4wd Framtrac 555
/ 4wd Framtrac 555 #1
jcos52
Panama City Fi.
Farmtrac 555DTC
I have a Farmtrac 555 DTC 4wd (2007)The problem is it will not go into 4wd. I was told it was because of a spring in the gearbox that engages the 4wd. Does anybody know about this and how hard is to repair? Also whenever I turn my tractor it doesn't matter which way I turn the back wheel tears up the ground.
/ 4wd Framtrac 555 #2
Sounds like u have a diff lock. Not sure if it being engaged would prevent you from using 4 wheel drive but it definitely will tear up ground during turns. Check your manual or look for a small pedal rear of yor left foot.
2018 John Deere 3033R (A64126)
2018 John Deere...
1974 Ford F600 Grain Truck (A63118)
1974 Ford F600...
ALLMAND MP65-8E1 PORTABLE (3) PHASE GENERATOR (A63276)
ALLMAND MP65-8E1...
2010 Ari Hetra HDML-8 15,000lb. Heavy Duty Mobile Column Lifts (A61572)
2010 Ari Hetra...
John Deere 6125R (A64126)
John Deere 6125R...
2018 PETERBILT 567 (A65643)
2018 PETERBILT 567...
