B2400 4WD = no love........
/ B2400 4WD = no love........ #1
stayalert
Shifter seems to operate OK but I get no power to front wheels.....Where to start????
I live/operate in hilly terrain and need 4wd often....HELP!!!
current thinking is fork on inside of case....~$2000!!!!! to fix....Ulp....
/ B2400 4WD = no love........ #3
In which case is the fork located? Drive axle case?
/ B2400 4WD = no love........ #4
I'd check the drive shaft coupler first!
/ B2400 4WD = no love........ #5
I'd check the coupler first too. $2000 is a little high for that repair. I did a pto fork which involves splitting the tractor the same way for a customer 2 yrs ago, for $1400 at his vineyard, so even with my rate increase to $100/hr and possible price difference on parts, I'd say maybe $1600 if the fork is broken.
Brian
The drive shaft coupler at the front?
Thanks i'll check it out (with fingers crossed)
Well I don't know how to explain this but in preparation to take it in for repair I took off the loader, took off the mower, and generally cleaned it up bait....The 4WD seems to be working fine again.....I changed the front axle lube, and HST fluid & filter, cleaned the HST strainer and everything seems to be working properly....With fingers crossed I cancelled my scheduled appointment.....Hardly any fillings etc in the strainer and nothing noteworthy about the old front axle fluid.....I'm wondering if the bi-speed steering was acting wonky leading me to believe the 4WD was at fault.....Perhaps my cleaning efforts were sufficient to restore just a wee bit of proper linkage movement? I dunno....I hope everything remains tickity boo.......
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63118)
2006 Cadillac GM...
John Deere 1418 Bush Hog (A64047)
John Deere 1418...
1986 Eager Beaver B9D0W 20ft. 11 Ton Tri Axle Dovetail Tag A Long Tailer (A61568)
1986 Eager Beaver...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
30 Yard Roll Off Dumpster (A61165)
30 Yard Roll Off...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
