Broken Mount For LA724
/ Broken Mount For LA724
The back yard is finished now,trying to get some ground cover to grow on it.The brackets are around 1100 dollars each if I remember correctly.Did you try adding plates to each side like I did?The Kubota rep that looked at my tractor said it was the first failure of this kind that Kubota had ever experienced.Good luck with getting it fixed.
/ Broken Mount For LA724 #102
Looking around today at older photos I came across these two that showed one of the failed FEL mounts after it broke the second time. The previous repair consisted of scabbing on a plate to the outside of the arm, and as you can see the second crack propagated right through both mount and repair plate.
I have no idea what kind of material was used for the patch, but it wasn't strong or thick enough to prevent the failure from happening again. It's pretty clear from looking at the bottom of the broken cross section that it had been cracked a while before it failed completely, and that the crack started at the back of the mount.
I weld repaired this failure by grinding a bevel on the scab plate side, welding it, then back grinding the other side to sound weld metal. I then completed the weld ensuring 100% penetration across the failure zone. Used 400F preheat, let it cool by itself in still air. Now another crack started about a quarter inch below the newest repair weld on the back of the mount, pretty much parallel to the failure in the picture.
Haven't talked to my local dealer yet, but I'm hoping that these pictures will help him understand what's been going on.
/ Broken Mount For LA724 #103
I talked to my local Kubota dealer a few weeks ago about the broken mounts. They had never heard of the problem, and I found out later that the regional warranty rep hadn't either until he checked up his line. That turned up four additional cases, not exactly proof of a design problem, but not a clean bill of health, either. I was offered a replacement mount at cost, with an additional cash discount, but I reminded them that both mounts had been broken. At the end of the day I was offered two mounts at cost ($610.76 + tax and shipping each) and a $500 discount. That still left an eight hundred dollar + hole in my pocket, but I guess it was better than nothing. I bought the tractor used three years ago and the mounts had already been repaired once, so it wasn't like I went into this with my eyes closed. The thing's been out of warranty for a long time (it's an '05), and I'm thinking I should be satisfied. Even though the replacement parts weren't served up gratis, I really appreciate the way my local dealer went to bat for me with Kubota. I didn't buy the tractor from them (though I have purchased a 4-in-1 bucket, several chain saws, and a big string trimmer) and they could have just said sorry, you're out of luck.
Picked up the new mounts yesterday, and the design is unchanged from the broken mounts on my tractor. When I asked what would happen if the new ones failed, the dealer rolled his eyes and made noises like it would be my fault because it could only happen through abuse. I've never abused this tractor, unless you consider hauling buckets full of gravel and fill dirt across a side hill abuse. That job's done now, and all that remains to finish the house is laying down another layer of gravel on the driveway. We're looking to move this year, so depending on where we end up I may get rid of this Kubota. It's been a hard workin' machine, but it just hasn't been up to the task of clearing trees and setting grades for new construction. It's been great for landscaping, but I'll let the big boys handle the heavy stuff from now on.
One in the box, one out. Now the fun starts.
Looking at the picture of your new mounts brings back memories for me,but not good memories:laughing:Good luck with replacing the mounts.Good to see Kubota did something for you.
/ Broken Mount For LA724 #105
If it breaks again (let's hope not) I think a flat piece of steel welded perpendicular to the plates you've welded on that would cover where the cracks are starting in the rear would do a lot to strengthen it. I would start from as low as I could all the way up to the upper hole for the pin and use something thick, like 3/8", since you wouldn't need to bend it much and a couple inches wide. That way every time you lifted something you would be trying to stretch the 3/8" flat stock.
/ Broken Mount For LA724 #106
It always seems to be the casting that breaks, or forging, whatever it is. If it was a wider-spread problem, they'd likely switch to a completely fabricated design using flat plate. Then again, Kubota doesn't always acknowledge there's a problem with one of their designs.
Sean
/ Broken Mount For LA724 #107
Yesterday I replaced the old repaired FEL mounts with the new ones from the dealer. In the process I took some photos that show there are significant differences between old and new.
The most obvious difference is that the webbing is much more shallow on the new part which significantly increases stiffness cross wise to the tractor. I also see that the webbing has been eliminated alltogether at the back side of the upper mount arm in exactly the location that cracks were starting on my old parts. In light of this new info I'm thinking it might be worth while to have another go with the Kubota warranty person, who claimed that there were no changes between old and new parts. In my mind it's clear that Kubota engineers understood there was a problem and changed the casting design in an effort to correct it. They did the right thing, maybe there's a chance the rest of the company could follow suit. Do you guys think I should push my luck, or just be satisfied with less than half the repair cost?
