DK45 FEL capacity issues?
/ DK45 FEL capacity issues? #41
I stand corrected about others having issues with the vent 'kit'. :confused3:
And to the OP, did you say yet if you have had the rear remote activated when having issues with your FEL?
(BTW, this discussion isn't a hijack of the OP's thread), it is however a pertinent clue to the OP's FEL issues, especially if the vent kit is being used without the new vent working properly.
Sorry- No. Your comment was in the middle of the back hoe discussion and I thought it was directed at someone else.
I do have T-N-T connected all of the time but they were not being used for anything. Plus I have removed the detent for that one pesky valve so it could not get locked into an active position.
/ DK45 FEL capacity issues? #43
OK, well that eliminates the rear remotes from the issue. Thanks for confirming. FWIW, often owners make up a loop of hose to plug into the detented remote to effect the same result.
/ DK45 FEL capacity issues? #44
That gave my an Idea. Bottom out on of your TNT cylinders and listen for the relief valve, tell us if you hear anything different.
I have the ROBB on there now and bottomed out each cylinder with the ROBB sitting on the ground. When each cylinder bottomed, it sounded like the engine came under a small additional load and the RPMs dropped a very small amount.
/ DK45 FEL capacity issues? #46
That sounds normal. Does your FEL do the same thing when it hits its limit?
/ DK45 FEL capacity issues? #47
Not sure if this helps but my Kubota BX 2200 makes a loud squeal when loader is maxed out. My Kioti 45 makes no sound at all. The only warning signs are RPM drop.
Redneck- yes this does make me feel better.
The tractor will stall at times with the RPMs ~ 1800 or so. And at this point I do not know if I am also moving forward along while lifting with the bucket deep into the earth or just lifting with the FEL with the bucket in deeply. I think there may be a fine here I am unsure of.
The other day I had the rock grapple teeth stuck under a large, life oak root which kept the FEL from lifting. And the engine did not stall, as I was lifting to no avail- many times. I do not recall if the RPMs dropped as this is a small drop and I was concentrating on other things. So at this point I now have to wonder if my issue was moving forward while heavy lifting with the bucket planted deeply while lifting that may have caused or contributed to the stalling, or not.
But either way I would think that this particular tractor should not be stalling at this RPM range for any of the things I am doing. Or maybe it is just a learning experience. In any case, the inline gauge testing parts should be here tomorrow and I will assemble and test, maybe Sunday- assuming I ordered the correct couplings. Saturday is already programmed for other tractor activities. I will post my results when I have them after thorough testing and this issue should then be put to bed. And maybe it will be a good reference for others in the future.
/ DK45 FEL capacity issues? #49
sdef, I have worked my FEL on my DK40HST...hard. Yes I have stalled out the tractor by going in too fast into gravel or dirt and no letting up when I took too big of a bite and I think that is normal. When mine max's out on lift there is almost no whine...it just stops lifting, but there is a subtle tone change in the hydro . Anytime I am lifting heavy things, I run it at max rpm...2500, right on that little red line. 2,000 rpm is too low for these HST tractors to get full lift potential out of them. From what I have read here, I don't think you have a problem, you are just trying to work outside of it's design parameters. HST's require more finesse then a gear tractor & it takes a while to get the hang of it.
/ DK45 FEL capacity issues? #50
1800 is a bit low for that tractor if you are doing real work. Consider 2000 as a minimum when you are trying to get things done. The HST in med will eat up your power quickly if you are in mud or whatnot.
