How to remove fallen tree from pond
   / How to remove fallen tree from pond #1
rekees4300
Elite Member
Indiana
JD4300
Today a large (3' diameter at the base) Oak tree fell into my pond. The removal game plan is to cut off the portion (15') on the bank with a chainsaw to reduce its weight then use a come-a-long to pullout the portion (50') in the water. Ordered a 4-ton come-a-long from Amazon and it should be delivered Friday. Hopefully it will be powerful enough to slide the tree through the muck and cattails? Any other tips/suggestions on how to remove the tree would be appreciated. Can't reach it with the tractor so that isn't an option.
   / How to remove fallen tree from pond #2
Are you going to use a come-a-long or a winch? Perhaps I am wrong, but I would think using a winch would be easier. Less manual exertion. Just my thoughts. Best wishes.
   / How to remove fallen tree from pond #3
When it gets to the bank, try to get some smaller logs, pipes, something round under it to use as a roller so it will roll up the muck instead of digging in.
Or, just called Shelby from "Axe Men". :)
   / How to remove fallen tree from pond #4
Could you use a long chain and pull it with the tractor a ways? Then cut off some of what is out of the pond, reset the chain and pull some more, repeat until light enough to pull the remainder with the tractor.
Good 3/8" chain is pretty expensive though to buy a length of it. TSC does, or used to, sell it in a bucket with about 40' of chain in it. I bought a bucket and cut that into a 20' and two 10' chains. I can hook the chains together if I need the length. 3/8" chain is pretty heavy to handle for most uses.
Same procedure could be used with the come-along. Pull, cut, pull, cut.
   / How to remove fallen tree from pond #5
Could be wrong, but I'd be really surprised if that come-a-long moved it much past the cattails let alone up the bank.
3' base is a big tree. A big heavy tree.
   / How to remove fallen tree from pond #6
I'm inclined to agree with Will. Oak is a heavy wood and it is going to be water logged. In addition, the limbs will likely be digging into the muck.
Steve
Current game plan is come-a-long. Dunno if winch is feasible. Never owned a winch so not familiar with their operation. Aren't they electrically powered and therefore required to be attached to a vehicle? Are any available that use 120AC (I have a generator) and could be attached via chain to a tree?
   / How to remove fallen tree from pond #8
Thats what I was thinking too. I like Dave's idea using chain, but if that didn't work,( sawing it could prove dangerous since a majority is in the water). I think I'd rent or hire a backhoe if I really needed it out.
I've thought about buying a few round posts to use as rollers. Thanks. Shelby is an idiot! :)
I plan to use pull-cut-pull-cut technique assuming the come-a-long will be capable of the pull part. :confused3: Long chain isn't feasible since it would have to be about 500'!
GOODYEAR SET OF 12.4/11-24 TIRES WITH 5 BOLT HUB WHEELS (80% TREAD) (A55315)
GOODYEAR SET OF...
2019 GALYEAN...
*Selling at Royal Auction Tampa, FL Location* Runs and drives. Needs jump. 1987 hrs. (A59228)
*Selling at Royal...
2018 Kubota RTV500 4x4 Diesel Utility Cart (A59228)
2018 Kubota RTV500...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
Toro z turn (A56859)
