Farmall 806 3 Point
/ Farmall 806 3 Point #1
leader58
Can anyone help me adjust the drop rate of the 3 point on an 806 Farmall? Thanks
/ Farmall 806 3 Point #2
Are you wanting it so speed up or slow down? Are you familiar with the draft control?
I have a large rotary rake on it and when you lower it it falls like a rock. I need it to go down slower. Draft does not change this. Thanks
/ Farmall 806 3 Point #4
Do you not have a descent control knob under the seat ?
This knob is turned in to decrease the drop speed. and turned all the way in to lock for transport.
No Knob
/ Farmall 806 3 Point #7
It may be a T handle, or something similar, but I believe almost every tractor has a control to change the descent speed.
/ Farmall 806 3 Point #8
I inherited an old 706...i don't recall ever seeing a rate descent control knob like is on my Kubota.
I am pretty sure it's all tied into the draft control system. The draft control is the outer lever, next to your 3pt control. Fully forward should be off, then it goes from light load to heavy.
I suspect if operating your draft control isn't making any difference, you will need to rebuild the draft control valve. Perhaps there is an adjustment on the valve itself (not sure).
http://partstore.caseih.com/us/parts-search.html#epc::model_find
You should see a link to IH tractor parts - here you can pull up a parts schematic and see what's what. Since I am on my iPhone, I can't load the pages..but I have used this site in the past to troubleshoot (and order parts). Hope this helps.
NOTE: I edited my parts link..for some reason my local supplier's parts link no longers works...but this one does!
2010 Acura MDX AWD SUV (A61574)
2010 Acura MDX AWD...
2006 Sea Ray Sundancer 31ft Boat w/ Loadmaster 28ft Tri-Axle Boat Trailer (A61574)
2006 Sea Ray...
1997 Duraco Dura Patcher 81DJ Towable Asphalt Patcher (A64194)
1997 Duraco Dura...
(2) John Deere Row Markers (A60462)
(2) John Deere Row...
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
