Truck payload question
/ Truck payload question
Exactly what I wanted to confirmed !
That's the way I saw it also...so a F250 is needed for the job. Thank you !
Black
/ Truck payload question #22
Well I've got a 2 ton air conditioner, but it won't even haul a ton of rocks.
/ Truck payload question #23
If you compare the GVWR sticker on my truck it states 11,500# max weight...
This is an 03 F350 4x4 dually crew cab...
Full of fuel with my fat tail I am in the 8,000# range for a measly payload of 3,500#...
But...
The rear axle on my truck is a Dana 80 rated at 11,000#...
The front axle is a Dana 60 rated at 5,200#...
That is over 16,000# worth of axle on a truck rated at only 11,500#...
The difference is in the spring packs...
I would not be at all concerned loading up my truck to 15 or 16 thousand pounds total if I upgraded my springs...
See what your axles and spring packs are rated for...
That will give you the true hauling capacity of your truck...
/ Truck payload question #24
Exactly what I wanted to confirmed ! That's the way I saw it also...so a F250 is needed for the job. Thank you ! Black
No you don't. I have an F150 with max tow but NOT max payload and my sticker is 1835 lbs. It would have been about 500 lbs higher with the max payload package. Basically the max payload package is an f250 but you keep the engine choices from the F150.
/ Truck payload question #25
But...
Noy sure what year your truck is but my 06 F350 SRW 4x4 is also rated at 11,500# gvwr. It weighs 7,600# with me and fuel so my legal payload is 3,900# which it handles just fine. I have had nearly 5,000 in it for a short 15 mile trip.
The dually of that era I see are rated at 13,000# gvwr.
Chris
/ Truck payload question #26
Dont forget brakes and cooling..
/ Truck payload question #27
If you compare the GVWR sticker on my truck it states 11,500# max weight... This is an 03 F350 4x4 dually crew cab... Full of fuel with my fat tail I am in the 8,000# range for a measly payload of 3,500#... But... The rear axle on my truck is a Dana 80 rated at 11,000#... The front axle is a Dana 60 rated at 5,200#... That is over 16,000# worth of axle on a truck rated at only 11,500#... The difference is in the spring packs... I would not be at all concerned loading up my truck to 15 or 16 thousand pounds total if I upgraded my springs... See what your axles and spring packs are rated for... That will give you the true hauling capacity of your truck...
I politely disagree. You are not concerned with frame strength, or more importantly braking capability?
/ Truck payload question #28
Chassis or frame, Axles, brakes, tyres, hitch rating, and most importantly manufacturers rating all come together to determine gross vehicle weight and towing capacity. I have seen a tricky manufacturer rate a vehicles gross weight as one thing meaning a carry capacity of 1 ton and apply a 1 ton towing capacity but in the vehicle specs fine print the towing capacity max was only applicable if the carrying capacity was reduced to 1/2 ton.
If the manufacturer will upgrade the rating often contingent upon Tyres, brakes, and springs then you may be able to get the licencing authority to upgrade too
/ Truck payload question #30
On my f-250 according to specs my front axle is overloaded with 2 passengers in the truck and I can only haul like 1600 lbs to exceed the GVW of the truck. SOOO take these ratings with a grain of salt. With my 9'4" v-plow and weight in the back the truck weighs in at 10,200 lbs and handles it like it is not loaded at all. The plow/bracket weighs in at 1200lbs. The front axle weighs 5500lbs and is only "rated" at 4400 it has been hauling this from day one in the winter every winter for 10 years with no issues and 1 set of ball joints. I purchased a 2000 GM 3/4 ton that was "rated" to do the job and had to replace the torsion bars because of the front end sagging and front brakes every 30k miles because of being so small. So again I take these ratings as rough guidelines and talk to people who know from experience what is going on. Tire and axle ratings tell me more than anything. CJ
/ Truck payload question #31
Okay , I want to hear your definitions of 1/4 , 1/2 , 3/4 , and 1 ton trucks . Explain the ratings with facts . Why the ton measure ? I know for a fact , a 1/2 ton truck is not gonna haul 1000# of rock or sand very far . Excuse my ignorance .
MY opinion,
the best I can come up with is the ton rating is a old military cross country rating, (cargo weight)
I do not know when it became popular, but my guess is ex military under stood (post ww2) what a 1/2 ton rated truck could do and what a larger ton rated truck was capable of, most likely more of a selling point,
I have a old 6X6 2 1/2 ton truck, the cross country rating is 5000 pounds but the highway rating is about 10,000.
but the best way is to go off of the GVW tag
even tho the ton rating is still used going by truck classifications probably more accurate, today
http://en.wikipedia.org/wiki/Truck_classification
http://voices.yahoo.com/guide-truck-classes-light-medium-heavy-duty-5266315.html?cat=27
http://www.wrcog.cog.ca.us/downloads/050205 Truck Type Appendix.pdf
/ Truck payload question #32
Try wikipedia for an accurate answer.
/ Truck payload question #33
If you get into a wreck, the insurance companys might take issue with you being overloaded. The RV world had the same issues of being over weight with just people in them as the OEMs where building way over weight.
/ Truck payload question #34
MY opinion,
Truck classification - Wikipedia, the free encyclopedia
Guide to Truck Classes: Light, Medium and Heavy Duty - Yahoo Voices - voices.yahoo.com
Deuce and half... Nice! :thumbsup:
/ Truck payload question #35
Not sure what printed material you are referencing but the printed yellow sticker on the door specifically says payload capacity is without passengers. You must subtract passengers from the number given.
Sorry I was looking at "Cargo Weight Rating" not "Payload" I'll read more closely next next time.
/ Truck payload question #36
So true, I put the insurance companies in the same spot as lawyers. No common sence and all about the $$$. Funny a 1/2 ton rated at 11k towing is legal with no trailer brakes pulling a fifthwheel but me with my gooseneck at 16k with everything functioning and safe but 3k over the manufactures RECOMMENDED tow rating is illegal. Welcome to stupidity at it's finest. Thats why the gooseneck is gone. I'll tow with my tags from now on, draws less attention. CJ
/ Truck payload question #37
Hello ev1 !
Just a quick question about truck payloads...
When looking at truck specs...does the payload given includes the passenger + the cargo....or applies just to cargo.
I'm shopping for a new truck, and this will determine if I go 1/2 ton or 3/4 ton.
I don't trust sales person word on that issue :confused3:
Thanks for the info, and...great site !:thumbsup:
BLACK
Once you zero in on a truck to purchase, get the dealer/seller to fill the tank 3/4 full. Get in and drive it to the nearest truck scales. Pay the $10 or whatever and get it weighed- front axle on the scale, then both axles on the scale and then the rear axle on the scale. This will give you the "curb" weight as well as the weight on the axles. Subtract the measured curb weight (weight on both axles) from the GVWR to get the payload capability.
/ Truck payload question #38
Why 3/4 full? Who wants to estimate how much the other 1/4 tank weighs?
/ Truck payload question #39
I always do 3/4 full because I never let my truck go below 1/4 tank when towing. So that is right in the middle.
Say you have a 30 gallon tank. Each 1/4 is 7.5 gallons @ 6# per gallon or 45#. So 3/4 tank is 135# and a full tank is 180#. Splitting hairs if you are worried about 45#.
Chris
/ Truck payload question #40
Chris
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
RoGator RG1300C (A63688)
RoGator RG1300C...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
Snap-On Gold Medal Tribute to Excellence Limited Edition 3-Bay Tool Box (A63689)
Snap-On Gold Medal...
2014 Chevrolet Traverse (A62613)
2014 Chevrolet...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
