Honda RT5000 multi-purpose sub-compact tractor engine tear down
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #1
SilverLakeFab
Concord, NH
Kubota B6100D & Honda RT5000
I purchased a Honda RT5000 4x4 subcompact tractor a couple months ago and I was told it had a seized engine. I finally got to start the tear-down last night and I figured I would share the project with the folks here. I've attached a few pictures of the machine to show where I am right now. So far, the front body panels have been removed, the clutch has been removed, a bunch of parts have been unbolted from the engine, and the rubber engine mounts have been unbolted. All that's left is to unbolt the engine from the drive-shaft to remove it from the engine. Where I quit last night was fighting the motor at this stage. It was late and the U-Joint splines are stuck together, so I unbolted the U-joint adapter from the flywheel, but since there's a screen attached to that in the motor cowling, I have to unbolt the cowling the hard way (all the bolts go in from the back side).
As mentioned above, I was told that this engine had a seized engine, but I pulled the head off (yay simple push rod engines) and the piston wasn't stuck (I was able to push in further into the cylinder by hand). However, the piston is no longer attached to the crankshaft either. Who wants to guess how many pieces the connecting rod will be in when I get the side cover off the motor? I'm guessing 5. Even with a catastrophic failure like this one, I should be able to rebuild this whole engine for about $140. Not bad!
I'll post more pictures and info on this little project as I go on with it.
RT5000 pic1.jpgRT5000 pic2.jpgRT5000 tear down pic1.jpgRT5000 tear down pic2.jpgRT5000 tear down pic3.jpg
I was close with my guess of 5 pieces for the connecting rod, but I'll say I'm right because of the part of the piston that I dug out as well. I was hoping that the crank was usable, but it's toast as well. It looks like I'm in for a piston, connecting rod, crankshaft, and cylinder bore. It's less expensive than it sounds though. If I can get this with a first oversized piston, I'll be golden, as a cylinder bore is only about $30.
Honda GX340 Roller Kit with Crankshaft Piston Rings Con Rod Pin and Clips GX 340 | eBay
I cleaned the block and found a good size crack. It's a 20 minute fix and it'll be welded up tomorrow. This is probably the easiest broken case weld job I've ever had to do. I'll post pics tomorrow.
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #4
Looks like 2 cracks(3 if you count the tee), but keep us posted. With my welding capabilities..............I would bury it with my Massey:laughing:
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #5
Those are cool little tractors. http://powerequipment.honda.com/pdf/manuals/31752601.pdf if you don't already have it. I have always hoped to run across one somewhere at a price I couldn't pass up, just to have one. Never read anything about the 11HP models being short on power ( even with 1100# combined F/R lift capability). How cool would it be to find one of the later 3cyl diesels w/ factory FEL and backhoe!!
The case has been fixed and is ready for an over-bore (0.25 mm should do it; the bore doesn't show much for wear). I've posted pictures of the fixing procedure below, but none of me actually welding (I can't do four things at once, only three :) ). The first step is to press the case back into shape. When doing this, you have to be aware that you may cause other cracks to occur (pretty common). Next, clean the weld area as much as possible. When welding anything aluminum that contained oil, you WILL fight through poor weld quality when you put down your initial filler bead, as no matter how clean you think the area is, there will always be residue within the crack itself. Even if you put the thing through an ultra sonic cleaner, it will NOT be clean, so you have to be prepared for that. Also, when possible, do the external weld first, as it's easier to fight the contamination of the puddle from the outside. Next, the filler is melted in thoroughly. I'm not looking for a pretty stack of dimes with this weld; I need an evenly melted in weld with full penetration and strength. Next I cleaned the inside of the case again, as any time aluminum is exposed for over a minute, it will have corrosion. After doing the outside weld, the inside weld is easy, as almost all the impurities have been burned and floated out of the remaining crack. Of course, I went over the weld area twice to ensure a super flat weld so I don't have a clearance concern. This was a utility job that doesn't have to be super pretty, but to show that I can do pretty aluminum welding, I've posted a sample picture of my nice looking work. :)
Pretty work examples: pretty aluminum weld.jpg
With that out of the way, the block will be pressure washed tomorrow and brought to Sanel's machine shop (in Concord, NH) for an over-bore. If I had to have the case welded up by another shop, it wouldn't be worth it, but now for $30 and about 45 minutes of my time, the case/cylinder will be good as new! I still think I'll be out of this engine rebuild for just under $200. I can't complain about that.
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #7
Nice looking repair job.
Thanks! I'll post more picture of the reassembly when I get the block back from the machine shop and the parts arrive to rebuild it in a couple weeks.
