where to do hydro oil
/ where to do hydro oil #1
chubby
Georgetown, De
Kioti DK50SE hst w/hoe & John Deere 3720 hst cab & John Deere 3120 hst w/375 hoe
I am at the 400 hrs mark, time to change fluid for the first time. I have a hoe that stays on and only comes off with the snow. My issue is where to add the new fluid. Looks like the hoe return line must be removed to add fluid. Are there any other spots or do I have to remove the return quick disconnect to add the fluid?
/ where to do hydro oil #2
The Hoe return line is the fill port.
/ where to do hydro oil #3
Say what? My hoe's hydro lines plug into the two remote connectors. I have a separate fill spot at the rear. :confused3:
/ where to do hydro oil #4
Yea, theres a kit supplied to the dealers that comes with the backhoe attachment, some dealers apparently think they know more than Kioti and don't install them.
Depending on how many backhoes your dealer has sold, he probably has the kits stacked up like cordwood.
There is a vent tube that gets installed in place of the little plastic plug that is up and to the left of the PTO shaft.
Then there is another fitting that replaces the fill plug for the HYD, the return on the Backhoe gets plugged into that.
My hoe was lacking power, it has more power since the kit was installed, and the hyd fluid stays cooler.
It clearly shows the kit in the owners book for the Hoe, sect. 13-4
/ where to do hydro oil #5
Your Backhoe would run cooler and stronger if it was plumbed right.
/ where to do hydro oil #7
Stronger is good and who doesn't want to be cooler. :cool2: I'm in!
Tell your dealer you want the kit your BH came with.
/ where to do hydro oil #8
I'll give him a call on Monday, thanks for the info on this. :thumbsup: Is this something he needs to put on or can I do this at home?
/ where to do hydro oil #9
You can do it easily, If you have a hard time [which I doub't] I'll take photo's.
/ where to do hydro oil #10
2 things: the new vent goes where there is a bolt, not a plastic screw (at least in my case) and I did not find myself having any more power than before.
/ where to do hydro oil #12
Mine was a red plastic threaded plug..charcoal paint over it...mine was bad to the point the bucket would get stuck in the ground, to where I thought I was going to have to get off the hoe and move the tractor to get it out, apparently some units are affected worse that others.
To the OP, yes you have to take the fitting out of the hyd fill to add oil.
/ where to do hydro oil #13
Ah yes I remember your thread.
/ where to do hydro oil #14
Mine doesn't seem to have a strength problem, I had the 2475 hoe on the CK25 and the 2485 is more powerful, but it definately does run a little warm. The cylinders are hot to the touch. Don't remember the 7' hoe being that hot.
/ where to do hydro oil #15
I checked my manual and confirmed that I do not have the in-out hose kit (page 13-4) installed. My KB2485 is hooked up to both remote lines, rather than having the return (white) line installed on the fille port.
Before I take this up with my dealer, please help me understand how the installation indicated in the manual is better from a power and heat standpoint. It seems to me like a return, any return, into the on-board hydro system would work the same, but I am ignorant when it comes to hydraulics, so I want to make sure I am well informed when I ask him to correct it.
/ where to do hydro oil #16
It stops the return under pressure so I'm told by the service guy.
/ where to do hydro oil #17
After I found out about this kit the other day, I called my dealer and he said that most dealers dont use the kit here because of the filler being "not as accessible", but has used it if the customer complains about loss of power or overheating oil.
Apparently, the return through the QD is a smaller pipe and therefore restricts the flow to the sump, causing slower fluid flow and hotter fluid. He offered to give me a kit if I want it.
One question, the A/B lever in the cab is designed to reverse the flow to the QD's if you hook them up backwards. I assume that function would no longer work if I use the kit.
/ where to do hydro oil #18
One would think the factory could put a T in that return line, Sure would make it easier when fluid needs to be added :rolleyes:
/ where to do hydro oil #19
True, You need to use either A or B as your power plug
/ where to do hydro oil #20
I contacted my dealer and he is sending me that parts.
He said that his mechanic had run into some issues with having to tap the filler neck to get the fitting to work, and was worried about getting metal chips into the hydro system, so he started omitting the return kit. Never had anyone complain. Either way, I am going to install it. If I have to tap the filler neck, I will wait until I am doing the 50hr service and deal with the prospects of metal chips then.
Hydraulic Auger Bits (A61572)
Hydraulic Auger...
WACKER NEUSON LTW20 LIGHT PLANT (A63569)
WACKER NEUSON...
2006 JOHN DEERE 160C LC EXCAVATOR (A64279)
2006 JOHN DEERE...
10ft Cattle Panels (A64047)
10ft Cattle Panels...
2019 Chevrolet Silverado 1500 Crew Cab 4X4 Pickup Truck (A60352)
2019 Chevrolet...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
