Piston
Elite Member
Here is what I currently have:
A '99 F350 SRW and a 10,000lb Hudson 18' bumper pull.
As you can see, when I need to bring numerous implements to a job, I have a hard time squeezing it all in. I really wanted to bring my chipper on this job as well but I just couldn't fit it, there was no way.
With the above setup, I'm positive I'm overloaded. All together the tractor, and implements on the trailer weigh in at about 8,500lbs. The trailer is another 2k so that is 10,500 total right there, not including the fact that I have way too much tongue weight on my hitch.
The stumpgrinder in the bed of the truck weighs either 1200lbs or 1400lbs, I forget off the top of my head. My truck weighs somewhere in the neighborhood of 8k, so total combined weight of everything is estimated to be between 19,000 to 19,500lbs.
I think it's safe to say that this load would pull a little better with a gooseneck! Although I have to admit, with heavy duty springs in the back, the truck actually rode decent with all this weight, I was even able to drink a cup of coffee without spilling it while driving, I can't do that too often in this truck! :laughing:
I have some questions about Goosenecks. First of all, I was thinking about a 24' GN. However, my tractor, grapple, and 6' rotary cutter are 22' long, so that only leaves 2' for another implement. I'd like to be able to take along the stumpgrinder and chipper, if possible. Most likely I would not need all these implements at the same time very often, so fitting one of the two would be sufficient. I figure if I had an additional 4' extra space I'd be okay. That brings me to 26'.
Just for safety sake, and the ability to shift weights slightly, I would most likely go with a 28' GN. I like the flat deckover design with slide in ramps. I am interested in something like the PJ classic flatdeck.
The issue is, it seems like no matter how I cut it, I am still limited to around a 10k lb load on the trailer. The trailer weighs just shy of 5,500lbs. It's rated for 15,600. Does that mean that I can only put 10,100lbs on the trailer?
PJ Trailers - Classic Flatdeck with Singles (FS)
