Thank you Tractorbynet
/ Thank you Tractorbynet #1
downsizingnow48
Elite Member
Sacramento, California
Kubota B21
I want to say thank you very much for the great information on trailering small tractors. I recently towed my Kubota B21 with implements from Virginia to California. Not my line of work, I had no idea about type/size/design of trailer or how to tie down the tractor and implements. Listening to local folks in Virginia I had a range of differing opinions. I studied your forums for several weeks to learn more. In the end I made the trip with absolutely no issues. The setup and load was scrutinized by passing highway patrol officers in 8 states. Here is what I used. Pickup is F150 Ecoboost with 3.55 gears, 7200 GVW, 1350 payload, 15500 GVCW, 9600 tow weight, P series tires @ 44lbs. Trailer is PJ 14k 20' equipment trailer with LRE tires @ 80lbs. Load is B21, scraper, tiller, bucket, tools etc. Total tow weight 8300. Used 4 of Lowes G70 5/16 chains, cutting them in half with abrasive saw to get 8 10ft pieces. Two chains crossing under the front, two chains on the rear, one on the hoe bucket, one on the loader bucket. Plus one on each implement. Used 6200 lb ratchet binders. I used a Sherline tongue weight scale and adjusted the load repeatedly to make sure I had 10%-12% tongue weight. Used an Equalizer 12k WD hitch. Traveling at speed limits up to a max of 70 mph had no issues with bounce or sway. Checked the chains about every 50-100 miles, they loosened up repeatedly during the first two days but after that were tight all the way. Again, big thanks to TBN for being an excellent source of expertise.
/ Thank you Tractorbynet #2
Welcome from NW Florida.
It looks like you did a great job of hauling. It's always better to err on the side of caution when tying down. Chain is cheaper than lost or busted equipment. Glad you made it.
That is a good looking rig you have there. If I didn't have so many trees, I would check into a cover for my B7500.
/ Thank you Tractorbynet #3
What kind of mileage did you get while towing and how does that contrast to regular highway mileage?
Regular highway mileage ranges from 17-18 mpg at 70-75mph to 20-21 mpg at 55-60 mph. On the trip daily mileage ranged from 10-12 mpg at 60-70 mph with overall average 10.7 mpg.
/ Thank you Tractorbynet #5
Welcome to the Sacra-tomato area. Only two hours to San Francisco to the West, two hours to Lake Tahoe to the East and two hours to Yosemite to the South.
/ Thank you Tractorbynet #6
Nice job. You have the perfect setup for that job.
Chris
/ Thank you Tractorbynet #7
NO NO NO! You did it all wrong. Taking all those precautions was a waste of time. Your suppose to use one of those trailers that's much to small, unbalance the load, use a couple of tie downs that are meant for a motor cycle, and your truck is too nice and new. Remember, trailer brakes are for girls. Heck, I even bet all your lights worked on the trailer.
On a more serious note, I'm glad the trip went well and you really did do a better job than 99% of the people towing stuff. I'm not saying its a waste of time though.
Thx for feedback. Someone on the forum makes a comment like this: if you are involved in an accident, and people are looking to assign liability, do you want the lead investigator to give you a list of the things wrong with your truck, trailer, and load? Or do you want them to say, this is in compliance with all federal and state requirements. That impressed me. An ounce of prevention etc.
/ Thank you Tractorbynet #9
I probably would have hauled it similar to what you did but I would have used ratchet straps for the end loader, I might not have done anything for the backhoe, and I would have eye balled the tongue weight.
On tongue weight, the F150 doesnt have much payload. And this was the first time using this trailer. So I wasnt sure I could correctly guesstimate the (narrow) sweet spot between enough tongue weight for the loaded trailer and too much for the loaded pickup. The limiting factor for this setup was pickup payload.
