Recomendations on this welder
/ Recomendations on this welder #1
kneedeep
AL Gulf Coast & MS Delta
Mahindra 3510 & 8560
Northern Tool has this unit on sale
Northern Industrial Welders Flux Core 125 115V Flux Cored Welder — 125 Amp Output | Wirefeed Welders| Northern Tool + Equipment
I need a small welder for 1/4" or less material. Mostly a repair or small fabrication around the farm. I have a ancient Lincoln with the big adjustment wheel here at home. I would like to be able to run this off a generator in the back of my UTV to make it more portable,
Could some of you guys that know about welding advise me on this unit or perhaps another one.
Thanks for any help
Wishfull thinking I guess-
I don't need a big fabrication quality machine, just something to do basic minor repairs and light fab work. I like to make yard art out of old scrap farm parts like bottle trees and flowers out of old disc blades [wifey really likes me when I make flowers]
Any recommendations for a good inexpensive machine?? [not cheap, inexpensive]
/ Recomendations on this welder #4
I would look at a good stick welder. Hey I'm all about flux core, I've run tons of it, but with 400-amp machines. I read stories all the time about these little wire feeders, there is so much to go wrong with them, from the drive roll system to the liner in the gun. If you go cheap with a wire feeder with in hours if not minutes you'll want to pull your hair out. You're gonna have to up you budget!
/ Recomendations on this welder #5
well, i have a Lincoln 120v wire feed that gets alot of use, and has so foir over 8 years. Cost me about $280-300 at Home Depot. Worth every penny.
As for northern equipment welders.....i personally wouldnt waste my $$ on their crap. At least Lincoln has a name to stand behind.
Now qas for working 1/4' stock, i like my wire feed unit better than a 120v mig. Better penetration on the thicker metals. Ive personally havnt had much luck with a 120v mig on 1/4" plate.
Also the lincoln unit accepts shielding gas unit, the northern unit doesnt.
/ Recomendations on this welder #7
I got to run one of those once. Years ago my x neighbor had a little Hobart 120-volt Mig welder. He was building some stake pockets for his flatbed trailer. He could not get it to run hot enough. So he came and got me. I think he was trying to do corner welds on 12-GA, but it might have been thicker. Only way I could get it to work half way right was to hold a longer than normal stick out:confused3:. That showed me right there I'll never own one. To me it's a lot easier to turn a machine down, than try to get it to work past it's capacity.
/ Recomendations on this welder #8
/ Recomendations on this welder #10
yup yup yup. I have this machine for one reason and one reason only..... i have to repair alot of horse panels on my place, and the 120v wire feed unit does a great job at that.....with available 120 outlets. The horse panels are too thin to weld with stick unit. Wire feed does an excellent job.
Im in the market for a 220 volt hobart wire feed unit...but its still a ways down on my need to buy list. when ive saves enough cash....its all mine.
/ Recomendations on this welder #11
Thanks for any help
1/4 inch steel is going to be at the upperlimit of a 120 volt machine.
The better ones are going to cost a bit more than you are thinking of. Like in the $500 range. I hear that Lincoln is the best for the 120 volt machines. Look for ones that have continuous voltage control vs. tapped voltage control. Welders you get at home depot, or lowes are low end crap. Go to your local welding supply (LWS) and see what they have. For the same money, you could buy a much more capable stick welder, unless you need to work on thinner stock much of the time.
/ Recomendations on this welder #12
Now qas for working 1/4' stock, i like my wire feed unit better than a 120v mig. Better penetration on the thicker metals. Ive personally haven't had much luck with a 120v mig on 1/4" plate.
Also the Lincoln unit accepts shielding gas unit, the northern unit doesn't.
I have one and it does well even on 1/4", if u take it slow but on 1/4" it doesn't have a very long duty cycle.
/ Recomendations on this welder #13
Forty plus years ago I learned to weld using an old buzz box that was too hot on one selection and too cold on the next one down to weld galvanized 16 ga horse panels. I can still weld 16 ga galvanzied fence tubing with stick. We used 3/32 6011 btw.
You can weld thin stuff with stick if you try.
What about the Lincoln 'Tombstone' welders?? Good enough or not enough??
I only need to repair and light fab work around the hunting camp/ farm and no heavy fab work.
Thanks for the advice!! I am at the right place! :blacksmith:
/ Recomendations on this welder #15
I ask the same question a few months ago. the smart guys suggest me to look for one of this
Arc Welder| Stick Welder | Power Arc
I pick the 300 I been really happy with it
/ Recomendations on this welder #16
I wish I would have waited until the PA-300 came out, instead of buying the PA-200! I most likely would not of bought the V350-Pro. For the money the PA-200 has the best arc I have ever seen. Longevity's Stickweld 250 is more money, but a lot nicer machine than the PA-200 because of the adjustable hot start and arc force. I think it runs 7018 better than the V350-Pro. I'd love to get my hands on a PA-300 to see how it runs! :drool:
/ Recomendations on this welder #17
Funny.. Before this post I was going to pm you to ask what you think of the everlast and longevity welders.. I respect your opinion highly.
/ Recomendations on this welder #20
SoGA,
You are about 45 minutes from me. You can run up and run one yourself.
2025 12v Fuel Pump (A61568)
2025 12v Fuel Pump...
2000 FORD F-550 XL SUPER DUTY DUALLY SERVICE TRUCK (A60430)
2000 FORD F-550 XL...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2020 Chevrolet Silverado 1500 (A55315)
2020 Chevrolet...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A62129)
KNOW BEFORE YOU...
