RCK 54BX Deck will not rotate
/ RCK 54BX Deck will not rotate #1
snpower
Gold Member
Charlottesville, Virginia
John Deere GT235, GT 275, 1025R
My wife... 'nuff said.
No, really - my wife let my buddy next door use my 2360 whilst I was away, to do some digging and raking. Now the mower deck will not rotate at all either by hand turning the spindle or the center blade. I have loosened the belt and cleaned all of the junk he covered the deck with, to no avail. There is gear oil in the box - maybe a tad low.
What can I, and should I do/check? I'm on the road for ten days starting tomorrow, so my lack of a thanks or reply does not mean I am not interested in what you might have to say!
/ RCK 54BX Deck will not rotate #2
We have 72" version of this deck so assume that 54" is still 3 blades? First thing I would do is remove belt so you can check individual blade spindles. Then you might try unhooking the mid PTO. That would isolate your problem to one of the spindles or issue with mid PTO.
Good luck.
Should have mentioned - the deck is OFF the tractor. :) Yes, it is 3-blades.
Good luck.
/ RCK 54BX Deck will not rotate #4
If you take the belt completely off, do the outer two spindles turn free? What about center one under gear box?
/ RCK 54BX Deck will not rotate #6
You've probably already checked this, but there may be a thin wire or rag caught up in the spindle above the blade. I've had it happen to me.
/ RCK 54BX Deck will not rotate #7
That's not good. With belt still off what happens when you try to turn the PTO shaft? You you get any rotation at all or is it completely locked up?
Think you might need to get the gear box off of the center spindle to isolate if problem is center spindle or in gear box.
Assume that, with deck off of tractor, the mid PTO now will turn?
/ RCK 54BX Deck will not rotate #8
Pull the centre blade.
Make sure the dust cap (the fez looking thing under the blade) isnt rusted or otherwise jambing things up. Try and rotate with the cap off.
If that fails your likely looking at a siezed bearing somewhere in the centre gearbox/spindle.
/ RCK 54BX Deck will not rotate #9
If the gear box has oil in it I can't imagine it locking up all at once.
Make sure nothing is wrapped around the spindle or under the pulley.
/ RCK 54BX Deck will not rotate #10
As others have said, I would pull the center blade, then see what moves after that.
Aaron Z
/ RCK 54BX Deck will not rotate #11
... my wife let my buddy next door use my 2360 whilst I was away, to do some digging and raking...
But not any mowing. Seems odd the gearbox would just coincidentally let go due to internal failure right when your neighbor used the tractor for some dirt work without taking the deck off. You have to wonder if he drove over something like a rock or a curb and bashed the heck out of the center blade or spindle. Maybe I'm the only one who thinks this way, but dragging that nice expensive deck around while moving, scraping and levelling dirt just never seemed prudent.
Problem Solved!
Yep there was indeed an object struck with the deck. Center shroud around the blade /spindle was bent inward enough to just catch that blade. I hammered it out and we are good. Can't believe I didn't check that earlier. So no more lending it out when I'm not in town!
/ RCK 54BX Deck will not rotate #13
That got hit HARD then. We have used the decks on our B7500 and BX2660 for mowing some nasty stuff but have yet to bend the deck...
Aaron Z
/ RCK 54BX Deck will not rotate #14
Aaron Z
No kidding! My right front gauge wheel is bent in and down (previous owner). I put my little 6 ton jack in to straighten it and it springs right back to the bent position.
/ RCK 54BX Deck will not rotate #15
Have you tried heating after you get it to where you want it with the jack. Sometimes a little heat will remove the "Set".
/ RCK 54BX Deck will not rotate #16
I've only got a small propane torch, but yes I used it for about 20 minutes when it was stretched. It is better than when I started, but still not straight. I can't imagine what they hit and how hard. Must have stopped the tractor cold.
/ RCK 54BX Deck will not rotate #17
If it was hit hard enough to bend the deck in you probably need to check the rest of the mower suspension system to see if it got tweaked too. I am thinking mainly of the front hook ups as opposed the the lift arms. Look for obviously bent stuff and/or krinkled paint. I would go back through the deck and make sure you can still level it from side to side and front to back. I am so glad my wife does not loan out any of my tools.
Take Care,
Doug in SW IA
/ RCK 54BX Deck will not rotate #18
You need to jack it beyond were it needs to be so when it springs back it is where you want it.
Sent from my Samsung SPH-L710 using TractorByNet
/ RCK 54BX Deck will not rotate #19
That's why I like fabricated decks. They can take the abuse and keep going. I was cutting along a fence row on my Hustler and hit a cut off tree that stopped the mower in its tracks. No problem..just go around and no damage. This mower weighs more than a ton so it had some force. It seems pretty easy to bend the stamped MMM on my Bota.
Glad your problem wasn't too bad. I hate lending equipment out.
/ RCK 54BX Deck will not rotate #20
Well, sure the BX deck isn't made of 3/8" plate, but it's no flimsy thing either...it's a 250 lb deck, 'way more than what's on a residential mower. As a detachable implement on a multi-purpose machine, I figure it's pretty darn good... ours has held up well for 8 years. Besides, when we're digging in the dirt and rocks, we get more work done if we take 5 minutes and remove the deck first.
2023 Caterpillar 259D3 Compact Track Loader Skid Steer (A64194)
2023 Caterpillar...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
49" X 74" TAILGATE (A64280)
49" X 74" TAILGATE...
(2) RAM 7000 LB TRAILER JACKS (A64280)
(2) RAM 7000 LB...
Adams 16T Tender Body (A63688)
Adams 16T Tender...
UNUSED IRANCH IRGC40 HIGH END MINI GOLF CART (A64281)
UNUSED IRANCH...
