R4041 steering issue?
/ R4041 steering issue? #1
boomer632
Steeler Country
2011 LS R4041EZ - 2014 Bad Boy CZT Elite - 1948 Ford 8N
I was mowing today and was making turns when I noticed that there is no steering stop. When it turned the wheel all the way left or right the steering wheel did not come to lock. I could just keep turning the steering wheel even though the wheels were at full turn. Never noticed that before. Anyone else notice this? Possible pump problem?
/ R4041 steering issue? #2
You probably lost the bolt that limits the travel.
Does this bolt cause the steering wheel to stop at full turns? Would you please be so kind as try this with your tractor? At about 1800 RPM turn the wheel all the way left or right. Does the steering wheel stop at full turn or can you keep turning it while the wheels dont move?
/ R4041 steering issue? #4
I'm 99% certain that if you turn the wheel all the way, it will hit the stop, and you can't move the steering wheel any further. I'll check when I get home. R,
/ R4041 steering issue? #5
Tested it on mine, and it's as I described. I guess you could get the wheel to turn, but you'd have to crank on it, making it slip (like when the engine isn't running).
Look at your left front hub....it will have a stop bolt in front, like the one below, and a similar one in back (mine is painted black). Sorry for the bad pic....it was in the shade, and I only had my work Blackberry on me.
/ R4041 steering issue? #6
If your hydrostatic steering motor is worn, the wheel will continue to turn if you apply pressure even after the wheels hit the steering limit. Does it turn easily or just gradually move round as you put on pressure. It shouldn't do this on a fairly new tractor. Time for a dealer call if that is the case.
My stop bolts are still there. It doesn't take a lot of force to turn the steering wheel at full wheel lock. Almost seems like a relief valve is opening.
/ R4041 steering issue? #8
I think you should get a prize, you may be the first one on here with a legitimate problem with the tractor itself. Sorry you had to be the one. Hope you get it worked out.
/ R4041 steering issue? #9
Could be, or maybe a seal in the valve....probably an easy fix.
/ R4041 steering issue? #10
Boomer632, did you ever get this checked out? My 4041 does the same thing.
I have not had a chance yet. Need machine to finish some projects. If you do... please let me know what your dealer says. Everything down there looks normal and steering stop bolts are in place.
JOHN DEERE HX 14' ROTARY MOWER (A63291)
JOHN DEERE HX 14'...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2007 John Deere 1790 Planter (A63111)
2007 John Deere...
1063 (A63291)
1063 (A63291)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59911)
2016 FREIGHTLINER...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
