problem opening web links with " aspx" suffix ?
/ problem opening web links with " aspx" suffix ? #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
At work we interface with a few prvate and govt web sites that we enter report data to, and then they generate a report for us. many times after report generation, there are buttons at the bottom of the page to say.. print confirmation.. or to save as a pdf.
last few days.. when i click save as pdf.. i get a IE diaglog box that comes up and says open, save, save as.. but instead of listing the pdf file.. it lists an address line that ends with aspx
almost as if IE is not processing the link to open the page that will then provide the pdf which I would save.
used to work fine. just recently changed?
is it a security setting on IE that is preventing that type of link?
any ideas?
machine happens to be a vista 32 laptop etc.
thanks
/ problem opening web links with " aspx" suffix ? #2
If its one website, its probably the website.
If its multiple websites, its probably the PC.
Did you run any updates lately?
/ problem opening web links with " aspx" suffix ? #3
Does it do the same thing in different browsers?
hmm.. will try same site from another pc or my tablet next time and see what it does.
that pc has auto updates on.. so it MAY have updated.. etc..
interesting read on the aspx
i wonder if axtiv x has anything to do with it. activex has been restricted on that pc...
/ problem opening web links with " aspx" suffix ? #6
Wouldn't you rather be working on tractors? :laughing:
/ problem opening web links with " aspx" suffix ? #7
Sounding, look in your downloads directory for the file you see in the dialog box. It's an executable that will download the .pdf you want.
no.. it errors out and does not save the aspx file either
SP36 VIBRATORY TRECH GRADER (A60736)
SP36 VIBRATORY...
2015 PETERBILT 367 WINCH TRUCK (A60736)
2015 PETERBILT 367...
2017 JOHN DEERE 350G LC EXCAVATOR (A62129)
2017 JOHN DEERE...
John Deere 6 Row Do All (A60462)
John Deere 6 Row...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
