Simple approach for adding a tool box
/ Simple approach for adding a tool box #1
Kubota Tee
Gold Member
Hudsonville, MI
Kubota L5740 HSTC-3, Kubota L3540HST-3 (sold)
I've been wanting to add a real sized toolbox to my Kubota Grand L 3540 for some time now and have thoroughly enjoyed researching all the unique and creative ideas people have come up with for adding additional tool storage to their tractors. I wanted to leverage existing mount points on the tractor as well as keeping the design relatively simple, yet functional. I haven't seen this particular approach done before, but I can't imagine I'm the first one to come up with this idea. I started with a piece of 2"x3" angle iron and had it cut to fit onto the ROPS where they mount behind the operators station. Since I often travel on the local roads, I needed to incorporate the SMV mount into the design, so I also had a slit cut in so I could mount the bracket behind where the new toolbox will go. image-2858034732.jpg image-3932339490.jpg image-1586937327.jpg image-3090045696.jpg
/ Simple approach for adding a tool box #2
Where's the box?
Now that I have everything test fitted, I'm going to paint the new bracket to match the ROPs and hopefully by the time I have the paint job done my new 20" tool box will arrive. I'll post some pics of the finished product in a few days so you can see how it turned out. I'm really looking forward to the additional storage!
Where's the box?
I ended up ordering a Kubota branded tool box from Messicks. It's 20" wide, so I'll have a few inches on either side for a nice comfortable fit. Once it arrives, I'll get it mounted up and post some pics. Anticipation . . . . .
The UPS guy delivered the tool box today and just in time!
PRICELESS!!!
/ Simple approach for adding a tool box #6
Lookin Good! Nice job.
Thanks Murphy! I know I overpaid to get the branded tool box, but I figure it looks letter on the tractor and I won't have to worry about it rusting out on me.
/ Simple approach for adding a tool box #8
If that's what you want then that's what you want. You only have to please you.
/ Simple approach for adding a tool box #9
That is every which way cool !!!!!!!
/ Simple approach for adding a tool box #11
Looks good! "I know I overpaid to get the branded tool box, but I figure it looks letter on the tractor...." I agree, looks better on the tractor than a generic box.
After putting the SMV sign back on I wasn't happy with how it blocked the tool box. After further examination, I discovered additional mounting holes at the bottom of the factory tool box (if you could call it that). I had to make up an extension arm for the factory sign bracket, but it was pretty straight forward. Found a piece of matching width and thickness metal at the local hardware store, drilled some holes ..... 2 coats primer, 3 coats ROPS gray and back in action.
Also added some reflective tape to dress it up a little. Here's the finished product.
/ Simple approach for adding a tool box #13
Very nice. I wanted to mount a tool box in the same spot on my Kioti, but there wasn't enough space between the drivers seat (I run it all the way back), and the seat of my backhoe.
I can definitely see how that would restrict your space. Did you find another spot? I considered something off the ROPS and above the right fender, but opted for the rear location.
/ Simple approach for adding a tool box #15
I did. I welded up a basket to each fender and filled them with plastic ammo boxes:
I did. I welded up a basket to each fender and filled them with plastic ammo boxes: <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=342456"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=342457"/>
Very Nice! And thanks for sharing the pictures. I always like to see how the creative minds here at TBN have solved similar problems.
/ Simple approach for adding a tool box #17
U gave me an AH ha moment. Ive been looking 4 a place on my Ford 1510. Running out to chek out the ROPS/Fenders etc I considered the fenders but I do a lot of looking back with my BB & scoop & lean on the fenders.
Good to hear this thread helped spark an idea for you. To me, that's the real value of TBN!
When I started this idea, it almost seemed too easy of a solution - I'd like to think that the best solutions are the simple ones. I've been really happy with the added storage space.
Thomas
/ Simple approach for adding a tool box #19
On second look I am going 4 two small tool boxes one on each fender. I only will carry the things I NEED, my place isn't that large that I can't walk to a tool I don't carry. heck I have been carrying a 5gal bucket on my mower with extra electric fence stuff in it.. Some times I forget the mower is back there when I make a turn a bit too close to a corner..
Be sure to post some pics of your solution! I'm sure many will enjoy seeing how you do your dual fender tool storage!
Good luck.
Thomas
2012 Dodge Charger Sedan (A61574)
2012 Dodge Charger...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
2026 Stout TB-76 Tri-Blade Brush Cutter (A64047)
2026 Stout TB-76...
iDrive TDS-2010H...
2018 Ram 1500 Crew Cab Pickup Truck (A61573)
2018 Ram 1500 Crew...
