Temp Gauge
/ Temp Gauge #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
I was mowing some thick stuff today and looked down to see the temp gauge past the two dots. I stopped mowing, reduced throttle and just made some long passes out in the open to cool it down. I also looked and the grills were pretty clean.
This normal?
/ Temp Gauge #2
With the engine turned OFF, use compressed air and blow through radiator from engine side. I expect you will see quite a bit of chaff and debris come out. Make blowing out radiator a regular maintenance task.
/ Temp Gauge
I had pulled the radiator screens and cleaned them a coupled days ago but I've mowed quite a bit since then.
/ Temp Gauge #4
Working in an evironment such as bush hogging or baling hay creates a lot of chaff and debris in the air that all tractors are susceptible to. The small radiators on compact tractors make them more prone to clogging.
/ Temp Gauge #5
Clean those Screens every Day when cutting.
KUBOTA 4 BASKET HAY TEDDER (A64278)
KUBOTA 4 BASKET...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
2015 Ford Taurus Sedan (A64557)
2015 Ford Taurus...
