Advice On First Kubota Purchase
/ Advice On First Kubota Purchase #1
mopac01
Member
Kansas City
Kubota L3200HST
I've decided I've had enough of my 1942 2N. I have 5 acres with a half dozen scattered trees, a small "stand" of 10-12 trees along a "creek" that only flows when it rains hard, a septic pond and an "ornamental" pond about 2-3 times the size of the septic pond. The 2N was fine for pulling the brush hog when all I had was empty pasture. It pulled a small plow once in a blue moon for my wife's 25'x25' vegetable garden and once a year or so ran a post hole digger. Well, that's when the 2N would start that is. It always seems like I have a problem with it just when I want to use it. I'm tired of spending more time next to it than on it. I want something that "just works."
2 years ago we fenced the property into 3 separate pastures, put up a 36x36 monitor barn (with hay loft) and added 3 horses and a dozen chickens to the mix. The house sits 50' from the road so my gravel driveway is very short at 80' feet or so to the rear of the house. It needs some maintenance from time to time, but not much. I can find uses for the FEL. I've wished I had one on quite a few occasions when getting a load of dirt or gravel out of the back of my F150.
I think I could probably get by with a large B but the L seems so much stouter. The 3800 adds $1,500 to the cost and I'm just not sure if the L3200 isn't already meeting the "figure out the size you need and then go one bigger" maxum.
So I'd like comments on whether for my needs I'd really ever use the extra 5 horses. I don't plan on ever buying another property or another tractor.
I'm considering getting a rear blade, box blade, 5' brush cutter. Any recommendations on specific Land Pride models would also be welcome. I can get a good deal on any of the Land Pride stuff I buy with the tractor.
/ Advice On First Kubota Purchase #2
I never planned on buying another Tractor either. Now I own 3.:eek:
/ Advice On First Kubota Purchase #3
The largest B model is at least 10 HP larger than your 2N IIRC they had 19 HP so I think that a B 2920 or similar would be plenty of tractor for your needs and it would save you a few thousand in initial cost. I am constantly surprised at what my little B 26 TLB does with its 26 engine HP. The B series are nimble enough to get into the smallest of places also.
/ Advice On First Kubota Purchase #4
I have L3200 2wd gear and tractor has way more power than traction with ag tires. Only regret is pto not live.
/ Advice On First Kubota Purchase #5
mopac01,
You mention needing a 5' brush cutter. To me that says live pto. In order to get live pto you have to get a hydro transmission on the L3200, where live pto is standard on a gear drive L3800. The price between the hydro L3200 and Gear L3800 starts narrowing.
/ Advice On First Kubota Purchase #6
Welcome aboard. I had a B7500/HST/FEL/R4's for 10 years. I loved everything about it except for occasionally wanting more weight and more horses. It had a Landpride 5' RFM and that was really max for it due to the weight. Last year the B was replaced with an L3200 equipped the same except the L has a 6' Landpride RFM. For me it's ideal. Plenty of power, more comfortable to operate and the FEL is more capable. The front axle on the L series makes the B look more like a lawn mower. My brother-in-law has borrowed both Kubotas and remarked that the L is a lot more beefy. The L3200 breezes along in 3rd range mowing in places where the B7500 struggled.
We have had the original 2-1/2 acres in mostly grass, plus anywhere between 1/2 and 5 acres of additional offsite mowing since building in 1989. We're in the process of prepping for another 1-1/3 acres of grass on an adjoining piece of land we bought. Obstacles include a couple of sheds, some trees, a creek and a few other things. Snow can range from nothing all winter to a few decent snows here. The main driveway is 100 yards long and we have neighbors close enough to drive to and take care of their driveways.
mopac01,
I had a dealer with only 3800s and no 3200s try to tell me the PTO wasn't live on the 3200 but was on the 3800. When I said I was pretty sure that was correct if he was talking geared tranny but that I thought PTO mechanicals where identical between a 3800 and 3200 with HST he said he'd have to look into that.
I'm not sure a dealer I have to educate on the differences in his offerings is worth dealing with.
mopac01,
Thanks for that observation. However, I'm sold on the HST for ease of use - particularly as it would make the unit more "approachable" for my wife to use in some of her gardening activities. So I don't want to get 5 horses at the "cost" of forgoing HST
/ Advice On First Kubota Purchase #9
Welcome aboard, I'd say either will work for you but I would lean towards the larger one as your needs may change later on. Another thought is physical size of the operator. I found a L3200 was too small for me to be comfortable on while bush hogging. I had spent yrs on Ford N's and 600 series and well as my MF35 so I wanted something similar in size. I found a L5740 which is the largest chassis in the compact series and it works for me. Get the FEL you will never know how you got along without it. I have picked up a set of pallet forks and find I use them more than the bucket. Try to find a Tier III machine
Check with Barlows in Somerset KY they seem to be able to beat most local dealers on prices. Lastly ask if they have any "old" stock available around anywhere, That is how I got my L5740 it was brand new but a 08 I bought in Sept 2011....big discount.
/ Advice On First Kubota Purchase #10
I have 400 hours on Kubota B3300SU, tractor/loader package, largest of the Bs. Very fine machine. Power has been fine but there have been occasions when I wish I had more weight.
The L series are stouter. I think about 600 pounds heavier.
If you can afford it go with L3800/4-WD.
You've keep the Ford operating for 70 years.....the additional $1,800 will be like three cents per week.
With Kubota you will be able to get parts easily until you have worn the L3800 out, probably during the NEXT century.
