From which side do you mount your tractor?
/ From which side do you mount your tractor? #61
I learned to always mount & dismount a horse on the left and I guess it stuck, that said I have had tractors with no FEL and steps on both sides but I always mount/dismount on the left.
/ From which side do you mount your tractor? #62
should this thread be moved to the adult tractor owners only area?:laughing:
/ From which side do you mount your tractor? #63
I don't care which side someone dismounts from. If you are about to disembark and you notice a rattlesnake below; you will probably change sides.
/ From which side do you mount your tractor? #64
Man you got that right......
/ From which side do you mount your tractor? #65
On the left cause that's where the steps are.
/ From which side do you mount your tractor? #66
I don't know that I have a preference. Whichever side is convenient for the reason I'm mounting/dismounting. All else being equal, I probably use the left side more.
Either way, I have to swing a leg up and over the steering wheel. The seating layout on my '88 JD750, tho comfortable while operating, does not work especially well for my 6 foot 200 pound frame.
I love absolutely everything else about the tractor though. It has been through **** with me for 25 years now and never had a serious breakdown.
/ From which side do you mount your tractor? #67
Has anybody ever seen a left-hand joy stick???? 90% left, 10% right for me.
Now wondering if there are "left-handed" tractors, like shotguns, with FEL controls on the left?
That makes 3 of us asking that, but so far no answers.
I get on from the right, loader controls are on the left, because that is where I put it! :D
P7301900.JPG P7301902.JPG P7301904.JPG P7301905.JPG P7301909.JPG P9050001.JPG
If the loader is up, I can get on from the left.
/ From which side do you mount your tractor? #68
I generally get on my tractor from the left, or port side if you prefer. It allows for easier access as the loader controls aren't in the way on the left. Sometimes if I'm near a tree or something on the left side I'll get on from the right side. It is nice to have the option.
/ From which side do you mount your tractor? #69
It is easy enough to use either side on my JD855.....
Like said before...... I normally mount and dismount from the left side....
I was ask why I do that... Only answer I could think of was that is how you get on and off a horse....
And since the people that have ask know I grew up in Wyoming.....
It is also part to do with the fact one knee works better than the other.... And it is easier on both knees to use the left side...
Good luck
/ From which side do you mount your tractor? #70
Admittedly, I mount my bicycle from the right side. I don't know why. It may be because all of my bikes had kickstands mounted so as the bike leaned to the left. Why don't the put them on the right hand side? Why do NASCAR racers go counter clockwise, as does the traffic in skating rinks, and the horses and dogs at the tracks?
/ From which side do you mount your tractor? #71
counter clockwise, as does the horses and dogs at the tracks?
Down here it depends on what State the horse race is run. NSW & Queensland are clockwise, Victoria & Tassie are counter-clockwise. I can't speak for the other States.
Same thing for the dish-lickers... I think that they all go counter-clockwise but I'm not certain.
/ From which side do you mount your tractor? #72
This is why I read these "lame", i.e., not really structured practically useable knowledge threads, because I inevitably learn something by reading that I'd like to avoid having to learn the harder way, i.e., by doing, paying, suffering the consequemces.
I have mounted a step to the left side of our B2320's floor pan, and mostly use that to mount, UNLESS we have the MMM mounted, when I more than occasionally squeezed my 270#+ frame past the FEL control (which I do not lockout prior except at shutdown) luckily so far without incident.
This will no longer be allowed for me or anyone else using our tractor. The last thing I want to do is lose the use of my hard earned and fought for tool because of a moment of laziness.
That's my story and I'm sticking to it.
When I had my CK20 I almost always got on and off the left because the loader control was in the way. One day at the end of a long day I was stretching fence with the tractor and the fence kept getting caught on roots. I would get off, walk around the tractor, loosen the fence from the roots and walk back around the tractor. After about the third time instead of getting off the left, i stepped off the right. As I was stepping off, my denim short pants leg got caught on the loader handle. I then fell / jumped the rest of the way off and in the process popped the loader handle out of the valve. I ended up having to load up the tractor and haul it nearly an hour to the dealer to get new upgraded parts installed on my loader valve and handle.
