Matching a trailer to my load/truck, current setup isn't cutting it????
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #1
Piston
Elite Member
New England
Kubota L4610 Hitachi UH083LC
Here is what I currently have:
A '99 F350 SRW and a 10,000lb Hudson 18' bumper pull.
325700d1372847265-your-towing-rigs-trailers-image-671886419.jpg 325699d1372847252-your-towing-rigs-trailers-image-534395912.jpg
As you can see, when I need to bring numerous implements to a job, I have a hard time squeezing it all in. I really wanted to bring my chipper on this job as well but I just couldn't fit it, there was no way.
With the above setup, I'm positive I'm overloaded. All together the tractor, and implements on the trailer weigh in at about 8,500lbs. The trailer is another 2k so that is 10,500 total right there, not including the fact that I have way too much tongue weight on my hitch.
The stumpgrinder in the bed of the truck weighs either 1200lbs or 1400lbs, I forget off the top of my head. My truck weighs somewhere in the neighborhood of 8k, so total combined weight of everything is estimated to be between 19,000 to 19,500lbs.
I think it's safe to say that this load would pull a little better with a gooseneck! Although I have to admit, with heavy duty springs in the back, the truck actually rode decent with all this weight, I was even able to drink a cup of coffee without spilling it while driving, I can't do that too often in this truck! :laughing:
I have some questions about Goosenecks. First of all, I was thinking about a 24' GN. However, my tractor, grapple, and 6' rotary cutter are 22' long, so that only leaves 2' for another implement. I'd like to be able to take along the stumpgrinder and chipper, if possible. Most likely I would not need all these implements at the same time very often, so fitting one of the two would be sufficient. I figure if I had an additional 4' extra space I'd be okay. That brings me to 26'.
Just for safety sake, and the ability to shift weights slightly, I would most likely go with a 28' GN. I like the flat deckover design with slide in ramps. I am interested in something like the PJ classic flatdeck.
The issue is, it seems like no matter how I cut it, I am still limited to around a 10k lb load on the trailer. The trailer weighs just shy of 5,500lbs. It's rated for 15,600. Does that mean that I can only put 10,100lbs on the trailer?
PJ Trailers - Classic Flatdeck with Singles (FS)
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #2
They list optional 8K axles, but don't say what the GVWR would be.
Check this company. Gooseneck Trailers - Kaufman Trailers
I an considering this one. 17,000 GVWR / 24 ft. Equipment Tilt Gooseneck
Can get 26' and 28' also.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #3
You can do this with a smaller GN trailer than 28 foot. Mine has an upper deck of 8X7. The bed is 20 with 4 foot dovetail. I lift extra implements up to it. Just be careful with your turning radius with a shortbed truck. Too tight a U-turn and the deck can hit the back window. Use of an extended ball helps.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #4
First of all, you would do better (and be safer) with a weight distributing hitch on your existing trailer.
Have you weighed each axle to see how you are loaded? When we bought our horse camper (gooseneck), we found that we were 300# overweight on the rear axle without horses or water. I could feel the instability on mild curves. We upgraded to a dually, much, much better and safer. There is not much difference in rear axle capacity between a SRW 1 ton and a 3/4 ton.
With a gooseneck, a significant amount of weight will go onto the truck rear axle. Perhaps 4000# or more. So a gooseneck rated for 12,000# can actually haul 16K without exceeding the ratings (12K on the trailer axles and 4K on the truck rear axle). However, your truck needs to be able to handle that.
Depending on your state laws, you could possibly haul your existing trailer behind a gooseneck. My gooseneck equipment trailer has a hitch receiver on the rear. That sounds like a nightmare loading and driving, but it would be an option for hauling everything on rare occasions.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #5
I think you are in the same boat as me. I had a 25' GN and now a 18' BP. I actually can take more with the BP. With the GN the loss of the 8' bed killed me. My GN was 6500# empty and had a GVWR of 25,000# leaving about 18,500# for payload. My BP has has plenty of payload for my needs and my 06 F350 can handle 3,900# in the bed/tongue weight legally.
I think you would need a 30' or better GN with tri 7K axles to come close to your needs.
Chris
I didn't realize I could put implements on the top deck of the GN, so that could help save 4' or so with one implement.
I have not weighed each axle. I typically load differently on each job I go to, some require a lot of implements and some don't. When I have the RC on the back of the tractor, I end up with a lot more weight forward, when I don't have the RC, I end up with more room forward. So basically, my weight distribution on the trailer changes from job to job.
