Rotary Cutter Broke turnbuckle first time using bush hog
/ Broke turnbuckle first time using bush hog
I contacted my dealer. It may or may not be covered by warranty. First the guy said I need to bring the tractor in for it to be covered by warranty. A Kubota technician needed to install it so it would be installed properly. I said you’re kidding me. It is threading a nut on a rod. He said to bring the part in along with the hours and serial number of the tractor. I will do all of that tomorrow. I talked to a different guy at the parts counter regarding the beefier sway arms from the B series. Priced them to me at $21.xx each. Then he told me they wouldn’t work on my tractor. I said I know they are not an exact match, but they can be modified to fit. He told me I needed more parts but that it still would not work. I assured him that I have seen pictures of many people who had did this modification and that I wasn’t ordering right now, just checking prices. So now I will wait to see what I hear from Hodges. Although I did see a thread on a Kubota board where he said they were $110 plus the shipping costs.
/ Broke turnbuckle first time using bush hog #22
You may be on your own but even if you are out $110+ it should be a one time expense. Turning with the bush hog cutting low on hilly ground can lead me to plowing a furrow sometimes. :(
/ Broke turnbuckle first time using bush hog #23
Used my Kodiak bush hog for the first time today. It is only a 40" so my BX2370 should handle it. Many on here have told me they use 48" cutters with no issues. I don't know if I set it up wrong or what. I have used a bush hog on my old 9N and Massey many times in the past, but obviously the Kubota has a little different set up. Anyway, the turnbuckle on the left side broke where it is welded on the nut. I was on some uneven ground so I don't know if I got it in a bind or perhaps it was a bad weld. I am sure this won't be covered under warranty. Any ideas on what might have caused this?
Ran into this once (another brand of tractor) and the distance was changing as the implement was raised- had to set it while fully lifted to not bind... not sure if this is what's going on with yours but it might be worth checking...Those 3 points do have a lot of hydraulic power:D
Just looked a little closer at the turnbuckle set up and am suprised to see that Kubota did not mount the stabilizing turnbuckle on the same axis as the lift arms pivot point, virtually every other tractor 3 point mounts the check chains or bars on or very close to the lift arm pivot points- to allow full range of motion of the 3 point lift- how does Kubota keep even tension when the implement moves up and down???
I am beginning to think it may be easier to go back to the actual chains like the old tractors used!
/ Broke turnbuckle first time using bush hog #25
Wow- just looked again (pictures) is it possible that the lift arms are reversed left to right and inverted ? On most tractors normally the stabilizers mount outboard of the lift arms and to mounts that are very close to the axis of the lift arm pins- but mounted outside of them (towards the back tires) ??
I may be barking up the wrong tree - but never have seen the check chain /bars mounted anywhere near the pto...
so they don't mount like this rhino engine front 009.JPG is it possible there is a mount out of sight inboard of the lift arm mount pins? if not just can't see how the check chains or bars would not bind as the implement is raised or lowered...
/ Broke turnbuckle first time using bush hog #26
Thats how they are on the smaller kubotas. Not sure about the B's, but the L's they move to the outside and the BX's are on the inside
Maybe someone can tell me why this hairbrain idea won't work. Replacing the turnbuckle assembly with chains. I was thinking I could keep the U shaped clevis that attaches to the tractor and lift arm. Attach one end of the chain to the clevis on the plate under the pto shaft. Put one of the snap type quick links on the chain and attach it to the lift arm clevis with it. The chain could be adjusted by moving the quick link up or down the chain links. When shortened there may be a couple inches of chain hanging down, but not enough to get tangled in any rear implement. This sounds to simple so I am sure I am overlooking something as to why it won't work.
/ Broke turnbuckle first time using bush hog #28
You could use chain for sure. I installed chain shackles in my 3pt when i bent the stock U shackles. All I had to do was drill out the 3pt arms to fit the chain shackle (3/8" IIRC) then you could run chain in place of the turnbuckle.
Or maybe look at a heavier turnbuckle. This was the model that somebody told me would be a direct fit, I havent confirmed it myself : National Hardware® 3276BC 1/2X9 Forged Turnbuckle, Jaw/Jaw - Tractor Supply Online Store
Here's mine after installing the shackles.
/ Broke turnbuckle first time using bush hog #29
The drawback would be not being able to adjust it less than the length of a chain link. Maybe you could twist the chain if you needed it a half-link tighter.
Bruce
/ Broke turnbuckle first time using bush hog #30
Well, please don't take this the wrong say, and I sure don't mean to be hateful, but I am sure not impressed with those turnbuckles. They seem very weak to me. Just a couple of tack welds on a nut?
James K0UA
I agree...pretty flimsy.
Even the older Deeres (670, 55 series, 770, 790, etc.) had robust forged anti-sway links.
As far as why this one broke...probably when you made a turn and the tail wheel may have been cocked a bit...added stress to the rather weak turnbuckle.
/ Broke turnbuckle first time using bush hog #31
Now Roy you know they just don't build 'em like they used to. Sometimes that's a good thing, this time not so much.
/ Broke turnbuckle first time using bush hog #32
The OP has not described if he/she was PULLING the mower forward or PUSHING the mower in reverse. Tractors are designed to PULL, not PUSH.
Turnbuckles only provide 50% of support when pushing, relative to pulling, at best. In addition, factory turnbuckle stabilizers on my Kubota B3300SU weighed 4 pounds. Replacement Stabilworks pin adjustable stabilizers weigh 14 (+) pounds. I am not an engineer but I calculate Stabilworks mechs must be at least eight times stronger than factory turnbuckles WHEN PUSHING A BUSH HOG INTO THICK BRUSH.
In my experience the two occasions that cause turnbuckle stabilizer failure are PUSHING a bush hog and PUSHING a box blade.
Watch the Stabilworks video:
Kubota tractor stabilizers Kubota [url]www.stabilworks.com - YouTube[/url]
/ Broke turnbuckle first time using bush hog #33
Stabilworks option looks super strong and stable.
He (me) was pulling most of the time, which was less than 10 minutes total before it broke. I had to back up a couple times to turn around. For all I know it could have broke while "pushing" when I was backing up to turn around. I didn't see the moment that it broke. I just happened to look back and see that it was broke. Either way, I think I am going to go with the Kubota parts to make my arms. Stabil Works looks great, but I can't justify the price difference.
/ Broke turnbuckle first time using bush hog #35
To fix the factory defect would be $5 at our local welding shop.
I can get it re-welded for free, but it would still be a weak set up in my opinion.
/ Broke turnbuckle first time using bush hog #37
I agree...it's inherently a weak design.
2014 Dynapac CP142 9 Wheel Pneumatic Roller (A62679)
2014 Dynapac CP142...
2003 Dodge Ram 1500 Pickup Truck (A64194)
2003 Dodge Ram...
2018 Toyota Camry Sedan (A64557)
2018 Toyota Camry...
2025 JMR Stump Bucket Skid Steer Attachment (A64553)
2025 JMR Stump...
2019 FREIGHTLINER SPRINTER 2500 4X2 S/A CARGO VAN (A59912)
2019 FREIGHTLINER...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
