Increasing amps
/ Increasing amps #1
arrow
Super Member
Wakefield, RI
Mahindra 3016
On a 115 volt welder whether stick or mig, is there any advantage to plugging these into a 30 amp circuit?
/ Increasing amps #2
It depends on what the welder is rated for on input. Most welders that run on 110/120V obtain their ratings at amps over 20, up to 40 on 110V.
For stick, if you see over 90 amps or so, you can bet it pulls more than 20 amps at max operating output. On Mig, it is more than 120 or so. Tig, over 105/110 amps or so.
Input amp requirement is simply a function of multiplying max output voltage and max output amps, and dividing by the input voltage...which is still usually a little higher than the math tells because of the loss in efficiency.
/ Increasing amps #4
Cant hurt. If you have the 30amp already available, I'd use it. That 30amp should be wired with at least 10ga wire which will have much less voltage drop and allow more current draw than the 15amp or 20amp which will be wired with 14ga or 12ga respectively.
/ Increasing amps #5
Plug it into a 20 amp circuit and turn it all the way up. If you can run a bead without popping the breaker, there's no advantage. If you pop the breaker, then there's an advantage.
NEXT!
/ Increasing amps
NEXT!
That's what I like….something definitive,clear cut and proof of the pudding. Also, I do not have to do any numbers which I was never good at. Welder never popped however I do not feel I'm getting all the amps but Mark explained that already. This welder says its 100 amps but I think I'm lucky to be getting 75-80. Beads are cold looking to me. 220 coming up….NEXT.
/ Increasing amps #7
Without power factor correction, Most 115v Migs actually only put out about 85 amps on a 20 amp circuit @ 20% duty cycle. If you can borrow a set of DC tongs you can easily test your output by clamping the tongs over your ground cable while welding.
/ Increasing amps #8
Are you tripping the circuit breaker now with 20 amps?
If so, you can get a delayed action breaker that rides through the inrush current from things like welders, air compressors, etc. I use a 20 amp delayed action breaker to handle the inrush current from my 115V Porter Cable air compressor.
/ Increasing amps #9
I have trouble re-striking often enough and never thought to blame the welder's output. Using a fancy ground clamp to be sure of good contact, I keep thinking my weak point is how well the stinger grips the rod. Gets to where I use DC more often to run good beads, but I am indeed a seat of the pants rookie. :confused3: (I'm contemplating upgrading my Mig capability to >100a, too.)
Power factor is it's own can of worms, and the 'correcting' gizmos that 'power companies hate' are a big joke on other forums since single phase power is rarely if ever billed by PF anywhere here in the states. (Can you say 'snake oil'?) But, that PF could affect welder output is something to wonder about, since we're talking an inductive load. Is the PF/efficiency thingie part of why setting/adjusting amperage is such a shot in the dark?
btw: I'd love to take a welding class, but BO hasn't added tuition assistance to Soc Sec yet. :rolleyes:
/ Increasing amps #10
Power Factor Correction is simply a dam inside your welder that holds power to a steady rate. Its not a way to get billed from the power company. it will correct spikes and valleys in your power as it flows to your welder giving it the optimum voltage feed. this can save blowing breakers and allows extension cords on 115v welders. Nothing to do with your output adjustments.
/ Increasing amps #11
NEXT!
Yes. Regardless of a 20 A breaker holding, the performancece advantage is with the higher amp circuit due less voltage loss in the larger wiring.
larry
/ Increasing amps #12
larry
Help me out with that, if you would? My thinking would be that a given load is going to pull a given number of watts, and that is constant. If voltage is lower, amps will go up (and so will heat in the wire), but the wattage will always be the same. So take a welder that is operating at max output on 110v current and it pulls 19 amps = 2090 watts. Now it's on a circuit with less voltage drop and it's getting 120v. It pulls 17 amps instead of 19, but otherwise, it performs exactly the same, doesn't it?
/ Increasing amps #13
Nope - the larger supply wire size causes less drop in supply voltage - having a higher voltage available to the welder means that, for any given electrical resistance/impedance, a larger current can flow.
This is ignoring any change in the welder's input resistance due to the possibility of more heating ( resistance of all metals varies with temperature - some have positive temp coefficient, some negative. As in, warmer could mean either more or less resistance, which would also enter in.
But basically, if you have more voltage available at the input, you get more current out... Steve
Temperature Coefficient of Copper
/ Increasing amps #14
It needs to be fed enough volts and amps in the first place. If you have too much voltage drop and/or too small a wire its like drinking a shake through a stirring stick..
/ Increasing amps #15
larry
I appreciate your question ... and these good answers. I have very little to add, and some may be confusing. Briefly:
,,,The small wires drop more V @ any current and thereby consume power within themselves.
,,,Welders differ. With electronics deriving the welding current a welder can pin its output just fine with variable input V [within reason], but must pull greater current to do it as the voltage drops. Big wire is always your friend in any circuit, but one with an electronically pinned output will drive this home. - The welder puts out the V X A set regardless of the input. Factor this against a 20A breaker on 12Ga wire vs a 20A breaker on 10Ga and you see the welder will pop the 12Ga breaker before the identical 10 Ga ... because the welder draws more A on the 12 Ga feed.
,,, Other welders can be just a variable transformer. These putout lower V as the input V goes down. Altho V can drop a bit before you notice a performance change, its not too hard to see that yould like voltage to be nominal so theyld work as well as they can.
Stay as close to the power panel as feasible. Use oversized wire if you have to get very far away. Remember how that circular saw acts at the end of a 12 vs 14Ga 100' extension cord. same idea.
larry
/ Increasing amps #16
larry
That's a good point. Just a few months welding on an inverter, and it's like I've completely forgotten transformers exist.
/ Increasing amps
So for those saying it would, they would be thinking that the 20 amp is on 12 ga wire? Would it make any difference if both the 20 amp and the 30 amp are on 10 gauge? From what i'm interpreting, it doesn't.
/ Increasing amps #18
Yes.
... And Barely. There is some loss in a breaker associated with energy to cause the physical "break". This is approximately the same regardless of the breakers current rating. V across a breaker at its rating may be 0.05V at a guess. A 30A at 20A draw would then have 2/3 x 0.05 ~0.033V across it. ... Kinda no difference. :confused3:
larry
/ Increasing amps #19
A 20amp breaker is smaller and flows less with more voltage loss than a 30amp. Same idea as feeding a 1/2" spigot with a 3/4" hose - while you will have max water available, it will only flow as much as the 1/2" will allow.
But, as said, for a welder designed for 20amp, the difference would be very marginal.
DECORATIVE METAL GATE (A58214)
DECORATIVE METAL...
2018 Volvo VNL 760 T/A Sleeper Cab Truck Tractor (A61568)
2018 Volvo VNL 760...
2017 Loat 22ft Tilt Trailer (A59231)
2017 Loat 22ft...
2019 John Deere 1023E Tractor (A61166)
2019 John Deere...
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A63118)
2023 New Holland...
