New X749 with 54C deck has terrible cut quality
/ New X749 with 54C deck has terrible cut quality
Don't get me wrong the X749 is worth every penny when it comes to my hilly landscape. No other mower can handle my hills with the stability this thing has but I'm with you all, JD fell short with the decks. I understand that most of what you pay for on these machines is the AWD and the versatility of the machine to be used for other things but still for 13-15k this thing should have the best possible cut in the business considering it is the main task it was made for. I don't have any of the uneven deck issue some of you have however the I have experienced the terrible cut of the JD's mulching kit. I have learned talking with some fellas that mow professionally with Zero Turns and they don't run mulching kits either because of the cut quality.
/ New X749 with 54C deck has terrible cut quality #42
That mower seems too heavy for 7psi.
In some cases I find it necessary to run more air in one front tire to level my old deck up.
How does this work? Don't tell me the x7xx doesn't have a pivoting front axle.
/ New X749 with 54C deck has terrible cut quality #43
I should have stated that mine is an old 445, but it does have the larger frame and commercial deck.
Book says 8-14psi in front tires. I start at 12psi, then up to 15. I have slopes and the tires seem more stable with more air.
I can't explain exactly how it works but at times I decide one side is lower or higher than the other.
I can add just 1 psi in to one of the tires to level it up.
The tires inflate on top in concave bubble and you can raise the deck even 2" at the ends with air pressure.
My 445 has 16 x 7.5-8" and the rears are 23 x 8.5-12"
And the newer mowers may to have even wider tires than mine.
/ New X749 with 54C deck has terrible cut quality #44
I'm not sure how that works either, but I'll take your word for it.
I wouldn't mind having a 445, they seem like tanks.
/ New X749 with 54C deck has terrible cut quality #45
Well Dealer coming tomorrow to take it in for further research. Said Factory rep coming in to evaluate. This is the second time. Dealer replaced drop links two weeks ago on first return. Glad grass season is just about over. I have a feeling the X758 going to be gone for a while. I will let you all know what and if there is a solution. I just double checked the deck blades depth. After two trips back and forth on my front yard, deck dropped 1/4 inch on right side.
/ New X749 with 54C deck has terrible cut quality #46
So are they giving you a loaner in the mean time? How come the rep couldn't come to your house to check it out? Seems like seeing it in action would be the best way to diagnose.
/ New X749 with 54C deck has terrible cut quality #47
Gator: Done that at Least 2 dozen times. I had pressure in front at 22 because I didn't want it spongy. Dealer set it back to 10 lb when he returned the tractor last Friday. I just checked level, the deck was Right on at 3 inches both sides with John Deere Mower depth gauge. Cut two Strips. Brought mower back into level concrete floor of my garage. Checked level again and Right side off by 3/8 inch. My dealer came out to my house. Spent all of two hours double checking my procedure on deck leveling, grass cutting. I. Demonstrated my knowledge of lawn tractor lawn care. Cut up and down and back and forth on my front lawn. Man it looked like it was cut with machete when I was done. . Dealer said, never seen that before. Took it for 8 days and replaced drop link. Coming tomorrow for second repair. Very frustrating. Also I got a bad feeling about the eventual outcome. Deere saying, Don't know. Yours is the only tractor in the world doing this. Must be the deisel fuel your using, it's your grass, should of never put 22 lb in tires now the mechanical plain is off, are you driving with one hand, not wearing your owner edition hat we sent you. Yada, yada, yada.
/ New X749 with 54C deck has terrible cut quality #48
Use the Mower Depth gauge and check the blades to ascertain if one is bent. Check the height on the blade tip then rotate the blade and check the other end to determine if their is any difference.
/ New X749 with 54C deck has terrible cut quality #49
Done it, even measured across all blade tips. Dead on, straight across. Also measured height of spindles thought I had a odd duck spindle. Iam beginning to believe it might be the ridged deck/draft assemble as specified in original post. I went and shook it up and down on the discharge side very little give. I know on my old 4110 if you stood on the deck suspended, it sagged a little. Appreciate all suggestions.
/ New X749 with 54C deck has terrible cut quality #50
Dealer hauled it off about 0730 this morning. Mike, no loaner, didn't offer to bring the rep buy. Why? I could surely speculate being a suspicious person. But so far they been a pretty good outfit. Been proactive pretty much on this issue. I am hoping it's because they stand behind their product. Owned Deere since 1980. From same dealer. First time I have had an issue.
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
TANK MANIFOLD (A58216)