/ Advice On First Kubota Purchase #11
For HST, there is no difference other than power between the L3800 and L3200, and either will pull a 5' bushhog through a pasture with ease.
I would be looking at the L and NOT the B. Since you are used to the n. Physical size and weight wise, the L is nearly the same. And nearly the same pulling ability. Not trying to insult the B, as it is a good tractor, but compared to your N, It would feel small.
/ Advice On First Kubota Purchase #12
Get the HST, you will not regret it, and if you can swing it, you should get the SSQA bucket. You might want some pallet forks later.. very handy. Also you can buy or make many other SSQA attachments for your Front End Loader. If you ever think you would want these things, now is the time to buy, it is much cheaper to do it now than later.. I know..
James K0UA
/ Advice On First Kubota Purchase #13
Really either a larger B or the L will be OK on your property, but be sure to spend as much time as possible on both before buying. I won't buy another tractor without position control 3PH which many of the B's don't have and the price of the ones with it get pretty close to the cost of an L. I tried an L out and found the work platform to be a little awkward to get onto and off and didn't like the bump in the middle, overall ergonomics just weren't right overall. What bothers one another will like so fit the machine to you. I wound up with a Grand L, but that is going to really cost you, so spend some time on those you mentioned and see which fits you the best and go from there. Both are good tractors with lots of happy owners.
Between the L3200 and 3800 my choice would be the 3800 for the reasons mentioned.
TripleR - what part of Missouri are you in? I'm now just outside KC, but grew up in St. Louis.
I've never looked forward to getting on my N. Partly because I had to mow with my hand on the hydrolic lever since the slightest difference in engine RPM going uphill vs downhill would change the height of the mower. With the engine off the mower IMMEDIATELY started to drop. I also never looked forward to going out there because at least once a summer it wouldn't start for one reason or another. It's not that it wasn't repairable, but my time is limited with 4 kids, a time intensive summer work schedule and when I had time for a project I wanted it to be the intended project and not another "tractor project." And let's not forget that if I got the mower stuck I couldn't raise the hydrolics without disconnecting the PTO shaft first. I can honestly say I won't miss the N and would get some satisfaction with simply putting it in neutral and pointing it at the pond were it not for the environmental damage to the pond.
I've noticed the Grand L and an earlier poster who suggested an even larger Kubota. But for 5 acres that are "finished" and just need to be maintained and a firm resolve for my next move to be in a pine box I think anything larger than an L3200 or L3800 is going to be a lot like swatting flies with a sledge hammer or getting a 16' double axle trailer to haul a push mower.
/ Advice On First Kubota Purchase #15
I live in what is often referred to as "Swampeast Missouri" as it was almost all swampland prior to the Little River Drainage District drain most of it turning it into fertile farmland. I lived and worked in KCMO my first year and a half on my job beginning in 1975, office was at 615 E. 13th Street, I lived one block in the city limits up at Claycomo and spent my spare time riding my bike through the countryside. I imagine it has all been swallowed up by now.
Picking just the right size tractor can be confusing, one time I went shopping convinced I needed a B2920 and came home with a BX2660, another time I went to buy a B3200 or L3400 and came home with an L5030.:laughing:
I can identify with your Ford N to some degree as for many years my only tractor was a Ford NAA, never knew when it would start or I would have to walk home in the middle of a job.
You might want to introduce yourself here: http://www.tractorbynet.com/forums/midwest-great-lakes/228416-missouri-roll-call-show-me.html
/ Advice On First Kubota Purchase #16
The "Grand L" L3560 is not larger. It has HST+ transmission, spacious cockpit, pin adjustable stabilizers and telescoping lower links, which, in combination, make hooking up implements a breeze; its quieter and another 700 pounds over the "regular" L series.
My dream.
http://www.kubota.com/product/L60/lineup.aspx
/ Advice On First Kubota Purchase #17
Brings back memories. I'm 63 and for 30 or so years, did a lot of work with my old 2N, no loader, no live pto. Raised 3 kids that had horses, built 2 barns, lots of fencing, manure spreading, brush hogging, rear finish mower, snow plowing, plowing gardens, pulling an old disk that was too big, etc.
Got divorced 12 years ago and sold everything.
About 2 years ago, I bought a B2620 with loader and a 60" belly mower. I added a rear blade, a 5' rear snow blower and 4' tiller, bought an old 4' brush hog and just recently bought a post hole digger.
I was going to buy a B2920 but found a good deal on a used B2620 (3 horspower difference).
I am so happy to have an HST, loader and a pto I can shut off independent of the 3 point lift. This thing is awesome. For what work you describe and amount of acreage, I think the B2920 would work fine for you.
But I agree, get on the platforms, test drive them and then make your decision. But any of the models you mentioned will be so much better than the 70 year old technology you have been using. And you can get some money out of the old N.
/ Advice On First Kubota Purchase #18
Also, just ordered a set of telescoping stabilizer arms to replace the turnbuckle stabilizers that come with the B2620. from Mark Hodge StabilWorks Cost was $167. I'm also considering getting Pat's Easy Change system for the 2 lower links.
I want to make it easier to change implements in my old age and some of my implements are pretty heavy.
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
2019 Ford E-450 Shuttle Bus (A61568)
2019 Ford E-450...
New/Unused 2025 CFG QK18R Mini Excavator (A61166)
New/Unused 2025...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
Kubota SVL 75-2 (A60462)
Kubota SVL 75-2...
2019 Ford F-550 4x4 Dur-A-Lift DTAXS39 39ft. Bucket Truck (A60352)
2019 Ford F-550...