Thanks for mentioning about how a 12k GN can actually haul 16k without exceeding the limits, that was going to be one of my next questions.
I can not legally tow a second trailer, behind a first, nor would I want to do that.
Chris
Chris,
I think that is the main problem I'm facing, I don't see me gaining a lot of capacity by going to a large GN, weight wise. If I had a 12,000 lb bumper pull, I could load around 9000 lbs on it, plus put an implement in the back of the truck, and probably do it a whole lot cheaper.
I would like a GN for how well they supposedly tow, but if it's going to cost me 6-8 grand, and not give me much more capacity, well I wonder which way I should go. As you can see, I am not decided on what to do, I don't know what would be best for me, short of buying a dually with a huge capacity, which is out of the question.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #7
Your F350 looks like a short bed in the picture. Do you really want the potential hassle of a GN on a short box?
If you can't put the GN ball where it's supposed to be, slightly ahead of the truck axle, you're really not taking full advantage of the GN design.
If that's the truck you're going to use why not consider a long tri-axle bumper pull with a GOOD weight distributing hitch?
I think that combo would do the job and you would still have the truck bed available to load things in. The truck will ride a lot better with the WD than your current setup.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #8
First of all, you would do better (and be safer) with a weight distributing hitch on your existing trailer...
With a gooseneck, a significant amount of weight will go onto the truck rear axle. Perhaps 4000# or more. So a gooseneck rated for 12,000# can actually haul 16K without exceeding the ratings (12K on the trailer axles and 4K on the truck rear axle). However, your truck needs to be able to handle that...
If a trailer is rated at 12K on the chassis tag that is all it is supposed to weigh including the hitch weight. I know what you're saying, if the trailer has two 6K axles you could probably load it up over 12K because some of the weight is on the hitch and the trailer axles would not be overloaded; but what about the rest of the trailer?
The problem is some manufacturers, especially with goosenecks, have already included the tongue weight in their "rating" You will see some GN's with two 7K axles rated at over 15K. On the other hand some trailer manufacturers do not do this, the trailer with two 7K axles is rated 14,000 GVW and that's that.
I think you're being generous when you say a trailer with 12K of axle capacity can be loaded up to 16K. If you did that you would need to have 25% of the total on the hitch, which is on the high end even for a GN; and with his SRW F350 4x4 crew cab I think 4K in the bed would be over the truck's payload rating and possibly rear axle rating.
My main point is if the tag on the trailer frame says 12,000 GVW, then you really shouldn't go over that. They could have designed the neck, frame, coupler brakes, etc., for 12K but no more.
It is a short bed. I really don't know about the potential hassle of a GN with the short bed. I have never once towed anything on a GN trailer, I've never even been in a truck towing anything with a GN, so I really have zero experience with this. The ONLY reason I was convinced that a GN was better, is from all the threads on here from people saying how much better GN's are for towing. It's one of those things that I didn't realize how much I "needed" a GN until I learned WHY they were "better" from reading online, so basically, I have NO experience with them.
I've actually been really happy with bumper pull trailers in general, I have a LOT of experience towing bumper pulls, and really have never had the issues people talk about.
I "originally" was set on a longer bumper pull, because I'm used to it, it's worked well for me, I like the ability to put other implements in the back, and also because my next truck will most likely have a cap on the back, which of course I can't do if I have a GN. Then, after reading a lot online about longer bumper pulls, I started seeing how almost everyone was recommending GN's, and how much "better" they are.
Now you guys might be knocking some sense into me and convincing me that maybe my original idea of a longer bumper pull is the way to go.
I'm hoping that in the next few years I'll be buying a new truck, it will either be a 3/4 ton or another 1ton diesel. It seems like a lot of the new trucks come with class V hitches, whereas mine is only a Class IV I believe (it's rated at 10k lbs)
I've also never used a WD hitch, but have talked to a lot of friends who have, they say they make a big difference as well. Again, I've really not had many problems towing my current trailer, except for when I try to "fit" a whole lot more that I should. With this trailer, I don't have much room to balance the load.
I'd really like to have a 5 ton capacity trailer, so I assume any trailer that has that capacity, would probably weigh 3-4k lbs? I guess I'd need a 15k lb trailer?
Since posting this, and reading some of your replies, I started looking at 24'-26' bumper pulls, that may be my best route?
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #10
I think a BP is the best choice. I have had them all upto 25000 # GVWR and by far the BP is my choice for all the reasons listed above.
