tire chains
/ tire chains #1
bob vaillancourt
masson nh
yanmar336d
hey all. have a problem hope someone can help . tractor chains that i bought for my tractor a few years ago had a twist in the side chain . its where the cross links are bent on to the side chains. side chains have a twist and when i try to turn the link that the cross link is attached to it puts more of a twist in the side chain . i remember that they were this way when i bought them. and put them on one winter up north of my state of new Hampshire. now my tractor is back home in the southern part of my state for some summer repair in my garage. last thing to do before i bring it back up north for the winter was to put on the tire chains and their lies the problem of the twisted side chain.e fore i decide to pry open the side links and try to take the twist out i thought i would ask you folks those cross links are made out of 3/8 round stock. would probably have to heat them up just to bend them .hope some one can help thanks a lot bob in n.h.:dance1::dance1::dance1::dance1::dance1:
/ tire chains #2
Go to tirechain.com and buy a $95 pair of pliers. Get the one with 33 inch handles. Easy, simple and fast.
Large Repair Pliar
/ tire chains #3
I've clamped them in a large vise so I could open and then close the link. But it's not easy and sooner or later I'll buy the large tire chain pliers.
/ tire chains #4
I have 3/8" chains, they are tough as heck and hard too. The pliers would have to work really well to do much with them I think, but have never tried it.
If you can't get the twist out, you can cut that link out with a grinder and replace it with a screw together quick link. They hold up pretty well.
tirechain . com does sell replacement parts, including the hook link that goes from side chain to cross-tire section--if that is what is twisted.
/ tire chains #7
I had some tire chains for my puckup a few years ago that I was sure had a twist... but after carefully laying them out on a smooth surface and laying each link down as it should be, it turned out that they had simply gotten pulled thru themselves. It was as simple as pulling the chains thru the hole created by the side chains and cross chains at the point of the twist in the proper direction. Just takes some time to check closely... well worth it before you go opening links. Likely you will find a twist in the cross chain as well as the side chain close to it. Or maybe both side chains... take your time.
Good luck... chains are awesome. With chains front and back on my 4x4 pickup there is no such thing as snowed in... at least where I am!
/ tire chains #8
I had a similar issue, twist in chain I couldn't figure out how to remove. Before I spent any time trying to unbend/rebend the links. I did what dieselcrawler did. I laid them out on my driveway and very carefully aligned all the links and finally found where a side and cross link were twisted. I fed the chain back thru to untwist it and it all fell into place.... no need to fight with bending the links. :)
/ tire chains #9
Be careful with tirechains.com "HD" pliers. I bent the snot out of the jaws working on my 3/8" tractor chains which they claim to use them every day on. I tried to get them replaced ( I bought them specifically for this task and only had them a few days) and all I got was an offer to sell me the jaw at full price.
/ tire chains #10
You bent them? I figured the weak part was the thin spreading side and probably would break before bending. Mine worked just like advertised and the only down side was that I didn't get my moneys worth before the job was finished.
/ tire chains #11
The chains I purchased for mine had one link that was twisted. I messed with it for an hour, and couldn't get it to correct itself no matter how hard I tried.
But a hammer, chisel and vise did the trick.
/ tire chains #12
I had 4 or 5 like that on a chain. My neighbor has a set of tire chain pliers he let me use.
/ tire chains #13
Yea I bent them. That was what the tech on the phoneline said to. I think he asked if I was using anything for leverage and I told him no. He didn't believe me and I even had to send them pictures to prove there were no scratch marks on the tool. IMG-20130220-00063.jpgIMG-20130220-00065.jpg
They are not bent in one direction either.
2017 Dodge Charger Sedan (A61574)
2017 Dodge Charger...
UNUSED ATS POWER ATS-PC90 HEAVY DUTY PLATE COMPACT (A64281)
UNUSED ATS POWER...
Hydraulic Stump Grapple Bucket Mini Skid Steer Attachment (A61572)
Hydraulic Stump...
2016 Komatsu WA320-8 Articulated Wheel Loader (A61572)
2016 Komatsu...
2019 CHEVROLET 5500HD LCF S/A  4X2 24FT BOX TRUCK (A59912)
2019 CHEVROLET...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
