Moving Tractor Long Distance
/ Moving Tractor Long Distance
Thanks Tim, good info. The distance is actually approx. 400 miles one way as we live in the far Eastern part of Ontario and Southern Maine is about a 6.5 hr drive so it's definitely doable myself by renting. I just need to check all the options and determine what works for me and what doesn't. Doing it myself I prefer as I would just take my time on the drive and could also bring down a few other things along the way.
/ Moving Tractor Long Distance #22
Just check with the Canadian Border Services and especially the American Border Services to see what they want from you to import the tractor to the U.S.
Should be little on the Cdn side but the Americans may want a whole bunch of stuff re liens, emissions, etc so you should give them a shout to see.
Most Cdns on here import from the U.S to Canada and few export to the U.S.
Good luck on the move and transitioning your equipment to the U.S.
/ Moving Tractor Long Distance #23
/ Moving Tractor Long Distance #25
I've a got a buddy who bought an anitque tractor in Canada and brought it back to the US. His biggest worry was making sure all the dirt was off. For some reason customs checks this closely. He power washed the tractor before crossing the border.
Wedge
/ Moving Tractor Long Distance #26
No doubt for the same reason they ask passengers at the airport whether they have been to a cow pasture. Disease control of some sort one would think.
Terry
/ Moving Tractor Long Distance #27
Terry
Or weeds...
/ Moving Tractor Long Distance #28
I've had a tractor moved about 400 miles and an old IH 2-bottom plow moved about 1700 miles. No problems. I found the shipper for the plow on uShip. The tractor was moved by a hotshotter who specializes in hauling tractors up and down the West Coast. Prices and delivery were reasonable both times.
"Shipping Wars" is entertainment. The bozos on that show are the customers who don't have a clue or actually lie about the size and weigh of the shipment, don't have the proper equipment and personnel to load and unload heavy and bulky stuff that can't be rolled off the trailer, and otherwise act like jerks. And the two gal shippers are both pretty babealicious:thumbsup:
/ Moving Tractor Long Distance #29
A Nissan Frontier has a rated towing capacity of 6500lbs, MX5100 weights 3500... what the problem? You could likely buy a decent enough used lightweight ~5000lb trailer for not much more than the cost of shipping it and still be well under 6500lb. Sell the trailer when you get there.
That said, the going prices for Kubotas seem to be higher in Canada than in the US (at least in BC). You might be able to sell it and buy another one possibly coming out ahead, and as a bonus having the option to downsize to a smaller model for the smaller properly in the process.
/ Moving Tractor Long Distance #30
Generally you can move a piece of equipment for around $1/mile on long hauls if they can fill a load (semi). I shad my Kubota shipped from Tennessee to South Dakota for around $900 and the trucker only received $600. The load broker got the other $300. If you know any truckers, talk wit them direct.
That is true about the Frontier however the MX5100 weighs 3500-3700lbs + BH92 at 1800lbs put it at around 5300-5500lbs and that I believe is too much along with a decent trailer for the Frontier.
What I could though is remove the BH and transport the tractor alone and then do a second trip for the BH, BB, snowblower, etc. So I might just look around for a used trailer!
/ Moving Tractor Long Distance #32
That doesn't include the 1100 (it might even be 1300?) pounds of the front end loader. Are your rears filled? That's another thousand or so pounds. Tractor weights add up quickly :)
Agreed tractor weight does add up very quickly. Nope, tires are not filled and I had thought of removing the loader for transport so would only have the tractor on the trailer and then would do a second trip with BH, loader, BB, blower and bushhog. Still trying to determine the best solution though as renting a moving truck along with a car hauler trailer would be best as then there is no worries with the weight.
/ Moving Tractor Long Distance #34
I use uship all the time . its free to put up a listing. try and see , you will get quotes from brokers the a few independants will bid and be cheap. I just had bids to move a deere 5300 fom chicago to north carolina 715 miles for a total cost of $660 offer was only good for 24 hours as the trucker wanted to fill a space .just look at there feedback and be ready to commit when you get a price your happy with if you wait to see if it gets cheaper you may loose a good shipper at a fair price
2013 PETERBILT 367 (A65643)
2013 PETERBILT 367...
Titan Hydraulic Hay Bale Handler (A62613)
Titan Hydraulic...
Case 1150G Dozer (A66285)
Case 1150G Dozer...
REMINGTON ELECTRIC POLE SAW (A62613)
REMINGTON ELECTRIC...
2018 CATERPILLAR 573D FELLER BUNCHER (A62129)
2018 CATERPILLAR...
Speed Trailer (A64194)
