The Log house Project begins........
/ The Log house Project begins........ #2,181
M7
As usual its a really awesome job!!!
My purchase in New Tazewell fell through but we picked up different place in Speedwell so we are still kinda neighbors :) just over the clairborne/cambell county line in Cambell county
/ The Log house Project begins........ #2,183
we had gusts up to 70 mph last night
kept me up an hour or two
thought I might have to yell Anti Am Anti Am or click my heals 3 times :laughing:
/ The Log house Project begins........ #2,184
You have a pair of ruby slippers--in the closet? :laughing:
/ The Log house Project begins........ #2,186
no and I don't have a dog named Toto either
just it was nasty out that night
looking at the weather it looks like the same for this Wed- thur
Gave the 'ole Beast a new paint job:
/ The Log house Project begins........ #2,188
The stove looks nice, were did you find high heat paint in a color other than black?
Dave
Dave first I tried Stove Bright:
http://forrestpaint.com/wp-content/uploads/2013/09/SBCC-1a.pdf
I found that their color chart was way off(can you say Jamacian Madri Gras?) and the paint chalked up after a month or so and would rub off with a fingernail.
This time I am trying Thurmalox:
Stove Paint - High Temperature Stove Paint
I found their colors much closer to the chart and I will post up an opinion on it's durability after a month or so of burning....so far so good and this is their Hunter Green. I also bought the Jade green, but it's a little too loud...wish I had tried the Midnight Green.
/ The Log house Project begins........ #2,190
that looks like some good stuff :thumbsup:
thanks for the link
ARGGGGG, the back porch transition is leaking when it's raining...AGAIN!...and it's doing it in two places. Looks like I will be removing the entire porch roof this spring.........grrrrrrrr
/ The Log house Project begins........ #2,192
Sorry to hear that....After your experience with the heater, I noticed my son`s house to be particularly damp when he ran his gas heater (natural gas) It also had a dampish smell in the house Tony
/ The Log house Project begins........ #2,193
Sorry to hear that Rick. Y'all have a HAPPY NEW YEAR anyway.
hugs, Brandi
/ The Log house Project begins........ #2,194
Dang.
Maybe the best thing to do is to eliminate the transition. Build up the porch roof side of the transition and run roofing continuous over that out to the porch eave.
Yeah Tony, I will be getting rid of the propane fireplace & mantle....not crazy about it and the moisture it puts out.
Same to you Brandi!
Dave, definitely some kind of a re-design is in order because if I don't fix this it's going to make me loose the rest of my marbles. I think I am going to call in some back-up and get another pair of eyes up there to inspect everything, because I am missing something & it might be something obvious.....or not.
/ The Log house Project begins........ #2,196
Rick,
Is your transition still the way you pictured it in the attached?
We discussed potential problems of a roof merged that way up here when you first built/photographed it, and your reply was: "that's the way we do it down here."
As I recall your front porch transition was the same. Did it develop any leaks? I don't remember which compass direction your back porch faces.
/ The Log house Project begins........ #2,197
Sorry for your roof leaking again. I can't begin to imagine the frustration.
/ The Log house Project begins........ #2,198
I had a porch with a similar looking transition leak on me once. The existing house didn't have a porch, and they wanted it to go out as far as possible. I think I went 12 feet. The house was a 6:12 pitch that was about ten years old, and I built the porch roof with a 1:12 pitch. After a heavy rain, there would be several leaks right at the transition where the flashing was that leaked into the porch area. I went over it inch by inch and couldn't find anything. I ran the hose over each panel right above the flashing and it never leaked. I spent hours out there over several days and could never get it to leak with the hose, but after a heavy rain, it leaked again.
Then I got the idea that maybe it wasn't anything that I had done, and maybe the existing metal roof was leaking. I put the hose at the peak of the roof and let it run. Sure enough, water started coming out at the flashing. What I realized was happening was the rubber gaskets on the existing roof where leaking and had always leaked. The builder put the metal over felt paper, over OSB decking. The water went past the gaskets in the screws, and then under the metal, on top of the felt paper. They had gutters there, so nobody ever knew it was doing anything unusual because the gutters caught all the water.
I replaced the screws in the roof and the problem was solved.
Eddie
Rick,
Yes the front developed one leak about half way across & to the right of the front door.
Ron, you may have missed it, but a few months ago I went back and shoved a 50x10" roll flashing under the bottom transition metal on both front and back porches. So this added another 5" to the lower half of the transition, and a no seam one 44' long. After that it rained several times and I had no leaks.....then two weeks ago {poof} two leaks re-appeared on the back(north) porch in the same area of previous leaks.
I went back and re-read the old posts, I saw the above reference, but can't find if or where you illustrated my transition metal is incorrect or the correct way if indeed mine is wrong. My metal guy & the gutter guy even came out and looked at it & said I did it properly.
The whole thing is baffling since I had all leaks stopped only to have some reappear.....
Eddie, you know I have been pondering that very question of a loose screw or two(on the roof not the established one's in my head), or screws that did not have a washer/gasket on them for whatever reason. Assuming that is the problem, why did it go away??...oohhh ohh, pick me pick me{hand raised}.....Warmer temps, roof steel atoms are all fat, lazy & spread out, winter comes and they are freezing their butt's off and huddling together for warmth...opening up a gap that Mr Water exploits???? Hmmmmmmmm................
/ The Log house Project begins........ #2,200
If there was enough moisture trapped below the metal roofing, freezing weather would cause expansion--perhaps lifting the metal and creating a dimple around the screw head? Then it thaws and the roof metal sinks back down leaving the dimple as a little unsealed trough around the screw head?
I dunno, just thinking about why it stopped then began again.
2021 CATERPILLAR 289D3 SKID STEER (A62129)
2021 CATERPILLAR...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
Strickland MFG 24" Excavator Bucket (A60463)
Strickland MFG 24"...
CK350KW SKIDDED GENERATOR (A60736)
CK350KW SKIDDED...
Paladin 12in Digging Tooth Bucket Excavator Attachment (A60352)
Paladin 12in...
1991 INGERSOLL RAND DD-24 SMOOTH DBL DRUM ROLLER (A62129)
1991 INGERSOLL...
