The Only Down Side To Having A Cab...
/ The Only Down Side To Having A Cab... #1
Utopia Texas
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I love the ac when it is hot. I love the heat when it is cold. Love not having dust and chaf covering me from head to toe. Love the am/fm/cd stereo. I love being able to do tasks in the rain without getting wet. So what's the problem? I have 300 mature pecan trees in the orchard with lower limbs that hang down lower than the top of the cab. I have a lot of trimming to do the Winter...:(
/ The Only Down Side To Having A Cab... #2
Oh a couple of lower limbs to trim:D well worth it for the comfort of having the cab me thinks???:thumbsup:
/ The Only Down Side To Having A Cab... #3
I don't like not having windows and being forced to run some sort of air. It would be great if the doors came off easily.
The whole rear glass on my unit tilts open from the bottom so outside air is easily available though it's not like having a cross flow type breeze.
/ The Only Down Side To Having A Cab... #5
Ever consider a boom or sickle bar mower to reach under the trees? I'd hate to take all the easy to reach branches out of my orchard.
/ The Only Down Side To Having A Cab... #6
Being stuck in an office job all day I kind of enjoy being out in the elements on my open station tractor. But yeah, if I had to make a living with my tractor the cab would be nice.
I've been working outside for the past 42 years and have had 35-40 pre-cancer and 2 cancer spots removed from my skin though I covered up a lot in the past. Having a enclosed cab now may be too late for me but I plan to enjoy it as much as possible as long as possible. :)
The trees are at 70 feet tall and 60 feet across. Due to the shading from the branches above the lower branches haven't had any production for a lot of years. None are very large around but it's going to be a lot of work to trim. I will probably use one height of scaffolding in a flat bed trailer so someone can ride on the scaffolding easily with chain saw and hand clippers with the whole set up pulled slowly with a tractor. No chain sawing from a FEL like we used to do years ago. Though the irrigation ditches that the rows of trees sit in have filled in over the years they are still too deep to use a sickle bar mower and make the cut look neat and tidy. Maybe it's time for a larger zero turn mower.
/ The Only Down Side To Having A Cab... #9
So does mine but as you state no cross breeze. I'm also fearful of having my back exposed to a sneak attack from bees so I never just leave it open.
Well, One can always run the fan without the ac compressor running to just introduce fresh air into the cab, but no, it's not like driving a regular tractor totally outside. I should not complain as I have always wanted a enclosed cab and finally have one. I was out at 4 am this morning picking up huge limbs with my skid loader with hydraulic "Hand" while running the ac and listening to Bon Jove on the radio. Life is good! The humidity is so high here on the Texas Gulf Coast I left a puddle of condensate on the barn floor when I backed in and parked. At first I thought it was a hydraulic leak until I found he drain hose from the ac unit. It needs to be extended as it drips on top the rear axle...
/ The Only Down Side To Having A Cab... #11
The only downside to having a cab, hmmm, wouldn't it be that everyone else wants to run your machine?
/ The Only Down Side To Having A Cab... #12
I bought one of those Echo "chainsaws on a stick" and I can walk along and trim most offending limbs from the safety of the ground. I also have a longer pole saw for those limbs that start higher and grow down. Scaffolding in a truck bed with somebody perched on top with a chainsaw is a perfect example of "sounded like a good idea at the time" that has a distinct possibility of going bad. But hey, I'm getting old and have lost a lot of my sense of adventure.....
/ The Only Down Side To Having A Cab... #13
If the scaffolding is secured a bit, strapped or whatever, to the wagon bed (not truck bed, so it makes all the difference :laughing:) I would do it. The wagon would catch most of the trimmings too and save a lot of picking up.
Ideally, someone would ride the wagon bed and stack the trimmings, plus pass fresh beers to the saw operator. :laughing:
/ The Only Down Side To Having A Cab... #14
I like my cab but getting in and out to open and close gates can be a pain after a while. I'm not as nimble as I used to be.
/ The Only Down Side To Having A Cab... #16
I was just the opposite, working in office most of the time and want to still be cool when on my tractor. My problem is that most of my work is with my B26 TLB and no cab on it.
/ The Only Down Side To Having A Cab... #17
That and on LS P7010, it has a special locking mechanism that folds out about 3-4" so you can lock the doors in a slightly open position for free air movement if you don't want to run the heat or AC.
/ The Only Down Side To Having A Cab... #18
I feel your pain.Just don,t have the grit in my ***** like I use to.LOL
/ The Only Down Side To Having A Cab... #20
Gary, that is a VERY good idea!
2008 Sterling L7500 Series T/A Vactor 2115-824 Combination Sewer Jetter Vacuum Truck (A66736)
2008 Sterling...
2019 FREIGHTLINER M2 4X2 S/A 26FT BOX TRUCK (A69167)
2019 FREIGHTLINER...
FOUR RACKS OF MISC FILTERS (A68842)
FOUR RACKS OF MISC...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2014 Dodge Grand Caravan Van (A66738)
2014 Dodge Grand...
2023 JOHN DEERE 35P EXCAVATOR (A65056)
2023 JOHN DEERE...
