BX25D. Mod #1 and continued.
/ BX25D. Mod #1 and continued.
I have to say that I like the tool box that came with the BX25D. It's simple but very effective. The box is only made to attach to the left side but I wanted one for the right side as well so I ordered the kit and yesterday Newfoundland Kubota called and said it was in. We dropped into the dealer to pick it up and was pleasantly surprised when they said "this is compliments of the dealership". How cool is that? Wow. I was pleased to say the least.
Anyway I had an hour to attached it this morning but before I could I had to make a few changes to make it work on the right side so after some pondering I decided to cut on bracket off and re-weld it on the other side of the bracket. Yes it made it a little tricky to get the nuts on but I got it mounted on the right side plus the off set is perfect for turning the seat when I need to operate the back hoe.
I figured I'd post this simple little mod just in case someone else was considering it.
/ BX25D. Mod #1 and continued. #482
Very cool, and VERY useful. One can never have too many toolboxes, close at hand.
/ BX25D. Mod #1 and continued. #485
Is that thing plastic? Where are the chains supposed to go?
Thanks. So true on the toolboxes
Nice. I wonder if that would work for our BX2660...
Aaron Z
I don't see why it wouldn't. ROPS should be the same size.
4shorts. Has this become an addiction? :)
Heck no. I don't post photos of my addictions ;)
Yup. Chains go between the hooks :rolleyes:
/ BX25D. Mod #1 and continued. #487
I really like the saw holder...
Maybe a Loper holder too?
I use to keep the saw in the bucket and that was great until I forgot it was there... luckily no damage done!
Thanks. Ya the saw holder got an axe holder just at the base of it and the chipper has the lopper holder. That's the reason I made the holders. I was afraid I'd run it all over :eek:
/ BX25D. Mod #1 and continued. #489
If I was still in R & D... we would give you the merchandise and turn you loose.
Almost like some of the sponsored auto race teams.
Many years ago, back in the 60's, my uncle was sponsored by Oldsmobile and he had access to their little 215 ci Aluminum Block V8 and all the goodies... carbs, manifolds, ultra high compression heads and forged cranks...
Nice that Kubota has acknowledge your accomplishments and that of the Mrs. at the Dealer level!!!
/ BX25D. Mod #1 and continued. #490
Chipper... do you see any need for the hydraulic feed option with your wallenstein?
/ BX25D. Mod #1 and continued. #491
Also wanted to ask if there are any plans for a backhoe mounted hitch receiver for moving trailers around the yard?
/ BX25D. Mod #1 and continued. #492
Hey guys. Got a one hour break from the work today so I just did another mod. 75% Kubota and 25% me. I'll post in an hour :D
That's the spirit! Can't wait to see what you did!
Thank you sir for your vote of confidence. That would be a very cool job to have for sure :thumbsup:
For me personally no but if we had larger trees I would. My wife and I got about 6 hours on the chipper now and even putting green trees through it, it haven't plugged and its pretty good as it is with out the hydraulic feed. I'm also very happy I chose the chipper/shredder combo as well. We chipped this much (see photo) in 30 minutes. Now we'll use the chips tomorrow around our shrubs.
No.That's something I don't need because we have our old Toyota fork lift that I restored a few years ago. Its got the hole in the fork to install a ball and we've towed some pretty big boats with it plus it turns so sharp.
chipping photofrom this evening.
No stray smartcars hanging around tonight to chip up?
Aaron Z
No not then but there's a Jag here I wish would fit in it ;)
What Paul gets done in an hour takes me a month to do.
Hey Matt. Do you sleep? 3:21 AM you posted :confused2: :laughing:
This is a poor place to be if you need to take a break. Worked in the shop all day rebuilding a hay grabber that came in destroyed. It was on a big Cat loader when something went wrong with its hydraulics and tore up everything on the grabber. Parts were bent up, cracked off and some just plain wore out so I didn't stop much yesterday to get that ready for them. Between the gouging,machining,fabricating and welding it was a pretty big job. As I'd leave the lathe wifey would move in and clean it up then I'd leave the mill and she'd do the same there. We get a lot done working together like that.
Got in for supper at 6:00. 6:30 wifey and I were out chipping again and worked until dark. We don't see to many visitors in the evenings. They're afraid we'll put them to work
:laughing:
Here's a few more photos to keep the boredom going. Sorry about the quality on some of them. They were taken with the phone.
/ BX25D. Mod #1 and continued. #498
Paul- at some point, I was about to put some fresh wood chips down around shrubs, and I was told that they would do something undesirable, like suck the nitrogen out of the soil as they decompose... but I am not much of a gardener. Just saying you might want to check it out? Maybe it makes no difference. Looks like you two are having fun playing with your new toys!
Man I'm not much of a gardener either but I've adding chips and mulch to shrubs for 25 years. I'll snap a photo of a couple of shrubs I have here later on today. They are Hugh. That being said I scanned a copy of the brochure we got from Wallenstein. Interesting read if it is fact. I like these kind of posts. Hopefully we learn something from them. Thanks buddy.
/ BX25D. Mod #1 and continued. #500
That 3:21 AM post is server time, I probably posted it around 11:21 PM or 12:21 AM my time.
Good grief, a 70's XJS Jag! How has it survived rusting away in your climate?
2011 Peterbilt 365 Altec AC38-127S 38 Ton Straight Boom Crane Truck (A61568)
2011 Peterbilt 365...
2013 John Deere 1770NT Planter (A63109)
2013 John Deere...
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2018 INTERNATIONAL...
Arrow Quip MAN-STBR Sternum Bar (A64047)
Arrow Quip...
