Boring out pin holes
   / Boring out pin holes #1
enterprisebbc
Ct
2008 CK35 Kioti
Can someone tell me if its ok to bore out the pin holes in an angle snow plow cylinder? I have an old Jeep plow 6' with 1.5, 10" that have a 1" pin hole. Now all I can find thats not to much $ is the same with a 5/8 pin hole. Or I can weld a cpuple of washers on the plow to accept the smaller pins. I have found exact replacement with the 1" but they are $100 apiece. Any ideas? What would you do?
   / Boring out pin holes #2
If you are talking about reducing sleeves for the pin hoes, TSC has adapter sleeve to reduce the pin hole, or make your own.
Is that Tractor Supply?
   / Boring out pin holes #5
I would try boring the cylinder holes. You may find the cylinder rod is hardened and can't be drilled, if so I would bush the snow plow mounts for a smaller pin.
I think welding washers on would not be enough support and quickly wear out.
1673 (A54756)
1673 (A54756)
2014 International ProStar Truck, VIN # 3HSDHSJR1EN768255 (A54865)
2014 International...
2013 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400LB Crane Service Truck (A53422)
2013 Ford F-550...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
2025 Kivel Forks and Frame Mini Skid Steer Attachment (A55787)
2025 Kivel Forks...
2009 JLG 1930ES ELECTRIC SCISSOR LIFT (A51242)
2009 JLG 1930ES...