/ DK45 FEL capacity issues? #51
There is 28 - 6x6x8 cedar logs in this bundle. I really did not think my DK would lift it, but it did(and no it didn't like it) and that is as high as I could go. I weighed a couple of the logs after I took this shot....One was 90, the other was almost 100, so if you average these out at even 90lbs ea, you get 2,520 and the forks weigh another 350 lbs. So according to the spec's this can't happen...inmo these loaders are a BEAST:thumbsup:
/ DK45 FEL capacity issues? #52
For those coming from gear or shuttle they are used to operating at low rpms. At 1800 my tractor feels like a dog still chained to his house, 2K is not much better. Running at the max rpm for a hst is completely proper, and won't hurt a thing....try it:)
The latest few posts are convincing me I most likely have no problems. However, I am now committed to building the inline hydraulic tester. Discount Hydraulic Hoses sent the wrong T-fitting yesterday and I ordered the wrong couplings for the FEL valve located under the right side of the operators station.
The female coupling is marked: Kwan Kwang 13 PT3/8. Can anyone identify what standard type this is so I can order 3 sets?
Thanks.
/ DK45 FEL capacity issues? #54
Man that is a lot of wood!
/ DK45 FEL capacity issues? #55
Yeah, I rearranged them a little them to look like this:) :
I will also mention that when my head gasket went under warranty, I got a "new" 50 horse Mahindra as a loaner for a week. I did not find that the Mahindra loader was any more powerful than the on on my DK, but the tractor and loader were physically larger.
sdef, yes I am also curious as to what you will find ref the pressure readings. I think all of us would like to have a hyd gauge hanging on the shop wall.
/ DK45 FEL capacity issues? #56
Please don't take this the wrong way, others have said the same thing, but "how do you stall the engine of a HST equipped tractor?" I have never done it. And would not know how to make it stall. The only thing I can think of is the Hydrostats relief valve was set very high? How can you possibly stall the engine? I have run up against immovable objects many times, One of two things happen, if in low range, the tires will spin, sometimes all 4.. or if in Med or High, they will either spin a bit and/or the relief valve will open on the hydro, and it will just "whine" and not move.. But in neither case has the engine died. It will drop RPM of course as it loads, but unless you were at such a low RPM that it dropped below where it could sustain rotary motion?.. Combination of low RPM, and very high hydrostat relief valve setting? Someone please 'splain this to me, I have been meaning to ask about it for a long time.
James K0UA
Easy to do. Did it about three times yesterday. Just keep the RPMs in a "comfortable range" like 1800 and then push hard against a tree. It will stall occasionally. It happens to me most often when I am intending just to pick up brush with the grapple and suddenly get the urge to knock a tree down without remembering to increase RPM. I have also stalled using a bush hog in thick brush (again at 1800-2000).
/ DK45 FEL capacity issues? #57
Thanks.
1/2 inch Pioneer AG Connectors.
But just think- this is the easy part. The follow on work is not something I want to be associated with.
/ DK45 FEL capacity issues? #59
maybe you are just pushing too hard on the HST pedal when you go into a pile of dirt. (same goes for Islandtractor)
try it again another way...push hard until you reach the pile, then remove 75% of your pedal push, that should letthe tractor breath while pushing in Medium range and working the FEL.
I never stalled it but on occasion when I'm trying to makes it work beyond its limit (and too fast) the RPM drop a lot and I let go the HST pedal to let it recover.
/ DK45 FEL capacity issues? #60
Yes, that is part of it. In my case I was picking up brush and just made sudden decisions to push against a tree. However, I have also stalled when mowing or doing other tasks. My point is that it ain't that hard to do.
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Hydraulic...
2008 MOTIV ALUMINUM TRAILER CO. 32 TRI AXLE GOOSENECK ENCLOSED TRAILER (A60736)
2008 MOTIV...
SHOPMADE MANIFOLD TRAILER (A58214)
SHOPMADE MANIFOLD...
2006 Ford F-550 Flatbed Truck, VIN # 1FDAF57PX6EB82087 (A61165)
2006 Ford F-550...
DECKED TRUCK BED SLIDING TOOLBOX (A60432)
DECKED TRUCK BED...
SET OF (10) ACE CATTLE PANELS W/CONNECTION JOINTS (A60736)
SET OF (10) ACE...
