Temp Gauge
/ Temp Gauge #1
freewookie
Guthrie, OK
JD GT235, DK40SE HST
I was mowing some thick stuff today and looked down to see the temp gauge past the two dots. I stopped mowing, reduced throttle and just made some long passes out in the open to cool it down. I also looked and the grills were pretty clean.
This normal?
/ Temp Gauge #2
With the engine turned OFF, use compressed air and blow through radiator from engine side. I expect you will see quite a bit of chaff and debris come out. Make blowing out radiator a regular maintenance task.
/ Temp Gauge
I had pulled the radiator screens and cleaned them a coupled days ago but I've mowed quite a bit since then.
/ Temp Gauge #4
Working in an evironment such as bush hogging or baling hay creates a lot of chaff and debris in the air that all tractors are susceptible to. The small radiators on compact tractors make them more prone to clogging.
/ Temp Gauge #5
Clean those Screens every Day when cutting.
2019 GMC Canyon SLE 4X4 (A62679)
2019 GMC Canyon...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
E-Z TRAIL HEADER CART (A64278)
E-Z TRAIL HEADER...
2016 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A64556)
2016 Chevrolet...
2025 KENWORTH T880 DUMP TRUCK (A63276)
2025 KENWORTH T880...
Kivel 48in Forks and Frame Skid Steer Attachment (A64553)
Kivel 48in Forks...
