How to remove carbon from piston
/ How to remove carbon from piston #1
whynot162
Amboy WA
Rhino 324
So I have this tractor apart now, one set of rings is stuck. So I am going to remove and replace them. How do I get the carbon out of the grooves? using a broken ring is not doing much.
do I also need to clean it from the piston, or just leave it?
thanks
Doug
/ How to remove carbon from piston #2
There is a grove tool for cleaning that out. Wire wheel the top.
Thanks, I will see if the local parts store rents one, or sells one.
Thanks, I got it mostly clean. No big deposits of carbon. But there were some stuck rings. Now the rings go on, and move freely, so I think I am ready to put it back in.
got the new liners in last night, still waiting on the head to be checked.
/ How to remove carbon from piston #7
Soaking in Diesel fuel will also soften carbon deposits...
Thanks, I will try that and finish up getting the rings on and the pistons into the engine, hopefully tonight after work...
/ How to remove carbon from piston #10
A word of caution on using oven cleaner on aluminum pistons. Most oven cleaners are some sort of caustic solution and will etch aluminum fairly rapidly, so don't leave it for long and be sure to rise it thoroughly and neutralize it with a dip in vinegar, followed by another rinse. I have used oven cleaner to etch aluminum to make artistic plaques and such as itis somewhat safer than acid and easier to get anywhere.
Got them back in and realized that I did not order Rod bearings:eek::banghead:
And Farmboys tractor is out on vacation! It was going so well and I was going to have it running this weekend
/ How to remove carbon from piston #13
Berrymans Chemtool B12.. soak a day or two. Cleans the combustion chambers too..
yes, a good job someitimes takes longer. But the "forgetful" moments seem to multiply as I get more vintage.
2007 Polar Dot 407 Insulated T/A Chemical Tanker Trailer (A64194)
2007 Polar Dot 407...
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
2020 BROWN AND HUBERT 10' SPOOL TRAILER (A63276)
2020 BROWN AND...
2023 CATERPILLAR 262D3 SKID STEER (A65053)
2023 CATERPILLAR...
SUPER C 12' BOX BLADE (A64278)
SUPER C 12' BOX...
Bainbridge,Georgia (A65640)
Bainbridge,Georgia...