I have a different tractor now, but I get off the and on the left side.
/ From which side do you mount your tractor? #73
Likwise on the miniex/trackhoe I rented a while back. There was also a pod that swung and locked down on the left after entry that would have made bailing out that way pretty dang difficult, but there was absolutely no way to egress fron the right. I think it was a matsu****a or some such...
RH cab doors are non-existent or optional on some tractors.
/ From which side do you mount your tractor? #75
I don't know about the other things, but NASCAR turns left because of the Coriolis effect.
xtn (expert at clever toilet humor)
/ From which side do you mount your tractor? #76
Wagtail, If my memory is right, the NSW "trots" go counterclockwise. In the UK some horse racecourses go one way, some the other. No idea why. Something to find out on a rainy day.
No need to wait for that rainy day...
RISA - Racing Information Services Australia: Why Race Courses are Clockwise or Anti Clockwise
And I forgot about the Standardbred trotters. Counterclockwise I believe is standard all across Aus.
I've heard it said that we Aussies will have a punt on which raindrop reaches the bottom of a window pane! :laughing:
Wagtail, I take that link with a rather large grain of salt. First, several of those racecourses are not in England and it is far from being an even half-hearted attempt at listing all the courses. Several major ones are missing. At the same time I have been doing a bit of thinking, and topgraphy appears to be important in the courses I know well - they all finish uphill. Some of them a fairly steep climb and for several furlongs. But, many are flat and there is no obvious reason for them to run one way or the other.
/ From which side do you mount your tractor? #79
Well, Mate, it is an Aussie link so I don't think that the intension was to list all the courses in the UK.
You're correct about topography being a factor in (at least) thoroughbred race courses and the link mentioned that... but didn't explain why. You have done that with your "they all finish uphill" observation.
Horses are trained by repetition so standardising track directions is good for the 'industry' as the country & provincial tracks can train the horses up for the major city tracks (and the BIG purses). Horses are also 'right handed or left handed' so the different directions would be slightly advantageous to certain horses. The country & provincial tracks follow the lead of the major tracks.
The thoroughbred racing industry is HUGE in Australia! When you consider our relatively small population, the major capitol cities (Sydney, Melbourne, Brisbane, Adelaide & Perth) all support FOUR major tracks! EACH. This coming Tuesday (always the first Tuesday of November) is the Melbourne Cup... otherwise known as 'The Race That Stops The Nation'. It's such a big race that, outside the State of Victoria & the ACT, it's practically an unofficial national holiday.
Wagtail, I forgot to mention that there are also two figure of eight tracks at Fontwell and Windsor.
Totally agree with you about many horses being better suited to right or left hand tracks. I know that many racing people also think that some jockeys are better going one way or the other. My experience is extremely limited, only in "unofficial" races on straight courses except for one on a country track in NSW, but I can see the reasoning behind it - jockeys become accustomed to going in a particular direction as well as the horses.
I am also aware of the importance of TB racing in Australia, and some fantastic horses have been bred there over many years. Black Caviar is only the latest in a long line, and their success in major races around the world is proof of their outstanding ability. I never did get to the Melbourne Cup, being in northern NSW for almost all the time I lived in Australia, but you are right - the whole country seems to stop operating whilst it is being run. Hope you pick the winner on Tuesday. As always, I will watch out for it coming onto YouTube.
2004 GMC 5500, Duramax Diesel Truck Vin# 1GDE5E1234F520387 (A62679)
2004 GMC 5500...
John Deere 1025R (A64126)
John Deere 1025R...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2010 PETERBILT 384 (A65643)
2010 PETERBILT 384...
2020 Broyhill Load and Pack Articulated Solid Waste Handling Vehicle (A59228)
2020 Broyhill Load...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
