Need to weld stainless steel
/ Need to weld stainless steel #21
Not me. I think I am the onle one that just uses the c25 mix that is used with mild steel???
Never had an issue...
Look up the welding of the St-Louis arch...
All SS welded on site c25 mix
/ Need to weld stainless steel #22
Well At least I am not alone then.
I guess the way I see it, C25 is good enough to do the job and do it well. Sure, other mixes may work better, but if you are going to go the extra mile, just TIG it.
/ Need to weld stainless steel #23
........... but if you are going to go the extra mile, just TIG it.
Or break out the wallet and pay someone else to TIG it.....Done.....:thumbsup:
sometimes a six-pack and perfect timing to the right guy that works at a metal shop is all that is needed
Adams Tender Trailer (A61306)
Adams Tender...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
JCB 2145 (A47477)
JCB 2145 (A47477)
Kubota L3130 (A53317)
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