/ Broken Mount For LA724 #108
Why have the webbing at all would be my answer
/ Broken Mount For LA724 #109
And that's my question too.. unless there's some engineering theory that says a webbed section is stronger than solid, or less susceptible to cracking, it seems like a really poor place to try and save weight.
Sean
/ Broken Mount For LA724 #110
I doubt you'd get much more from them than you already have, unless it was only a couple months out of warranty.
Sean
/ Broken Mount For LA724 #111
How old is the tractor? I have a 2008 purchased GL3240 with the LA 724 loader and I have the newer style mount you show. My tractor was on the dealer lot at the time for a while to so I am not sure when it was manufactured.
/ Broken Mount For LA724 #112
Sorry if it's a dumb question, but does the actual geometry of that bracket differ between old and new? The old one seems to be tilted clockwise from vertical by maybe 5 degrees and the new one seems to tilt the other way by maybe 10 degrees. Maybe it's just the camera lens or the angle, but they sure look different.
/ Broken Mount For LA724 #113
I was thinking the same thing, but figured it might be just me.
Sean
/ Broken Mount For LA724 #114
Virtually every manufacturer has in the fine print that they reserve the right to change anything without obligation to upgrade previous machines. That doesn't apply to safety concerns - by law those are mandatory and open ended. Then there is the discretion of the dealer and local company rep. Normal practice in such a case is the local rep has a budget - use it where it will do the most good. Unfortunately that means the largest customers, by purchase volume not weight, get the most sympathy$$$. Then there are the pain in the *** customers who they pay off just to get them off their back.
/ Broken Mount For LA724 #116
Didn't get the PM, but those look like the "improved" mounts. Webbing is much thinner than the ones that broke on mine. Just goes to show that Kubota is trying to throw bandaids on a basic design flaw when they should be helping owners out with redesigned mounts that will take the loads these tractors put on them. My experience is that instead, they blame the owners for "abusing" the tractor. Good luck getting Kubota to do anything about it.
/ Broken Mount For LA724 #117
I was using the backhoe and moved the rear of the tractor over to reposition it when I heard a loud snap.I got on the tractor to use the FEL and noticed it was lopsided,looked down and saw the bracket broke clean in two.After going back to the garage I was able to get the loader off.I called the dealer and he said he would come down Saturday to take some pictures and send to Kubota. The loader has a 12 month warranty and the tractor is 15 months old so I am thinking Kubota won't do anything about it after reading other posts on here about similar situations.The tractor has 530 hours on it and most of that is FEL work.I do use it but I don't feel I did anything with the loader that I shouldn't have.When I use the backhoe I lay the FEL bucket flat on the ground so that it will slide when I reposition with the hoe.Maybe moving the tractor around with the hoe is not a good thing to be doing but I thought it was common practice when using the backhoe.After looking at the other bracket I noticed that it has a crack in it as well.You can see from the rust that the broken bracket also had a crack for a while before it broke.I will wait to see what Kubota says but I am thinking I will probably end up welding and reinforcing both brackets.I make my living as a welder so I feel confident in doing this if it is necessary.This incident has kind of left me soured on tractors but that will probably pass with time.I guess tractors are not industrial machines like a real backhoe and are only made to do light work.I never really envisioned something like this happening from the work I was doing with the tractor.Curious to see if anybody else has had a similar problem.The tractor is an L3240.
That's really interesting kcender because I was only doing what I would call light work on the loader at the time it went bang and the loader slew off at an altogether unhealthy angle. Mine broke on the other side, but at almost the exact same place, looks to me like they've under engineered the size of the casting. I haven't noticed a crack on the left hand side but I'll check it out with a bright light and a magnifying glass to see if there are any signs of weakness. I hope the welding and extra plates added to either side of the cast weld will be strong enough; if it holds OK then I'll probably beef up the other side too before it breaks.
2025 Pabreak Hydraulic Brush Cutter Skid Steer Attachment (A61567)
2025 Pabreak...
2019 FREIGHTLINER 126 SLEEPER TRUCK TRACTOR (A59909)
2019 FREIGHTLINER...
LID Cutter for Mini Excavator (A61166)
LID Cutter for...
2010 Ford F-150 Pickup Truck, VIN # 1FTEX1CW9AFC54781 (A61165)
2010 Ford F-150...
2018 CATERPILLAR 289D SKID STEER (A62129)
2018 CATERPILLAR...
2020 Kinze 3505 High Speed 6/11 Planter (A63118)
2020 Kinze 3505...