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #9
Nice work. :thumbsup:
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #10
Excellent job!!! As much equipment as we have and welding/fabrication we do just to keep things ( wife calls them toys....from the amount of work/repair sometimes I think junk may be more appropriate!) going around here, we aren't set up to do Al welding/repair.....and you obviously know the art of TIG welder. That is the next form/(ART!!) I want to set up, learn and put to use. Can't wait to see the progress. Are you going to do a complete restoration? I'm sure you've already been all over the net, but I see Formula H, Middletown, NY, Honda Power Equipment and 5000 Tractor Sales and Service has a number of OEM parts but they're sure proud of them!!
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #11
Very nice work neighbor.
Hi Darryl,
Thanks for the compliment. I've been TIG welding professionally for 13 years now and I use my TIG all the time. Aluminum isn't hard, it just requires patience. As far as parts go, I'm actually also the online parts manager at Freedom Cycle in Concord, NH and we sell parts for these machines too (we advertise a bunch on eBay and sell parts through our web site as well). There are a handful of parts that we can't get for the RT5000 (very similar to the H5013), but there is always a way to fix anything that's broken on the machine. From what I can tell, everything should be in working order once I get all the engine put back together. If I keep the rig (I'm pretty sure I will), I'll float out the dents in the hood and paint all the bodywork. If I get it running right, I want it to look presentable as well.
The next thing is to wash a bunch of parts tomorrow and paint the rear cowl of the motor (has dents to remove and it has a little bit of rust). Once I get this beast running, then I'm onto making the mower deck presentable, as it does have a bit of rust, but isn't rusted through. I know that I have to fabricate the front mower deck linkage as well, but that's the easy part. Depending on how bad the mower deck is, it may have the top piece of steel replaced altogether. I haven't given it a super good inspection yet. Here's a couple pics of that.
If I keep the machine, I'll also be setting up the 3-point hitch. I have an almost complete category 1 hitch set up that I'll adapt this tractor to use. I know that this machine is set up for a category 0 hitch (factory accessory) set-up, but category 1 would be fine on it if I'm only using it for light things. Also, I want to be able to move the same implements that I use on my Kubota B6100. I'll keep this thread posted!
Hi Darryl,
I just realized who you are. Small world!
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #14
Hi Darryl,
You probably have me confused with someone else.....unless you used to live in S. IL? I don't own a commercial shop, although my middle son does a little fab/repair work for extra money. I just love to play with and do use a lot of metal working equip out of necessity ( remember the "toys/junk"). Have a small shop here at the house set up with a small Lathe, mill, metal band saw, plasma cutter, arc, mig, brake, shear, roller and the other small necessities. TIG setup and Iron worker will be my next main purchases.
About the only way you'd know who I was is: I have owned rental property and worked for Il Dept of Corrections for years. I have rented to hundreds and after 25 yrs., probably forgot most of them. I've probably "worked" with 30 thousand ( IDOC).....Hope I've never given you my, "Hey, we've all made bad decisions" speech. Church maybe?
I have been an avid off road MC enthusiast for 40 yrs though, but doubt you know me from that ( anymore you can call my riding style "Rag Doll" :thumbdown:) but I was never notable, except to my friends " DUDE! I thought you were dead! You think you can ride back with THAT rim and those bars"?.
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #15
Hi Darryl,
Small world is right. I plan on buying a WR450 from you guys at Freedom. Done alot of business there
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #16
My name is Darryl also. sorry for the mix up
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #17
Duh.....I DID notice you said something about "neighbor" in an earlier post. Never noticed your user name. Sorry.....darn, I feel pretty stupid. Anyone want to know any other personal details about me since I'm putting it all out there :laughing:
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #18
Nice repairs so far
THose RT5000's were way, way ahead of their time. Still are for that matter. 4wd. 4ws. front, mid and rear PTO.. You cant get that in anything available in North America at this moment on its size. And throw into the mix honda reliability. Both my neighbours had one, Id love the chance to get one now (for the right price). They were a great blower and mower, which is what probably 90% of the TBN members do with their CUTs.
Some days I wonder what goes through Hondas head (I say this owning 6 Hondas). They got rid of their (excellent) tractors. Got rid of their independent outdoor / small engine dealers and combined them with auto dealerships (Honda Powerhouse concept). Got rid of their commercial mowing equipment. Made everything "fixed price" so there is no real negotiation. Gah... Seems like they really got their heads up their asses these days.
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #19
At least we spell it the right way:laughing:
/ Honda RT5000 multi-purpose sub-compact tractor engine tear down #20
Nice repairs so far
...And front 550 lbs capacity rockshaft to match the rear 3 PTH.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Gravely ZT 1540 40in Zero Turn Commercial Mower (A59228)
Gravely ZT 1540...
2014 MASSEY FERGUSON 5612 DYNA-4 TRACTOR (A59823)
2014 MASSEY...
2016 Kubota SVL75-2 (A53317)
2016 Kubota...
2016 FORD TRANSIT T250 CARGO VAN (A59575)
2016 FORD TRANSIT...
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
