bam747
- Joined
- Nov 10, 2004
- Messages
- 209
- Tractor
- John Deere 4720 (2007)
The power steering on my 4720 has a very, and I do mean very, intermittent problem where it will essentially lock up.
By "lock up", I mean everything had been working fine and then suddenly the steering wheel will freeze up. It has done this with the wheels straight ahead or strongly turned. It has done it in cold weather, warm weather, shortly after starting the tractor, and after hours or days of continuous use with nary a hint of a power steering issue.
When my tractor does exhibit this problem, it has always cleared itself up after cranking on the steering wheel for a minute, and then I never see the problem again that day.
I cannot reiterate just how intermittent this problem is, which is actually more frustrating that if the steering would have just permanently locked up.
I currently have the tractor at a local JD dealer's service department. They've had the tractor for two weeks, but of course they cannot replicate the problem. To the service managers credit, he did do a search in JD's service advisory system and DID find some reports of power steering problems with some possible diagnostic tests to run. Still, they have no idea what to fix at this time.
Has anyone else out there experienced this problem with their 4000 Twenty series tractor? If so, have you found a solution?