/ Thank you Tractorbynet #11
Pickup is F150 Ecoboost with 3.55 gears, 7200 GVW, 1350 payload, 15500 GVCW, 9600 tow weight, P series tires @ 44lbs. Load is B21, scraper, tiller, bucket, tools etc. Total tow weight 8300.
so i understand... you saying the trailer scaled 9600 lbs with cargo? which based on empty trailer weight was a cargo weight of 8300lbs?
9600-8300 = 1300
1300 + 960 (10% tongue weight) = 2260 <--- trailer "curb" weight?
1350 payload in the truck was ~960 in TW plus ~400lbs of driver/fuel etc?
It sounds like you scaled the load. pull truck on only read 5900 (pull all the way on the scale) read 15500, pull truck off scale read 9600?
What is tow rating for that truck? (i cant keep up with all the options and years and how the rateings seem to inflate each year)
were did you get your trailer? and can i ask how much you paid?
/ Thank you Tractorbynet #12
9600-8300 = 1300
It sounds like you scaled the load. pull truck on only read 5900 (pull all the way on the scale) read 15500, pull truck off scale read 9600?150
No, his max tow rating is 9,600# for his 3.55 geared Eco Boost. His max GCWR is 15,500#. His trucks published max payload is 1,350# and the trucks GVWR is 7,200#.
So his truck weighs 5,850#
Chris
Chris has it exactly right on the specs, thanks!
On the trailer, I got it new from Jimmy's Trailer Service in Warrenton, Virginia. Very nice folks. $4k. I looked at dozens of new and used trailers before buying that one. Used trailers in this part of the country are about 2/3 the cost of new and a real roll of the dice as far as condition of brakes, axles, frame, hubs, tires, wiring. There are a lot of different new trailers. The PJ seemed to be reasonable in quality and price.
/ Thank you Tractorbynet #14
Federal regs (FMCSA) require a separate tie down for items like a backhoe.
To the OP: thanks for the report and it's good to hear that the board was helpful.
/ Thank you Tractorbynet #15
I do not know if it's FMCSA reg or just here in Texas but you also need to have your out rigger arms on the backhoe chained where they can not come down.
Several people I know have gotten popped for that down here!!!
/ Thank you Tractorbynet #16
You did a great job for a 'first time hauler'. I'm glad TBN was able to help you.
/ Thank you Tractorbynet #17
I know your suppose to have the back hoe strapped down, but lets be real here, how could the backhoe fall off. I suppose in theory it could, but very unlikely. Kind of the same thing for the endloader, it could fall off, but very unlikely. But I'm sure your correct, the rules say you should.
On chaining the outriggers, I did that. Didnt know it was a requirement though. Did it because the arms drop down by themselves overnight so knew they needed to be chained for a week trip.
/ Thank you Tractorbynet #19
I suspect the theory is that, if the hydraulics fail, the backhoe could swing side to side and either hit something, or unbalance the load, causing a tip over. Think of a sharp curve and the hoe suddenly swinging to the outside.
I do have to agree, I don't understand the loader going anywhere. Besides, that's how I chain the front of the tractor down, through the crosstube on the loader. That's the way the dealer delivered my tractor. Probably to meet FMCSA regs, that's not enough, unless the front of the tractor is chained separately.
2020 23 Ft. Godfrey Marine Hurricane Boat with 26ft T/A Boat Trailer . (A61574)
2020 23 Ft...
THIS WILL BE A LIVE VIRTUAL ONLINE AUCTION! (A63111)
THIS WILL BE A...
YANMAR VIO35-6A EXCAVATOR (A63276)
YANMAR VIO35-6A...
Year: 2007 Make: Ford Model: F-250 Vehicle Type: Pickup Truck Mileage: 77,977 Plate: Body Type: 4 (A61573)
Year: 2007 Make...
2025 Kivel Quick Hitch Mini Skid Steer Attachment (A61572)
2025 Kivel Quick...
(2) 380/85R28 TIRES W/ 10 LUG RIMS (A64280)
(2) 380/85R28...
