RCK 54BX Deck will not rotate
   / RCK 54BX Deck will not rotate #11
... my wife let my buddy next door use my 2360 whilst I was away, to do some digging and raking...
But not any mowing. Seems odd the gearbox would just coincidentally let go due to internal failure right when your neighbor used the tractor for some dirt work without taking the deck off. You have to wonder if he drove over something like a rock or a curb and bashed the heck out of the center blade or spindle. Maybe I'm the only one who thinks this way, but dragging that nice expensive deck around while moving, scraping and levelling dirt just never seemed prudent.
Problem Solved!
Yep there was indeed an object struck with the deck. Center shroud around the blade /spindle was bent inward enough to just catch that blade. I hammered it out and we are good. Can't believe I didn't check that earlier. So no more lending it out when I'm not in town!
   / RCK 54BX Deck will not rotate #13
That got hit HARD then. We have used the decks on our B7500 and BX2660 for mowing some nasty stuff but have yet to bend the deck...
Aaron Z
   / RCK 54BX Deck will not rotate #14
Aaron Z
No kidding! My right front gauge wheel is bent in and down (previous owner). I put my little 6 ton jack in to straighten it and it springs right back to the bent position.
   / RCK 54BX Deck will not rotate #15
Have you tried heating after you get it to where you want it with the jack. Sometimes a little heat will remove the "Set".
   / RCK 54BX Deck will not rotate #16
I've only got a small propane torch, but yes I used it for about 20 minutes when it was stretched. It is better than when I started, but still not straight. I can't imagine what they hit and how hard. Must have stopped the tractor cold.
   / RCK 54BX Deck will not rotate #17
If it was hit hard enough to bend the deck in you probably need to check the rest of the mower suspension system to see if it got tweaked too. I am thinking mainly of the front hook ups as opposed the the lift arms. Look for obviously bent stuff and/or krinkled paint. I would go back through the deck and make sure you can still level it from side to side and front to back. I am so glad my wife does not loan out any of my tools.
Take Care,
Doug in SW IA
   / RCK 54BX Deck will not rotate #18
You need to jack it beyond were it needs to be so when it springs back it is where you want it.
Sent from my Samsung SPH-L710 using TractorByNet
   / RCK 54BX Deck will not rotate #19
That's why I like fabricated decks. They can take the abuse and keep going. I was cutting along a fence row on my Hustler and hit a cut off tree that stopped the mower in its tracks. No problem..just go around and no damage. This mower weighs more than a ton so it had some force. It seems pretty easy to bend the stamped MMM on my Bota.
Glad your problem wasn't too bad. I hate lending equipment out.
   / RCK 54BX Deck will not rotate #20
Well, sure the BX deck isn't made of 3/8" plate, but it's no flimsy thing either...it's a 250 lb deck, 'way more than what's on a residential mower. As a detachable implement on a multi-purpose machine, I figure it's pretty darn good... ours has held up well for 8 years. Besides, when we're digging in the dirt and rocks, we get more work done if we take 5 minutes and remove the deck first.
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2015 CATERPILLAR 745C 6X6 OFF ROAD DUMP TRUCK (A51242)
2015 CATERPILLAR...
TOPCAT SKID STEER QUICK ATTACH BRUSH CUTTER (A51244)
TOPCAT SKID STEER...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
2015 PETERBILT CLASS 8 CEMENT MIXER TRUCK (A51243)
2015 PETERBILT...
2021 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A52141)
2021 FREIGHTLINER...
