Kubota ballast box mods
   / Kubota ballast box mods #1
mani1147
New Brunswick
Kubota Bx2370
A few more mods from the man cave.
-Little dolly, great for un-hitching and moving the loaded box around.
-Added a 1-7/8" ball to tow my little utility trailer around the house.
-Added a ground ripper bar using a 36" "Canadian Tire" crow bar, tried this last night, worked great. (I just have to tweek it a bit more and make it pretty...!!)
Cheers
Mani
   / Kubota ballast box mods #2
Nice work Mani. Some fill their box with concrete....some install 4 inch PVC pipes for tools. You may have already done a search on this subject. Myself, I leave mine empty and stored on a skid outdoors. I can muscle it around to hook it up. And then I add whatever weight may be necessary for the job at hand. This also leaves room for some tool handles etc. Once that box is permanently filled, it is one heavy beast. Just a thought....worth at least :2cents: cheers, Mike
Thanks Mike, i leave the box filled with concrete blocks. On a level, solid floor, that little dolly works awsome in quickly removing/mounting the box onto the 3pnt hitch as it is 10" high, well within the lower range of the 3 pnt hitch, no more need for blocking or skids. Got the idea from a chap out in NFd Land.
Cheers...Mani
   / Kubota ballast box mods #4
Looks good Mani and welcome to the site. Always nice to see someone from NB on here. I did a similar thing to my ballast box as well.
WATER TRAILER (A58214)
500BBL WHEELED...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2007 Ford F-550 Crew Cab 11ft Flatbed Truck (A55852)
2007 Ford F-550...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2007 Kenworth Tandem Axle Road Tractor (A47477)
2007 Kenworth...
