CK20S Stump Wars! 2013
/ CK20S Stump Wars! 2013 #1
rider7767
Paris, TN
TYM T264 with loader and implements
CK20S clearing land.
:cool2:
/ CK20S Stump Wars! 2013 #2
You should have some weight on that 3 Point Hitch.
/ CK20S Stump Wars! 2013 #3
CK20S 1
Nasty stump 0
Good job:thumbsup:
It was not that heavy, and the tires are loaded. When I get to my walnut stump, that will be another issue. I will just have to push that one across the ground.
/ CK20S Stump Wars! 2013 #5
Oaky Doaky. But if it were mine I'd have at least 500# back there.
/ CK20S Stump Wars! 2013 #6
My CK 20 eats big stumps for breakfast.
rimshot (member, ck20 whopper story club)
/ CK20S Stump Wars! 2013 #8
Much as it pains me to say so, Murph is right about wanting something beyond loaded tires for ballast. Maybe not so much for that particular stump but definitely for counterbalance in general. It's not when you think you need it so much as when you think you don't and actually do, only to realize it too late.
What is the ground where you are? Looks like soft clay? Man that looks like easy digging?!
/ CK20S Stump Wars! 2013 #9
Why does it pains you?
That is some hard clay with a taste of rock. My new teeth on my bucket seem to be holding up.
I do use my box blade most of the time as a counter weight. This was a light Popular stump in a tight place on level ground. All is well. But keep the advice coming. I have been know to do some stupid stuff.:confused2: If you hear me say "watch this", you had better get low! :laughing:
/ CK20S Stump Wars! 2013 #11
/ CK20S Stump Wars! 2013 #13
On this we agree!
To the OP, another caution would be how you're using the tip of the Stihl bar/chain. That's asking for kickback, at least the way it appears in your pic. Be careful of that; either get lower to the stump or dig out around it to be able to get more of the bar into the stump- next time. Put on some chaps and chainsaw boots, logging helmet too. If you're working alone you're in danger, all it takes is one wrong move or a millisecond of inattention. And I'm not a safety police kinda guy, but I've worked professionally with saws and know what can happen to even those with lots of experience.
Can't we all just get along! LOL
/ CK20S Stump Wars! 2013 #16
What/How are you guys getting hooks on your bucket?
As far as ballast goes, I always leave at least my cutter on mine and have the calcium filled tires...
/ CK20S Stump Wars! 2013 #17
/ CK20S Stump Wars! 2013 #18
Hi All,
Unlike some of the safety police types postin here, I'd just like to quietly point out the unsafe hook-up in rimshot's first picture, where although the load hangs down from the center of the bucket, the attachment point of the chain is solely on the left hand grapple mount, from whence it crossed over to the center hook. This mounting applies a twisting torque the the left hand bucket mount and is essentially trying to twist the bucket off the mounts.
We should all avoid this kind of one-sided or torquing hook ups, instead either just using the center mounted hook, or better yet, both of the end points. Also, the positioning, while dramatically impressive for a picture, is too loose, making the bucket have to rear up too high, and bringing the COG too high risking lateral instability.
Thomas
Just weld them on,, They are locally available at farm supply stores, or can be ordered over the internet. It just takes a few minutes even with a stick welder. Some 1/8 7018 at about 125 amps works for me.
View attachment 337453View attachment 337454
Amazon.com: Hook, Weld-On, Grab, 4700Lb: Industrial & Scientific
James K0UA
I like it. I made my own, because my tractor is small and the lifting capacity is only 1900lbs. Yea, but size don't matter. :D I like making stuff also.
(1) 235/80R16 TIRE W/ (8) LUG WHEEL (A64280)
(1) 235/80R16 TIRE...
2015 Honda Accord Sedan (A64557)
2015 Honda Accord...
2008 Allmand Max-Lite ML20 20KW Towable Light Tower (A64194)
2008 Allmand...
2016 VOLVO SD115B SMOOTH DRUM ROLLER (A65053)
2016 VOLVO SD115B...
HONDA generator (A64557)
HONDA generator...
2019 VOLVO VNL760 6X4 T/A SLEEPER TRUCK TRACTOR (A67147)
2019 VOLVO VNL760...
