Let's See Your Workbench
   / Let's See Your Workbench #71
Some really good set ups! Giving me a few new ideas
   / Let's See Your Workbench #72
This shows my lay out. I have a desk for finishing work, a wood workers bench, a metal area, and most of my tools in or on rollers/roller carts. This lets me take them out of the barn to work. I also have outlets all around the outside of the barn.
This shows my finish area, a log bowl carving bench, my wood working bench, and behind there is a router on an old vanity along with my table saw all on wheels. You can see all the white buckets, i have each labeled and put in shelving between the studs to save room.
my bandsaw and metal working area, behind the band saw is another bench. Along one wall I have a fold down shelf that a chop saw is on.
   / Let's See Your Workbench #73
Lee that looks like a REALLY nice start to your shop/upstairs all open or gettign sectioned off for living storage work shop??
Make sure to get additional skirt boards under them to keep critters from getting under the slab when ya eventually get some concrete in there. It took 8 or 9 years for me to get the concrete in mine and I ended up re-doing the stairs going up into my 2nd floor. It was a straight staircase that went into the middle (spot like yours but stairs went straight up along back wall. I took them out and put in a set like yours in the corner tho.
Mark
Thanks Mark. The space under the boards is closed off now that the final grade is finished outside.
   / Let's See Your Workbench #74
Mine was from a kit. The steel legs and bottom shelf are all bolted together. I put a solid wood door on top then wrapped the door with 18ga. galvinized sheet metal and installed a 12 receptacle outlet strip. It works well for my little garage and holds the weight of everything I've put on it - so far.
The worst part about it is it catches all my tools and incomplete projects so there's never any room on it and I can never find the tool I'm looking for!
   / Let's See Your Workbench #76
Lee: I have 2 to 3 8" T&G skirt boards buried under the final grade at my place because of the critters. I have Styrofoam underlay insulation so HAVE to keep critters away and radiant barrier too so warmth in winter when heat goes in (someday maybe.)
This is what the stairs look like going up to the 2nd floor NOW
This is what the corner looked like after the Straight steps were tore out (prepping for concrete, my older brother helping.) You can see some of the skirt boards but at this point I think 2 were below grade. In top right corner you can see the 2nd floor original opening. I cut it out back to the wall and moved that cut out section of floor forward to gain space in the center of the 2nd floor FLOOR. It was about 6' worth of floor space move but it made my 2nd floor layout better.
The original straight staircase also was close to the corner maybe 42" from the wall so limited the access some. I can eventually add a 2nd floor door where the NEW floor area is at and steps or deck outside...
(BTW that post is straight just a camera lens distortion :))
Mark
   / Let's See Your Workbench #77
OK, I am fascinated...is that a VW engine and if so, what's it for?:steeringwheel:
Yes, good catch Iowachild. VW Type 1 - 1776cc hot rod motor to my trike I built in 1977, from a 1966 bug. I'm replacing the axles to my swingaxle frame so the motor and transaxle had to come out. I also have another trike I built in 1999 from a 1973 bug. The wood barrel is the '77. I love building trikes and working on air-cooled VWs. (On my workbench!)
Sorry to go off topic but a chance to show off my passion is just beyond my limitations!
   / Let's See Your Workbench #78
Sorry all. I hope my last off topic post didn't kill/ruin this thread for everyone. :sorry:
   / Let's See Your Workbench #80
I really like the multiple outlets, as you never seem to have enough. I'd have put them about a foot higher up though to keep them out of harm's way for the big things that will wind up on there sooner or later.
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2017 Toro Z-Master 7000 Series 70in Zero Turn Commercial Mower (A53421)
2017 Toro Z-Master...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2006 Isuzu NPR-HD Landscape Dump Truck (A53422)
2006 Isuzu NPR-HD...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
2002 POLAR TANK TRAILER TRANSPORT TRAILER (A55745)
2002 POLAR TANK...
