Coyote machine
Super Member
- Joined
- May 4, 2009
- Messages
- 7,663
- Location
- Southern VT
- Tractor
- 22 SANY SY 50U, '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 BB, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Brush Mower. Diamondplate aluminum canopy
Before you go moving and rerouting allow me to suggest you map out which goes where now, before you disconnect anything from one of those female ports. Use colored tape, zip ties, a combo of both, but save yourself now by taking a little time to map it out. You may find that you have to have some hose lengths made up to allow you to reroute some lines to the other side of your frame and up and around to get the angle you need to have. You might have to add a QD or two in a couple of places to get the length you need overall, or as you mentioned you might have to shorten a hose and refit the end to make a good fit. Time spent now will save big time in the long run.:thumbsup:
Not to worry, you'll get it the way you want it before long.
