How to remove fallen tree from pond
   / How to remove fallen tree from pond #1
rekees4300
Elite Member
Indiana
JD4300
Today a large (3' diameter at the base) Oak tree fell into my pond. The removal game plan is to cut off the portion (15') on the bank with a chainsaw to reduce its weight then use a come-a-long to pullout the portion (50') in the water. Ordered a 4-ton come-a-long from Amazon and it should be delivered Friday. Hopefully it will be powerful enough to slide the tree through the muck and cattails? Any other tips/suggestions on how to remove the tree would be appreciated. Can't reach it with the tractor so that isn't an option.
   / How to remove fallen tree from pond #2
Are you going to use a come-a-long or a winch? Perhaps I am wrong, but I would think using a winch would be easier. Less manual exertion. Just my thoughts. Best wishes.
   / How to remove fallen tree from pond #3
When it gets to the bank, try to get some smaller logs, pipes, something round under it to use as a roller so it will roll up the muck instead of digging in.
Or, just called Shelby from "Axe Men". :)
   / How to remove fallen tree from pond #4
Could you use a long chain and pull it with the tractor a ways? Then cut off some of what is out of the pond, reset the chain and pull some more, repeat until light enough to pull the remainder with the tractor.
Good 3/8" chain is pretty expensive though to buy a length of it. TSC does, or used to, sell it in a bucket with about 40' of chain in it. I bought a bucket and cut that into a 20' and two 10' chains. I can hook the chains together if I need the length. 3/8" chain is pretty heavy to handle for most uses.
Same procedure could be used with the come-along. Pull, cut, pull, cut.
   / How to remove fallen tree from pond #5
Could be wrong, but I'd be really surprised if that come-a-long moved it much past the cattails let alone up the bank.
3' base is a big tree. A big heavy tree.
   / How to remove fallen tree from pond #6
I'm inclined to agree with Will. Oak is a heavy wood and it is going to be water logged. In addition, the limbs will likely be digging into the muck.
Steve
Current game plan is come-a-long. Dunno if winch is feasible. Never owned a winch so not familiar with their operation. Aren't they electrically powered and therefore required to be attached to a vehicle? Are any available that use 120AC (I have a generator) and could be attached via chain to a tree?
   / How to remove fallen tree from pond #8
Thats what I was thinking too. I like Dave's idea using chain, but if that didn't work,( sawing it could prove dangerous since a majority is in the water). I think I'd rent or hire a backhoe if I really needed it out.
I've thought about buying a few round posts to use as rollers. Thanks. Shelby is an idiot! :)
I plan to use pull-cut-pull-cut technique assuming the come-a-long will be capable of the pull part. :confused3: Long chain isn't feasible since it would have to be about 500'!
2016 Bobcat E85 Midi Excavator (A56857)
2016 Bobcat E85...
Massey Ferguson 9250 (A56438)
Massey Ferguson...
2013 Godwin CD103M Towable Diesel Pump (A59228)
2013 Godwin CD103M...
Unused 2025 CFG Industrial H15R Mini Excavator (A59228)
Unused 2025 CFG...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2020 Kinze 3505 High Speed 6/11 Planter (A56438)
2020 Kinze 3505...
