Grapple Which type of grapple is best suited for...
   / Which type of grapple is best suited for...
Stop wasting your time with a chainsaw. Get a ripper and take those trees out whole rather than being left with a nasty stump. Checkout the ripper thread from a year or two ago.
Do you mean a stump bucket / root ripper? I don't know if a tractor this size can handle the trees I'm doing. Its hard to see in the pics, but most of the trees I'm doing are 12" & bigger, oak & maple, with tough roots.
   / Which type of grapple is best suited for... #262
Not a stump bucket. A BH mounted ripper tooth.
I cannot say for sure about bigger, but I have certainly removed 12" trees via the ripper and push over method. I agree that any bigger than that gets dicy as it would be hard to push them over even after ripping lateral roots. Trees with big tap roots might be tough too. Still, a bigger excavator would make quick work of those and you wouldn't be digging out stumps for the next year or two.
   / Which type of grapple is best suited for... #263
So I put an hour or 2 on the tractor tonight using the grapple. The more I use it, the more disappointed I am with it. It seems 9 times out of 10 when I pick up a pile of stuff with it, almost all of it falls out. 2 different things are causing it, 1 is the lid design, and the other is the tine spacing.
With the lid design, it never actually can pinch anything between the tines. Also, having only 2 upper tines, there is little chance of actually pinching anything.
Even 'scooping' stuff up doesnt seem to go well for me. I seem to dig more dirt than anything with it!
I can see it working just fine with pile of brush, but I am dealing more with deadfall and firewood type chunks.
I also discovered today why it 'clatters' so much when adjusting the roll of the bucket, or up/down (anything really that jerks it in general). The quick attach openings are too large, and I have almost a 1/4" gap between the pin and the 'locking' side of the opening.
I know some of my issues are possibly still adjusting to using it, but I can see some things are not going to resolve with experience.
I wonder if I am asking too much. All I want to do is clean up the area in the pics...
   / Which type of grapple is best suited for... #264
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317225"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317226"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317227"/>
That is a challenging task. The trees limit maneuverability and you are not dealing with brush or logs but rather various sized fallen branches. Recognizing that you don't have much volume, the upper jaw lid doesn't have much of a role so just leave it full open.. I would just push stuff into a pile and not try to move the pile until it was larger. I would also try just scooping branches into the grapple and curl to keep the load in place until adding to the bigger pile. Once you get a good sized pile, come over the top, crush the pile and in the same manuever, close the upper lid.
   / Which type of grapple is best suited for... #265
Thanks! That makes me feel a little better :)
So I AM expecting a bit too much out of it! Maybe I will just put the kids on the project....
   / Which type of grapple is best suited for... #266
I forgot the picture that shows the gap I am referring to....
   / Which type of grapple is best suited for... #268
If the kids put stuff in a pile, with branches lined up parallel, it would go a lot faster. Grapples are not very efficient picking up single small branches. I have neighbors who collect brush and branches like yours into piles about 50 ft apart. I wait until the piles look to be about a grapple full and then move them.
I have a special adapter for the FEL that allows me to mount 3PT implements up front. If I didn't have kids to make piles and had a large area, I would probably use a landscape rake on the FEL pointing forward to push stuff like this into a pile and then come back later with a grapple.
   / Which type of grapple is best suited for... #269
Both are great ideas..... I will have to consider such an adapter....
   / Which type of grapple is best suited for... #270
Yours a Wildcat?
No, he has a Titan from PalletForks. I have their forks that fit like his grapple, but they are forks so it is not an issue (not pulling with them). I have their rake grapple and have a good fit. They tightened up their manufacturing a while back, but it looks like they slipped back to their old ways.
   / Which type of grapple is best suited for... #271
Well if you didn't have 11k of posts I would search for pictures of that bad boy ripper tooth on your BH. Mind saving me some search time and re-posting some pics? Thank you.
   / Which type of grapple is best suited for... #272
Now I have to check my forks too!!
   / Which type of grapple is best suited for... #273
I am traveling so don't have access to photos right now. However, there is a thread I started a couple of years ago titled something like "trees beware, I added a ripper to my Woods BH90x" that has lots of photos at the beginning as well as a pretty good discussion of various issues. Shouldn't be hard to find with the search tool. Basically, I worked with Michigan Iron and Equipment to adapt a full size excavator ripper tooth to scale for my Woods BH90x then to fabricate it. I then went to work removing trees with trunk diameters from about 5-15" by simply ripping through the roots around the base and then pushing the tree over. Works great and takes the "stump" out without nearly the soil disruption associated with digging a stump out after dropping a tree via traditional chainsaw method. And, to bring us back to grapples, I could then simply transport the ripped trees to a pile with my grapple. Very efficient combo for clearing 20-30 years of trash trees from a neglected pasture.
   / Which type of grapple is best suited for... #274
I just checked out your thread... you're forgetting that I don't have a backhoe! With that said, if I had access to a backhoe or excavator... that would be my way of removing these trees as well.
   / Which type of grapple is best suited for... #276
Very cool thread on the ripper. Thank you.
   / Which type of grapple is best suited for... #277
I would fix that gap pretty quick with a welder and some steel. Show the photo to the manufacture, and if you don't weld yourself , take it to a local weldor and see if the manufacture can pay to have it done.. Should not be much money. I would be afraid with it shifting around, it might pop off on one side and twist your SSQA. I really think you ought to fix it.
James K0UA
   / Which type of grapple is best suited for... #278
James K0UA
I plan to fix it - problem is, I only have my dads 110v MIG here, and my trailer axle has sprung a leak so to speak.....
   / Which type of grapple is best suited for... #279
<img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=317391"/>
110v MIG running fluxcore would be fine. You just need to put in spacers. Tack welds would probably work so a bead of 0.030 fluxcore would certainly do the trick.
   / Which type of grapple is best suited for... #280
I fixed my Wildcat grapple and forks with putting 1/4" spacer plates on the bottom brackets. Works great and the implements fit tight now.
2010 International 4300 2,000 Gallon Water Truck (A55973)
2010 International...
2018 VOLVO EC480EL EXCAVATOR (A60429)
2018 VOLVO EC480EL...
2011 NORAM POWER SYSTEMS 100KW GENERATOR (A58214)
2011 NORAM POWER...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59230)
iDrive TDS-2010H...
204549 (A52707)
204549 (A52707)
WBrock Meyer 2000S 70'x12' 2000 BPH Grain Dryer W/Legs&Mill Discharge Sylo,Controller is included (A57148)
WBrock Meyer 2000S...
