Temp Gauge
/ Temp Gauge #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
I was mowing some thick stuff today and looked down to see the temp gauge past the two dots. I stopped mowing, reduced throttle and just made some long passes out in the open to cool it down. I also looked and the grills were pretty clean.
This normal?
/ Temp Gauge #2
With the engine turned OFF, use compressed air and blow through radiator from engine side. I expect you will see quite a bit of chaff and debris come out. Make blowing out radiator a regular maintenance task.
/ Temp Gauge
I had pulled the radiator screens and cleaned them a coupled days ago but I've mowed quite a bit since then.
/ Temp Gauge #4
Working in an evironment such as bush hogging or baling hay creates a lot of chaff and debris in the air that all tractors are susceptible to. The small radiators on compact tractors make them more prone to clogging.
/ Temp Gauge #5
Clean those Screens every Day when cutting.
213135 (A64276)
213135 (A64276)
2008 Ford E-350 Cargo Van (A61573)
2008 Ford E-350...
1987 Polar 307 SS 3 Comp SS Insulated T/A Chemical Tanker Trailer (A64194)
1987 Polar 307 SS...
2015 Ford Explorer SUV (A64557)
2015 Ford Explorer...
2025 32in. Tilting Bucket Mini Excavator Attachment (A64553)
2025 32in. Tilting...
2002 Ditch Witch 1230H Walk-Behind Trencher (A64553)
2002 Ditch Witch...
