Torque Specs for Water Pump Yanmar 2000
/ Torque Specs for Water Pump Yanmar 2000 #1
Denise35768
Scottsboro, AL
YM2000
I'm trying to find torque specs for water pump for Yanmar 2000. I've searched through the forums and couldn't find this info, but I'm new so I could have missed it! :) Thanks in advance!
/ Torque Specs for Water Pump Yanmar 2000 #2
Just Google "Metric bolt torque value" and there are charts that show the torque. Hard part is figuring out what size bolt you have. You can Google "How to tell Metric bolt sizes" for that.
/ Torque Specs for Water Pump Yanmar 2000 #3
I think those will be 8mm bolts. 17-22 ft lbs for grade 7t, 45-52 for grade 11t. I would use goodntight on water pump bolts. :D
/ Torque Specs for Water Pump Yanmar 2000 #4
Im with winston, i would just snug them and then a bit more, but not ring them off tight but not so loose that they leak. I have replaced many a water pump and honestly never torqued a one. NOt saying it is right but for that application i dont think i would torque them.
I have done quite a bit of work and never had a problem not torqueing.
/ Torque Specs for Water Pump Yanmar 2000 #7
If its any help my Yanmar built JD specs out 228 inch lbs (26N*m) with a M8X45 cap screw on the water pump on a 3TNE74 engine (20hp)
/ Torque Specs for Water Pump Yanmar 2000 #8
That converts to 19 ft lbs.
2018 PETERBILT 579 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2018 PETERBILT 579...
2009 PALFINGER 11 FT SERVICE BODY (A62613)
2009 PALFINGER 11...
2017 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2017 Ford F-250...
2014 DODGE 5500 SERVICE TRUCK (A65643)
2014 DODGE 5500...
John Deer MX8 Bush Hog, 3pt, Dual Gear Box, PTO (A62679)
John Deer MX8 Bush...
2012 DODGE 2500 RAM (A65643)
2012 DODGE 2500...
