B7610 stalling
/ B7610 stalling #1
Raddad
Michigan
Kubota B7100 & B7610
My Kubota B7610 has been intermittently stalling for 5 years. Once every few months it would slow down to the point of almost stalling. Full tank or empty tank didn't matter. Over the last 5 years I temporarily jumper-ed out all the safety switches to no avail. I changed the fuel filter carefully examining all the seals and O rings. I disconnected the fuel line at the bottom of the fuel tank and blew it out with a modified fuel cap. I removed all the fuel lines and blew them out. I decided I would remove the fuel tank to examine it for an intermittent obstruction. See the attached picture. ( The forum won't accept the picture from my new Droid X.) I found a 2" X 1/2 inch piece of tree bark when I rinsed the tank. I hope this finally fixes the stalling problem. It will take a few months to convince me that I fixed the problem once and for all.
/ B7610 stalling #2
That could certainly interrupt your fuel flow. Here's hoping you found the issue!
Sent from my iPad using TractorByNet
/ B7610 stalling
I have now used the tractor for 8 hours without stalling. Note: The tank has no screen and the outlet is at the very bottom of the tank!
/ B7610 stalling #4
Looks like you found the cause of your problem Raddad, any ideas how it got in the tank?
/ B7610 stalling #5
Very similar to what I had. A piece of plastic pipe rolling around the bottom would roll over the outlet and restrict the flow. No rhyme nor reason to when it would happen but I finally spied it in the bottom of the tank one day.
