Tractor backhoe - homemade
/ Tractor backhoe - homemade #161
I speak American English, Canadian English (eh?), Australian English, and UK English. I can manage German English but sometimes struggle. I can read and write Jenglish (Japanese English) but have some trouble speaking it.
Well spoken :thumbsup:
:thumbsup:
/ Tractor backhoe - homemade #163
Great, so material thickness will be ok...as I expected.
These days I've been finishing design details for the boom and dipper...by now all the drawnings are done except for the thumb, but I'm working on it...:)
Nice work, it's turning out great! If you have not cut the side plates as shown in your drawing above, I would consider re-designing the large ones (at the bend of the boom, which has three lightening holes in it). If it were me, I would make the ends of these parts come to a point rather than the rounded shape you show. My reasoning is that the point allows you to weld more in a longitudinal direction along the beam. The rounded shape you show may entice you to weld across your most important structural component. Welding across is like putting a dotted line there that says "tear here".
That's not a bad idea, but it's too late for redesign since all the material is already delivered to the workshop and they are cutting it... I understand what you try to point out and hope it's not gonna tear :)
/ Tractor backhoe - homemade #165
Commercial backhoes are often designed with metal doubled in high stress areas and attached by a full weld round the perimeter of the doubler piece. That's a nice way to deal with the problem of material thickness vs weight.
rScotty
/ Tractor backhoe - homemade #166
If you take sections of the boom profile, you'll find the most stressed section (in the transition area where the doubler plate ends) has the weld near the neutral axis of the profile, where tension is little. So no problem :)
/ Tractor backhoe - homemade #167
I have nothing to add. You are amazing in your design and fabricating skills. I will be following this thread.
Marcus
/ Tractor backhoe - homemade #168
Marcus
/ Tractor backhoe - homemade #170
Hi, not sure where you are at, but on the boom, it look like you did some fish mouth weld on the reinforcement tips plates, but not on the dipper.
They are diagonal, but still pretty straight. Might wanna trim them to add a curve to it. Will end up having a better spread of tension force created by welding.
Thanks for the warning, I changed that detail earlier; the picture you're watching is not the latest one.
"Boom and bucket party" started today :)
/ Tractor backhoe - homemade #172
That is really looking nice, wish i could be there to help you!!!
Let me jump on the next available flight!!!
Is your bucket going to be tapered and have holes?
Read somewhere that is make it easier to drop sticky loads like clay.
/ Tractor backhoe - homemade #174
Awesome ideas and execution. It is really coming along nicely. You are going to have one heck of a backhoe :cool2::cool2:
I'm gonna build two buckets. The smaller one will have holes on the back side so the wet dirt can fall out easily.
Yes, I used the side teeth to get a 90 degree angle and a perfect alignment of Hardox plates. :)
Work continues...
/ Tractor backhoe - homemade #177
Very nice looks like it came from the factory!
What make and type of welder are you using to stick these together?
/ Tractor backhoe - homemade #178
Work continues...
We use chains for very sticky clay. One end is attached close to the digging edge and the other to the dipper. When the bucket is in digging position they are slack allowing bucket to fill. When the bucket is in emptying position they tighten pulling the content of the bucket out.
I know that mechanism. If necessary, it can be quickly mounted on my bucket. I'm using Varstroj SuperMIG 280 welding machine. Most of these parts were welded at 220-250 A. Wire thickness is 1.2 mm
/ Tractor backhoe - homemade #180
This is really beautiful. You are the HR Giger of backhoe builders.
3pt 6 Row Cultivator (A64119)
3pt 6 Row...
2023 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61573)
2023 Peterbilt 567...
Caterpillar Blade Control Service Manuals (A63117)
Caterpillar Blade...
2016 Ram ProMaster 2500 Cargo Van (A61573)
2016 Ram ProMaster...
2 Row Cole Planters w/Plates (A64119)
2 Row Cole...
2001 Freightliner FLD120 T/A Sleeper Cab Truck Tractor (A61573)
2001 Freightliner...
