Rotary Cutter Broke turnbuckle first time using bush hog
   / Broke turnbuckle first time using bush hog #31
I agree...pretty flimsy.
Even the older Deeres (670, 55 series, 770, 790, etc.) had robust forged anti-sway links.
Now Roy you know they just don't build 'em like they used to. Sometimes that's a good thing, this time not so much.
   / Broke turnbuckle first time using bush hog #32
The OP has not described if he/she was PULLING the mower forward or PUSHING the mower in reverse. Tractors are designed to PULL, not PUSH.
Turnbuckles only provide 50% of support when pushing, relative to pulling, at best. In addition, factory turnbuckle stabilizers on my Kubota B3300SU weighed 4 pounds. Replacement Stabilworks pin adjustable stabilizers weigh 14 (+) pounds. I am not an engineer but I calculate Stabilworks mechs must be at least eight times stronger than factory turnbuckles WHEN PUSHING A BUSH HOG INTO THICK BRUSH.
In my experience the two occasions that cause turnbuckle stabilizer failure are PUSHING a bush hog and PUSHING a box blade.
Watch the Stabilworks video:
Kubota tractor stabilizers Kubota [url]www.stabilworks.com - YouTube[/url]
   / Broke turnbuckle first time using bush hog #33
Stabilworks option looks super strong and stable.
He (me) was pulling most of the time, which was less than 10 minutes total before it broke. I had to back up a couple times to turn around. For all I know it could have broke while "pushing" when I was backing up to turn around. I didn't see the moment that it broke. I just happened to look back and see that it was broke. Either way, I think I am going to go with the Kubota parts to make my arms. Stabil Works looks great, but I can't justify the price difference.
   / Broke turnbuckle first time using bush hog #35
To fix the factory defect would be $5 at our local welding shop.
I can get it re-welded for free, but it would still be a weak set up in my opinion.
   / Broke turnbuckle first time using bush hog #37
I agree...it's inherently a weak design.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A56138)
2018 FREIGHTLINER...
2006 JOHN DEERE 650J XLT CRAWLER DOZER (A52707)
2006 JOHN DEERE...
2003 VOLVO VNL TANDEM AXLE SLEEPER TRUCK (A56138)
2003 VOLVO VNL...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2018 KENWORTH T680 TRI AXLE DUMP TRUCK (A56138)
2018 KENWORTH T680...
