why does this engine have more power when reversed
/ why does this engine have more power when reversed #1
Nooodles
Banned
De
Kubota BX3030 Cab with upgraded speakers
been using my dads very old Kawasaki mule lately to pick up sticks and stuff. For some reason when the engine is reversed it has much more response in reverse and doesn't smoke. I asked my dad and he said he didn't what in the heck I was talking about and walked away. What would cause this. When the engine is going forward it does run so well.
ned
/ why does this engine have more power when reversed #2
What do you mean by "engine reversed"? How did you accomplish this feat? I remember once a neighbor was using his Deutz hard on the loader and managed to kill the tractor, but hit the clutch just in time and it started to run backwards. He shut it off immediately and started it right back up forwards. I didn't understand what had happened until I realized the rain cap had slapped down on the exhaust and the air was whistling in around it. It only ran that way for a few seconds, no damage.
So I repeat, are you sure you were running it backwards? Your exhaust would now be coming out through your air filter, so I'm not surprised you don't see smoke.
/ why does this engine have more power when reversed #4
Do you now have to use reverse to go forward? Maybe the kid will learn us something.
/ why does this engine have more power when reversed #5
/ why does this engine have more power when reversed #6
If you mean it has more snap when you shift into reverse it's most likely because reverse is geared lower.
/ why does this engine have more power when reversed #7
It should not have more power but it may run just fine if there is no exhaust pressure in the air filter. With the gears reversed it may just feel like it has more power because of the gear ratio choices you have.
/ why does this engine have more power when reversed #8
Yep...THIS is the answer...
/ why does this engine have more power when reversed #9
For what it is worth, some older gas golf carts run the engine backwards for reverse. When you stop the motor stops. when you push the gas pedal the motor starts back up.
I wonder if an older kw mule is the same way.
Sent from my iPhone using TractorByNet
/ why does this engine have more power when reversed #10
ned
From such a smartass , that is the dumbest thing I have read today .
/ why does this engine have more power when reversed #11
As far as I know, Mules do not have different ratios for forward/reverse. They are powered by a 4 cycle engine through a CVT system with simple forward/reverse gear selector
/ why does this engine have more power when reversed #12
You might have some luck with checking on a golf cart form (buggies gone wild) they have info on those older motors. Might have to do w ignition timing or compresson.
Good luck.
/ why does this engine have more power when reversed #13
Not sure this is a factor or not but when I am going backwards at 20 MPH it seems faster than 60 MPH when going forward. As I understand it only a 2 stroke engine can run in either direction and the fuel and exhaust be correct. Did it once with a model plane but it would not take off backwards.
/ why does this engine have more power when reversed #14
Very easy to get a 2 stroke to run backwards. Ski-doo has been doing that with their snowmobiles for 10 years, or more.
/ why does this engine have more power when reversed #15
Yep, older golf carts were 2 stroke. They would couple a generator to the motor and use it as a starter. Flip the switch one way it runs forward the other and it runs backwards.
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
2007 Load - Max Loadmaster Gooseneck Trailer (A66285)
2007 Load - Max...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
Kubota V3600-T-E102 Diesel Engine - Pump Takeout (A63689)
Kubota...
MF GC2300 fel replaced
Sellick S80 (A60462)