Chris
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #11
I wouldn't get a flat deck. I'd strongly recommend a trailer with a dovetail. Slide in ramps would get old quick and the dove lowers the angle to load and unload substantially.
Brett
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #12
Brett
I am the opposite. Had a DT and much prefer my low boy flat deck with slide in ramps vs the stand up ramps on my old trailer that always seemed to be in the way.
Chris
Brett
Rusty, have you used both? The reason I ask is because my current trailer is a dovetail with fold up ramps and I hate it. I know it isn't good to hang the rotary cutter off the end but I would love to be able to let it overhang a few feet, whereas now I can't, because the ramps are always in the way. I haven't used a flat deck trailer but I can't see why it would be a big deal. I would really only use it for equipment, and not a car or anything that needs a shallow angle of approach. I feel like I would get more usable space with a flat deck.
The other use I have for the trailer, is to lay my Woodmizer sawmill on it for when I want to do a mobile job. The mill is not a trailerable model (LT 15) but is easily setup on a trailer. I've done this on my current setup but it overhangs as well.
I also do not like how little clearance I have on the back of the tractor, more than one occasion I have scraped/dragged the bottom of the trailer on a customer's driveway, I have to be really careful of that.
I'm browsing online and found this PJ trailer...
PJ Trailers - 8" I-Beam Deckover (F8)
I would probably like the 26' model, it comes with two 7,000lb axles and has a 14k lb weight rating. The trailer weighs 4k lbs (actually 4300 but let's say 4k for easy math:D) I'm assuming this means I can safely and legally carry 10k lbs?
If I were to upgrade to the two 8k lb axles, could I then legally carry 12k lbs on the trailer?
What would be better, two 8k lb axles, or three 7 lb axles? It seems like 3 axles would weigh more, and I couldn't take advantage of the extra weight rating, but it may ride or carry the load nicer with 3 axles? What are the advantages and disadvantages of 2 or 3 axles?
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #14
I agree that a short bed means more problems with a gooseneck. 1) you will need a narrow front on the gooseneck (no front deck) and 2) you will still have to be very carefully turning while backing up so that you don't run the truck cab into the side of the trailer. People do that even with the more spacious full sized beds.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #15
I have used both. With your trailer being a lowboy the slide in ramps wouldn't be a problem but if it was a deckover, the ramps would be very steep. To the OP if you place the bucket on the neck, it frees a bunch of deck space up. I have a 25+5 and have been able to haul anything needed from my 20k lb Dozer to a little kubota 3400.
The other thing to think about is slide in ramps aren't supported by anything other than the trailer lip and ground. In my opinion that puts a bunch of stress on the back of the trailer and ramps. On my setup the ramps have a brace on the ground so when loading the weight is on the ramps and not the trailer.
Brett
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #16
Here's how mine is set up
Brett
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #17
you should be able to get a 24-28' dual axle 16K bumper pull.
1600lb class 5 hitch (2.5") with WD hitch,
Id expect the trailer to weigh 4K lbs but with 1600 TW youll net about 13.5K cargo.
Is a Class 5 hitch and WD hitch, easily retrofitted to my truck? How much would something like that cost?
So just to make sure I understand this correctly, the tongue weight load does not apply to the total weight on the trailer? So if I have a 16k lb trailer, and it weighs 4k lbs, I can load MORE than 12k lbs on it legally?
Brett
Brett,
Thanks for the pics :thumbsup: That is a nice setup! The reason I don't like to pull the tractor all the way forward and put the bucket on the neck, is because of the increased tongue weight. I don't worry about the stress on the trailer, but rather overloading my hitch, which at this point is now approaching 14-15 yrs old.
/ Matching a trailer to my load/truck, current setup isn't cutting it???? #20
On my trailer if its pulled on to scales the trailer axles are not supposed to be above 10k each. The trailer is rated for 20k. The way to work the numbers is to put more weight on the rear axle of the truck. Technically I could put 23000 on my trailer. 20k on the axles of the trailer and 3k pin weight on my truck. Sometimes you move things around to get it balanced out right.
Brett
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
Kubota M4700 4WD 51HP Utility Loader Tractor (A56857)
Kubota M4700 4WD...
Willmar 4550 Wrangler Articulating Loader (A61307)
Willmar 4550...
Hidratrak 8' Rolling Cultivator (A53317)
Hidratrak 8'...
FORD F-250 (INOPERABLE) (A60736)
FORD F-250...
Auger with 2 bits for mini skid steer (A61567)
Auger with 2 bits...
