looking for used snow plow
/ looking for used snow plow #1
enterprisebbc
Ct
2008 CK35 Kioti
Looking for a 5-6' or so used snow plow that I can re-paint and maybe fix the cylinders and add a QA. I looked on Craigs for CT and found nothing like that. Anyone know of some place?
/ looking for used snow plow #2
I know they're out there, but I looked high & low for several months before giving up. The plows I did find, the seller was either out in left field on the price, or the plow needed so much work that it wasn't worth it...to me.
I wish you well on your search.
/ looking for used snow plow #3
You could put a wanted add on craigslist.
Check on Ebay and ask everybody you know if they have a blade.
/ looking for used snow plow #4
Used plows tend to demand a premium price around here as well. You can usually find a beater truck with plow for the same price.
/ looking for used snow plow #5
wrong time of year to be looking for a plow for sure.
But why do you want one so small? Assuming you are going to use it on your CK35, I think 5' is a bit small.
Also, it is really small for a truck plow, and they arent that common. Try looking for 7 or 7.5' plows and then you can cut them down. I dont know what prices are now, but in the summer, you can pick up 7-7.5 plows with no mounting hardware (truck mounts and pump), just the plow, a-frame, and angle cylinders, in the $200 range.
I found one 7', old cyl's, truck mount for $400. How much are new cylinders? I can find a welder for a QA I think. I could sand blast it make it look like new. Couldnt look in the summer
A wanted add? Didnt know about this. Thanks
/ looking for used snow plow #8
Cylinders will probably be around $100 a piece.
Sent from my Samsung SPH-L710 using TractorByNet
/ looking for used snow plow #9
I agree, we have a 5' front plow on our BX2660 and it has no problems with it. The L3830 handles the 6' backblade like it isn't there.
Aaron Z
/ looking for used snow plow #10
Baileynet.com has snowplow cylinders for ~$50-$55 each
So about 100 for a pair
/ looking for used snow plow #11
Are truck plow cylinders suitable for the pressure of a tractor?
/ looking for used snow plow #12
I would think so, my Fisher puts out 1700psi and there are lots of people on here running FEL plows made from truck plows.
/ looking for used snow plow #13
Yes, truck plow cylinders should be just fine. The Meyers E60 pumps are set to 2500PSI.
And the crossover relief valves are usually set a tad higher. So when you bump a curb, while the pump dont see the pressure, the cylinders and hoses certainly do. They see a pressure spike.
Bumping into a curb will create substantially more pressure than the tractors hydraulics will deliver.
Which brings me to another point.....if you use a loader mounted plow, you really should use a crossover relief of some kind if you arent using a plow hydraulic unit. Otherwise you will blow lines and bend cylinders if you catch something solid with the corner of a blade.
Baileynet? OK I'll check em out tx
/ looking for used snow plow #16
I read somewhere that the truck plows rant at 600-700psi, I did not understand how that would keep the crossover relief from letting the plow flop side to side as soon as you started pushing snow. It looks like the cylinders baileys has are good for 2600psi.
I am not sure if a cross over relief valve is necessary on a snow plow. Shouldn't the spring trip save the loader if you hit something. What about if it was a manual angle? It would not have any protection unless they have a shear pin.
/ looking for used snow plow #17
My thoughts as well.
I don't have a crossover relief on my snow blade.
Any time I have hit something solid the trip springs trip.
/ looking for used snow plow #18
Trip springs only help on a straight hit or on a bottom edge hit, not if half of the blade hits something. I'd imagine the leverage exerted on hitting only the outside edge on a immovable object could mess stuff up pretty quick w/o a relief built in.
/ looking for used snow plow #19
the cross over is not designed to protect the tractor or loader or truck or whatever. It is there to protect the plow, angle cylinders, and hydraulic hoses.
Those of you without a crossover safety are tempting fate. On my truck, the crossover opens quite frequently. Like when pushing into a pile but you arent perfectly square, curbs, etc.
The springs only protect from something hitting down low. And sometimes even if you hit something low, but out on the edge, the plow wont trip if the blade is full of snow, rather the crossover protects you.
Think about the forces involved. These are only 1-1/2" cylinders. If the cylinder is 10" from the central pivot, and you are running a 7' blade, thats a 3.5x's mechanical advantage over the cylinder.
SO hitting an object with the edge with only ~1200lbs of force, and you are at 2500PSI in the cylinder. Hit somthing with more force than that without the safety, again, tempting fate, and it only takes on mistake to pop a hydraulic hose or bend a cylinder
I found another one for $200 which is better. Now I can replace the cyl. with new and I think I found a weld on skid plate from WorkSaver for $139. I will sand blast it an I hope I can be off and running for $5-600 for something like brand new.
2020 CATERPILLAR 140 MOTORGRADER (A63276)
2020 CATERPILLAR...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
New/Unused AGROTK Tire Changer (A65583)
New/Unused AGROTK...
2008 PETERBILT 365 (A65643)
2008 PETERBILT 365...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
