Ford 3000 starter troubles
/ Ford 3000 starter troubles #1
mtk51
Member
Bobcat 863
We have a '65 Ford 3000 diesel that seems to go through a starter motor about once a year.
It is used to pull the manure spreader through a stable, stopping in front of each stall to clean the stall, so the starter does get a lot of use.
However, I pulled the cover off he solenoid on the starter and it appears to be fully extending without the starter gear meshing with the ring gear.
The edges of the ring gear teeth are pretty banged up, but no other wear patter is visible on the teeth.
Could the starter "nose" be too short?
Pictures doesn't upload correctly. Seems to be upside down and distorted. Oh well.
/ Ford 3000 starter troubles #2
Those teeth don't look too bad. Did you have the starter out to check the throw?
Jim
/ Ford 3000 starter troubles #3
That's a direct drive starter. It takes a BUNCH of amperage to turn it. Have you tested the battery? Are the cables and terminals in good shape?
I don't know how many of these starters have been fried by someone buying a "car" battery instead of the 4DLT that's supposed to be on there, or by someone "repairing" a cable by using an automotive replacement terminal.
The tractor had a car battery in it when we bought it three years ago. This is the 3rd starter to fail. I'll get the correct battery and check all the cables?
Think the starter is ruined? Maybe I'll put it back in and see if it works.
Going out to the farm today to measure the throw and distance to the ring gear.
Thanks for the information.
/ Ford 3000 starter troubles #5
Dont know if you need the 4dlt size (its is a size), but you should have a good 900 cca battery with good capacity and good starter cable. Some places sell low strand count 4 gauge that is no good. Should be high strand, or 2ga or bigger.
/ Ford 3000 starter troubles #6
There's a difference. I'm no electrical engineer, but IIRC, the 4DLT is only about a 850 CCA battery. You can put a 1000 CCA battery in that tractor, and it still won't be the same. Yes, a 4DLT is an expensive battery, but it doesn't cost half as much as the starter.
And, I'm not positive, but I think those battery cables may be a 1/0. And be sure to get a cable with a terminal that is either molded in or soldered. The little rinky-dink clamp-on terminals won't carry the amperage required.
/ Ford 3000 starter troubles #7
Wasnt sure about size.. I mine is a high strand 2ga from my BIL's work. Almost as fine a strand as welding cable :)
Agree about the ends..
The 4dlt is a big batt with a larger capacity.. the amps are the same.
/ Ford 3000 starter troubles #8
in 1965 the ford branded starter use an external solenoid you have not mentioned it. this must work properly for starter engagement also you can upgrade to new planetary gear style with solenoid attached will also help solve this problem post what city you are near can put you in touch with rebuilder who can supply this starter also there were 2 starters used in this year one for automatic trans on with manual difference being drive throw distance to flywheel
/ Ford 3000 starter troubles #9
heck.. the 4dlt is half the tractor ballast too! ;)
I made a mistake in my original listing. The tractor is not a diesel.
Looks like the AGRI FORCE 917TF is the size I need. The 4D is too big for the battery tray.
Just checked the serial number. Bought a newer tractor than the guy told me. Checks out as a 69.
Anyone know if the '65 and '69 used the same starter motor? I'm pretty sure the one in it is for a '65.
Anyway, this battery is getting replaced.
I'm in Minneapolis, MN
As noted in my other corrections, it is a '69 3-cyl GAS engine.
Today, I attempted to measure the distance from the mounting face to the ring gear and compare it to the starter motor throw. Bad light, flash light dead, trouble light burnt out and too many other things to take care of.
This tractor is a 5-speed manual transmission with high/low.
Did notice that the ground cable runs to the 1/4" bolt that holds the solenoid to its bracket. Going to get new cables and attach the ground to one of the starter motor bolts. Also getting a new solenoid.
My wife manages a boarding stable and I get out after work and on weekends to try keep things fixed. Always interesting.
/ Ford 3000 starter troubles #13
5spd trannies were on the previous 55-64 models.. not the 65+ models. and 5spds did not have high / low.
suggest you re-double your efforts to correctly ID what tractor, you have with respect to engine and fuel type.. and model and tranny.
that said. I see 1 starter for your gas tractor..
Good grief, I need to stop trying to post messages when I'm tired. Also have a starter motor out on a Farmall H. That one is the 5-speed.
An entertaining side note, the starter also went out on my wife's VW Jetta while at the farm. We are beginning to suspect aliens.
The Ford is an 8 speed (4 speed with high/low), gas, 1969, power steering.
I checked the serial number.
/ Ford 3000 starter troubles #15
ok here goes by application 1969 with ford branded starter the ford number is c5nf11001b fits ford motor 3-158 parts store may recognize part number 3139 which is a lester number as stated earlier there is a solenoid activated planetary gear starter available also will post later the number for it
/ Ford 3000 starter troubles #16
yep...pretty common starter..
2013 INTERNATIONAL DURASTAR 4300 M7 SWEEPER TRUCK (A63276)
2013 INTERNATIONAL...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
2015 VANTAGE TRAILER (A65054)
2015 VANTAGE...
2023 CHEVROLET W5500 4X2 S/A 16FT FLOOR TRUCK (A67148)
2023 CHEVROLET...
1999 INTERNATIONAL 4700 - 6 WHEEL GRAIN TRUCK (A64278)
1999 INTERNATIONAL...
2022 Mack Pinnacle T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Mack Pinnacle...
