sickle mower keeps tripping safety (?)
/ sickle mower keeps tripping safety (?) #1
idbill
McCall, ID
Ford 640, 1955 (?)
Hi all, total newbie here. I'm first-time using a Dearborn 14 15 sickle mower on a Ford 640, just trying to mow a pasture. The far end of the mower seems too low and keeps sticking, and that trips the release (which I figure is a safety feature?). There's no swath board, but from what I can read that's only there to help windrow the hay and isn't totally necessary. Seems like the outer shoe should be more like the inner shoe, taller and wider to keep the end from sticking on uneven ground.
Anyway, if anybody can point me in the right direction for doing a simple sickle mowing job without tripping the release every ten feet I'd appreciate it.
- Bill
/ sickle mower keeps tripping safety (?) #2
Can you adjust the bar pitch and see if it helps
/ sickle mower keeps tripping safety (?) #3
Yes. it should ski the end of the bar. Doesnt need to be as big out on the end because theres a lot less weight on it. Is there a spring mechanism that can be adjusted to apply some lift to the bar as it pivots down? Should be. plus tipping the mower back a little should help.
larry
Thanks for the replies. I'll try the bar pitch and/or tipping the mower.
Bill
/ sickle mower keeps tripping safety (?) #5
Hope we didn't mess you up but pitch and tipping same diff.,just screw out on top-link:D
Sorry, showing off my ignorance again. Thanks.
/ sickle mower keeps tripping safety (?) #7
The skid on most cutter bars are adjustable and yours might be to low.
/ sickle mower keeps tripping safety (?) #8
- Bill
There is a tension adjustment for the trip on the arm that goes to the right stabilizer clamp on the axle. You can also tighten up the cable that runs around the pulley. That will bring the tip of the bar up more. Ken Sweet
/ sickle mower keeps tripping safety (?) #9
Did you get it lined out?
Perfect, thanks. Nice to know now what some of those cranks and levers are for :) I'm also going to play around with the tension per Ken's reply above.
/ sickle mower keeps tripping safety (?) #11
I just looked at a video of the Dearborn 14 15 and the outboard shoe appears to be adjustable. I've also seen the outboard shoes rigged up with a small wheel. Not sure if the wheel was OEM or a modification.
I don't have much experience with a sickle bar mower yet but I've had the latch safety release on mine (an MF Dynabalance) a few times now and it seems to happen most often when something breaks the plane of the blade ...like an ant hill or some other kind of mound or when the outboard end of the blade meets a steep rise in the grade. Could it be that you just need to be more alert to what can cause the release?
I'd be careful with restricting the safety release operation unless I was sure that's where the problem was. I just greased the latch and the pivet points on the swing frame on mine to make sure it would operate.
2017 Mack Semi (A64047)
2017 Mack Semi...
New/Unused Landhonor Pallet of Chains and Binders (A65583)
New/Unused...
2018 Trail King Lowboy (A63689)
2018 Trail King...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
2021 Big Tex 14ET 18' Tandem Axle Trailer (A62679)
2021 Big Tex 14ET...
