Torque Specs for Water Pump Yanmar 2000
/ Torque Specs for Water Pump Yanmar 2000 #1
Denise35768
Scottsboro, AL
YM2000
I'm trying to find torque specs for water pump for Yanmar 2000. I've searched through the forums and couldn't find this info, but I'm new so I could have missed it! :) Thanks in advance!
/ Torque Specs for Water Pump Yanmar 2000 #2
Just Google "Metric bolt torque value" and there are charts that show the torque. Hard part is figuring out what size bolt you have. You can Google "How to tell Metric bolt sizes" for that.
/ Torque Specs for Water Pump Yanmar 2000 #3
I think those will be 8mm bolts. 17-22 ft lbs for grade 7t, 45-52 for grade 11t. I would use goodntight on water pump bolts. :D
/ Torque Specs for Water Pump Yanmar 2000 #4
Im with winston, i would just snug them and then a bit more, but not ring them off tight but not so loose that they leak. I have replaced many a water pump and honestly never torqued a one. NOt saying it is right but for that application i dont think i would torque them.
I have done quite a bit of work and never had a problem not torqueing.
/ Torque Specs for Water Pump Yanmar 2000 #7
If its any help my Yanmar built JD specs out 228 inch lbs (26N*m) with a M8X45 cap screw on the water pump on a 3TNE74 engine (20hp)
/ Torque Specs for Water Pump Yanmar 2000 #8
That converts to 19 ft lbs.
2024 MODASA  MH-25 I GENERATOR (A65643)
2024 MODASA MH-25...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
Landoll 18' Tilloll (A66285)
Landoll 18'...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2006 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2006 GREAT DANE...
2022 EZ-GO ELITE...
